Question about Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher
Problem with Bosch built-in Dishwasher Model SHU6806UC
The cycle time shows 2 hours even though we have it set for "quick Wash" and then gets down to 1 minute and still runs for an extended period. The dishwasher is 6 years old.
  • kaveyg Dec 19, 2008
    Just called the repair folks. $100 just to come out and look at it. Any chance Bosch is going to step up to the plate on these things. I spent a $1m for this thing ... funny how they tend to go out right after the warranty expires.
  • robertsanta7 May 11, 2010
    SHU6806UC
    some black water coming from under. Why is this water all black?
    Where would that be leaking from??
    Thanks.
    Problem Solver:
  • 7 Answers
First of all the "2H" is an error code - notice the upper-case letter. Delay start uses lower case letters (e.g., "2h" means 2 hours).
Also, It turns out the number 1 showing at the end of the cycle doesn't represent 1 minute...it is another error code indicating the cycle has timed out!
I have a repair man here right now trying to fix the same problem. As soon as we know the solution, I'll post it for others.
Posted on Jul 28, 2009
  • Jean Uptmor Jul 28, 2009
    Addendum to my earlier post...
    The control board was replaced with a factory reburbished one. Still having the same problem. The tech guy said my water is not hot enough at the inlet (BTW, it's 120 degrees, just what the manual states it should be - duh). He left with an attitude and I called customer solutions. They're sending out a senior tech repairman on Thursday. We'll see what happens next...
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
Posted on May 30, 2008
I know there are buttons you push simultaneously to get it to drain. which are they?
From The Guru Macmarkus:
**TO CANCEL A CYCLE:
Press the Scrub Wash and Delicate / Econo Buttons both in at the same time. The unit will then drain and the figure CL will appear in the display.**
Jan 05, 2011 | Bosch 24 in. SHU6802UC / SHU6806UC...
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Cycle time
yes its normal.bosch dishwashers use very little water and energy but,the cycles need to be longer to get the dishes clean. its perfectly OK.(ps use cascade powder if you can)
Jul 24, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Reset model smu7052uc
there is none- if the program is mucked up-- pull the plug for 5 minutes
Jul 16, 2009 | Bosch 24 in. SMU70 Built-in Dishwasher
SHU6806UC leaking from under
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Apr 04, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch 6802UC dishwasher is leaking water from bottom of door
Leaking Dishwasher
heatman101
Jan 22, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Long cycle times
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. About the led: If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Dec 30, 2005 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher Logo
1,066 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
