Question about Hitachi 51G500 51" Rear Projection HDTV-Ready Television
I have a Hitachi 51G500A TV. I Believe the green tube is out. How do I install a new one?
    Problem Solver:
  • 14 Answers
I hate to say it if you can fine one it would be from another scraped set it is a chore to do for a pro.
Recycle the set correctly.
SO sorry
Posted on Oct 03, 2010
Where is the lamp located on my HITACHI 51G500A?
51G500a is a rear projection CRT type set----It has no Lamp--it uses three picture tubes.
What is the problem with the set? Verify model number posted here is or is not correct.
SD TECH
Aug 16, 2010 | Hitachi 51G500 51" Rear Projection...
I have a Hitachi Projection TV 51G500A 2004 ,
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Hitachi 51G500 51" Rear Projection...
I have a Hitachi HDTV Model No. 51G500A
Replaced convergence ics. This set is old and if colors especially red are flagging crts are going bad . I would not repair a set this old .
Aug 15, 2009 | Hitachi 51F59 51" HDTV Projection...
Hitachi 51G500A and the screen when blank
Hi I am vortash I have just looked at the service manual for this set and it actually does not use a bulb as it is not an Lcd or DLP projection TV . It actually employs three CRT based tubes that produce the picture with automatic focus and convergence systems . If you do not have the manual for this set you can download it from http://www.safemanuals.com free of charge It says that if you have sound and no picture turn the set off and unplug it for 3o seconds then replace plug and turn on from switch on set not from the wall plug switch .. as this may reset the tv and cure the problem .. hope this helps regrads Vortash
Jun 08, 2009 | Hitachi 51F500 51" Rear Projection...
Hitachi 51G500A Convergence Problem
Hi, 110`s & 150`s are both replaced by stk 392-120`s. which run waaay cooler because the 120``s are rated at 4 amps while the 110`s and 150`s are 3 amp devices , the real key is to make absolutely certain you are not buying generics (which are everywhere on the internet), there should
be NO black print on the back side and a 4 digit code (not 5) on the front, top right corner, the originals or OEM`s are never $8.99, usually run about $12-15 and are made by Sanyo but the word sanyo will NOT be on the IC`s , so go by the info above, be sure to check for burnt resistors next to the heatsinks as well, good luck, video-tek
Feb 03, 2009 | Hitachi 51G500 51" Rear Projection...
Hitachi TV green CRT tube
Good Day, optih;
Why do you think the TV's green CRT is not working? If that is the case I would think of buying a new TV, or spend about
$550.00 to repair the TV.
Good Luck, big IRISH. PS Only use a Factory Authorized Service Center.
Jul 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53udx10b tv
these tvs usualy come with red green and blue tube a single unit mounted in back ,check ebay as there are some companies in japan china who still sell the repacement units.
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 51G500A picture adjustments
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence and other adjustments of many popular brad PTVs are given in detail.
Jun 04, 2017 | Hitachi Televison & Video
Green Screen
Sounds like the green tube is shorted.
Oct 06, 2007 | Hitachi 50VS810 50" Rear Projection HDTV
51' projection tv(Hitachi 51G500A)
The Hitachi part number for the screen assembly for the 51G500a is KR02844. You can call a Hitachi parts distributor and see for yourself how much those things cost, but I warn you they are not cheap!
May 12, 2007 | Hitachi 51G500 51" Rear Projection...
Hitachi 51G500 51" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
