Question about GE Profile Prodigy WPSE4200A
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
    Sergeant:
    Champion:
  • 351 Answers
Belt loose or bad
Posted on Oct 03, 2010
  • GE Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
My washer tends to have difficulty spinning if the load is too heavy and it is really loud when it does decide it will work. It works well with smaller loads but when i try to wash more than just a few...
Your load drum bearings appear to be in the process of seizing, thus putting excessive load on the drive motor and this causes it to trip its self out
Jun 24, 2010 | GE Profile Prodigy WPSE4200A
Washer only spins
Have you tried to unplug the machine, sometimes the control boards can get stuck and if you unplug it for say 30 seconds then plug it back in, it may reset itself. otherwise you may have to call someone these are very complicated machines.
Jun 19, 2009 | GE Profile Prodigy WPSE4200A
GE Top Loader Model WASE422OAOWW Profile Prodigy
you have a motor issue, do not run the machine. ther is a risk of fire.
May 26, 2009 | GE Profile Prodigy WPSE4200A
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
Ge washer # WBVH6240FWW
We have a GE washing machine that works fine with no load, but will not finish the cycle with a full load.
Aug 15, 2008 | GE Profile Prodigy WPSE4200A
Spin doesn't work...
THE WASHER HAS 2 CLIPS IN THE FRONT. Use A butter knife or puddy knife and push them back then pull the front off a flashlight will help you find the retainer clips
Mar 31, 2008 | GE Profile Prodigy WPSE4200A
Wierd smell from washer
If the machine will run in wash but not in rinse then I would check the motor first. If the motor is getting too hot toward the end of the wash cycle it may very well have a fault in the foward windings. When in the spin mode the motor is reversed so may continue to operate.
Jan 12, 2008 | GE Profile Prodigy WPSE4200A
Spin and Agitate problem on GE Profile Prodigy WPSE4200A
This machine uses an electric water pump. I would check to motor. Remove the front panel and operate the machine to see if the motor is working. Check this by listening to the motor and watching the belt. If you hear the motor but the belt does'nt move then there may be a problem with the pulley or motor clutch assy.
As far as not draining or pumping water ? Check the wiring from the pump to the control panel. If these wires are alright then i suspect the pump.
Nov 15, 2007 | GE Profile Prodigy WPSE4200A
Will not drain during spin???
Most likely your outlet filter of the machine is choked with dirt or something; clean out the filter & refit. Of course after taking of the wall plug & siphoning out the water from washer.
Sep 21, 2006 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
487 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
