Question about Frigidaire ATF6000ES Front Load Washer
Will not spin, just cuts off - Frigidaire ATF6000ES Front Load Washer
    Sergeant:
    Champion:
  • 351 Answers
Maybe door switch
Posted on Oct 03, 2010
Why does spin cycle cut out before hitting max RPM?
G box or timer not staying on long enough
Sep 03, 2015 | Washing Machines
The spin dry of the above mentioned washing machine spin dry not working properly cuts off what parts are required to fix this ?.
If a machine is out of balance when spinning it will shut down---there's an unbalance switch that controls this---also on some machines if not properly set level or feet not touching the floor causing the machine to rock---it will shut down---the remedy for that is to redistribute the clothes then is should resume spinning----another issue could be the timer----out of sequence or jumping ahead during that cycle---has the timer/control ever been wet as this will cause some issues---this is my thoughts on this--good luck
Mar 16, 2015 | Washing Machines
Grasshog GH700 spins but doesn't cut the grass
Most likely the string is not the right size in length and/or diameter.
Check instructions in the user manual available at this site.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90563741,GH700.pdf
Sep 02, 2014 | Garden
2003 mustang when traction control light comes on the car lose power almost like shutting down, when it goes off it pick up speed.
The traction control system DOES cut your engine power when the tires spin. That is by design. The system cuts engine power to stop the wheels spinning and restores power once the wheels regain traction. It feels odd when the tires spin and power cuts out. It's good practice to lift off the accelerator when the system kicks in. Otherwise, if you are on gravel or slick streets the tires may spin, stop when traction control kicks in, and then spin again when power is restored. It is not an "elegant" solution but it does work for the most part.
Apr 03, 2014 | 2003 Ford Mustang
Polan selfpropeled mower the blade is not spinning fast enough and hardly cuts the grass
Blade speed equals engine speed. Check your carburetor and fuel pipe
Make sure you sharpen the blade with - this is more important for a good cut.
Mar 19, 2014 | Garden
Simpson 175 washing machine: spin cycle noisy and motor cuts out after short spin. Bowl feels stiff
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Aug 07, 2010 | Washing Machines
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My amanda washing machine
My amana washing machine will not unlock
Mar 21, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
19 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
