Question about Xerox Office Equipment & Supplies
Scanner is showing error 0x00000015 device not ready on xerox scanner 3229 workstation
  • 3,530 Answers
Error 0X00000015 is caused by damaged windows files or broken system structures. This is a critical problem that can cause an unstable operating system, which is typically caused by improper management of the computer.
Please click on this link for the repair.
Posted on Oct 03, 2010
Workcentre 7242, it was showing 01-333 fault at first but after correction another error 010-319 how can i sort out this error code
Error 010-333 for this machine is "Fuser Center Thermistor Overtemp (Over temperature) or Overheat Error"
Error 010-319 for this machine doesn't seem to exist (Yes - I know you've got it - hence the problem post.)
Error 010-319 for other Workstation models (7655, 7665, 7675, 7755, 7765, 7775) is "Fuser Heat Control problem *NOTE: This code must be cleared from Diagnostic Mode"
As regards fixing this error the Xerox website should be helpful
Feb 16, 2014 | Xerox Office Equipment & Supplies
Error code 0x00000015
Use your Virus scanner. These errors (0x00000015)can be triggered by malware hiding inside your computer.please check your computer for malware. try checking it in safe mode and if that fix it, you may want to try system restore.
Feb 15, 2014 | Canon Pixma MP990 InkJet Printer
Canon pixma mx 700 won't scan showing error code 0x00000015
This is a windows or software error code,Uninstall the scanner/printer software and reinstall from the CD
If you have lost it you may download new drivers from here
http://support-au.canon.com.au/P/search?model=PIXMA%20MX700&filter=0&menu=Download
Aug 16, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Error 0x00000015 tha device is not ready this error showing in dcp7030 prienter help me.......
This problem has something to do with java. Try updating your Java. If the Problem still persists. Try using a Virus scanner. These errors (0x00000015) can be triggered by malware hiding inside your computer. please check your computer for malware.
Apr 20, 2011 | Computers & Internet
Scanner error 15
READ here on HP
http://h30434.www3.hp.com/t5/Scanning-Faxing-and-Copying/Error-0X00000015-The-scanner-is-not-ready/td-p/1106675
Apr 11, 2011 | HP LaserJet M1005 Printer
I am using a Xerox WorkCentre M15i connected to a server via a USB cable. I am trying to configure the scanner so that each user can perform a scan from the workstations without accessing the server...
There is a device called a Pocket Pro that attaches to the machine and you can then hook it via a RJ45 connection. I believe Troy makes that device. I have used it several times with success. Its basically a print server device.
Feb 02, 2010 | Xerox WorkCentre M15i Laser Printer
Error code 2019
Step 1 - Verify the scanner's power and connection
  1. Verify that the scanner is turnned on
  2. If the Check or Ready light on the scanner is flashing, click VIS1023 - Check Light Blinking on ADF Scanner for more information
  3. Check that the USB cable is connected to both the scanner and the computer
    • It is recommended that the scanner be connected directly to the back of your computer with a 6 foot or shorter USB cable
Step 2 - Redetect the scanner in device manager
  1. Turn the scanner off
  2. Click Here and select "Run" or "Open"
  3. The Windows Device Manager will open
  4. Go to "View" and choose "Show Hidden Devices"
  5. Click the "+" next to "Imaging Devices". This will show all Imaging Devices previously and currently connected to the computer.
  6. If listed, right-click on the DocuMate 510 then left click on "Uninstall"
  7. If asked to confirm the uninstall, click "OK"
  8. If the scanner is listed more than one time, uninstall ALL occurrences of the scanner
  9. IF you see "?Other Devices" in the device manager list, click on the "+" to view the list of Other Devices
  10. Right click on any instince of the scanner in this list then left click on "Uninstall"
    The scanner may be listed as any of the following:
    • USB Scanner
    • USB Device
    • Unknown Device
    • DocuMate 510
  11. Once the scanner has been completely removed from Device Manager, turn the scanner back on
If there is no Found New Hardware message when the scanner is turned back on and the scanner is not listed in Device Manager under Imaging Devices or Other Devices, this typically means the scanner is not communicating correctly with the computer. Try plugging the scanner into a different USB port or using a different USB cable.
Jan 08, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Error code 14-372 after power on
Chain 14 has to do with the scanner not passing self test, not comming to ready.
CCD Module, exposure lamp or one of the scanner baords.
Jan 03, 2008 | Xerox DocuColor 12 Printer
3,285 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
