Question about American Standard SILHOUETTE AMERICAST KITCHEN SINK Single Bowl 4-Hole 7172
I have an Americast Standard sink and I am looking for a sink rack . Can you help me?
Is there a stainless steel or cast iron replacement sink for Americast 7172?
I recommend an Elkay stainless steel sink. The drain is not offset the way the Americast drain is, but that shouldn't be a problem. Celebrity is the name of their basic line but it is not a cheapo sink. It comes in depths of 7", 10", and 12". The 10" and 12" deep ones are special order. They also have the Pacemaker, and the Lustertone, which is their top line sink.
I don't care for cast iron sinks as they sometimes bleed rust through the caulk, get scratched, and quickly lose ther gloss.
Jan 28, 2016 | Home
Need to purchase cover that is in tud about 5 inches round
Ok I figured out what part you are talking about and it is a dealer part only the link below will put you in touch with American Standard. http://www.americanstandard-us.com/contactUs.aspx
Feb 08, 2011 | American Standard Cambridge 5' Americast...
Americast tub has a scratch
try rubbing some toothpaste over the scratch with your finger you will be amazed
May 08, 2010 | American Standard Cambridge 5' Americast...
Bathtub chips
To fix small porcelain bathtub chips, you can use acrylic nail polish that matches the bathtub color. Just get some fine sand paper to remove any rust, then clean with alcohol, let it dry, and then touch up with the nail polish. Use a hair dryer on high heat to help dry faster, but wait several hours after to use.
Jan 14, 2010 | American Standard Cambridge 5' Americast...
Bathroom sink needs new drain, leaks under counter
Is it a new sink? Most of the time if it's new you'll have to get more pvc pipe because the new tail piece that comes with the new faucets usually is either longer than before or shorter. Yes you can get another tail piece or you may be able to by a longer pvc piece to to hook up the the metal tail piece. Make sure you have the plastic seals inside the pipe where they attach together or it will leak. Once you have it all together close your stopper and fill the sink with water and then pull the sink stopper and watch for leaks if it dont leak then it wont leak.
Dec 30, 2009 | American Standard Cambridge 5' Americast...
How do I remove an American Standard (or Delta?) pop-up drain?
Remove the lift rod and lift up the stopper.
The lift rod is under the sink and one end goes to the lift rod and the other end goes into he base of the plug.
Jul 05, 2009 | American Standard Princeton 2393.202.011...
Is an acrylic sink durable and stainproof?
Acrylic sinks can stain too. I would go with a cast iron sink if you don't want to worry about stains. Acrylic sinks tend to scratch if your not careful.
Mar 13, 2009 | International Thermocast Corp Thermocast...
I HAVE A AMERICAST TUB AND AM WONDERING IF I NED A MOTARBED UNDER THE TUB?
its not a bad idea i always did and never had a problem use strucolite lite weight cement
Feb 22, 2009 | Palm Thermocast Sea High Gloss White Cast...
American Standard SILHOUETTE AMERICAST KITCHEN SINK Single Bowl 4-Hole 7172 Logo
112 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
