Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer picks up multiple sheets to print on when it has been directed to print one copy
  • 33 Answers
Clean the separation pad and pick up roller, use cotton and alcohol. Reinstall the driver and set as default setting.
Posted on Oct 03, 2010
My HP5200 13.20.00 Paper Jam
sounds like your fuser sensor or the fuser is bad
Jul 28, 2017 | HP LaserJet 5200 Printer
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
My printer pulls multiple sheets at once.
yo have to:
1. Clear paper pick up roller whit wet cloth or alcohol
2. Clear separation pad (located under pick up roller) using same way as pick up roller.
Good luck
Jun 18, 2010 | Samsung ML 2010 Laser Printer
When paper is feeding into the printer it takes to many pieces
If the printer is picking up multiple sheets of paper, follow the recommendations below:
  • Keep more than 10 sheets in the In tray.
  • Ensure media is not loaded too far and extending past the In tray.
  • Store all media in a dry, cool place. Humid climates will see this issue more often.
  • Do not print on media that has already been printed on. The dampness of the ink will cause pages to stick together.
If the printer continues to pick up multiple sheets of paper, follow the following troubleshooting steps below:
  1. Remove the media from the In tray.
  2. Fan the edges, re-square the media, and reload the media properly into the In tray.
  3. Slide the paper width guide to the right until it stops at the edge of the media, then push the paper length guide towards the paper until it stops.
  4. NOTE: Not all HP Deskjet printers have rear access doors. Skip this step if your printer does not have a rear-access door. Remove the rear-access door (if applicable) and clean the internal rubber rollers with a soft lintfree cloth moistened with distilled water. Wait until the rubber rollers dry and replace the rear access door.
  5. Verify that the correct media size and type is selected in the printer settings along with the appropriate quality.
  6. If this issue still persists, try a different type of paper.
Aug 26, 2009 | HP Deskjet D1455 InkJet Printer
The bypass tray is contantly jamming when we try to print.
Hi, i'd start with cleaning any rubber rollers in the paper path, if its picking multiple sheets and then jamming, it will need a pick roller and seperation pad, hope this is helpful ,M.
Jul 03, 2009 | Ricoh Aficio SP C811DN-DL Printer
My printer will not print anything black. I have replaced the black ink cartridge multiple times yet it is still not printing. The printer thinks that it is working properly, and i know that my computer is...
Kodak EasyShare 5000 series
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
If so, You have to contact Kodak to be sent a new printhead to fix the problem. You click through the support on Kodak and then they automatically send out a new print head. To get the link to this on-line support chat with the live tech support and they can direct you where to go to find this solution.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Mar 07, 2009 | HP LaserJet 3015 All-In-One Printer
Hp 4345 printer that is picking up multiple sheets from tray2
Frankly speaking, this problem exists and printer companies always have denied this. What I think from my experience that there is some engineering problem with all these printer, in the way paper is fed in.Still I give some solution which HP's site suggests. See if it works in your case:
Issue Multiple pages feed through the printer when printing. Solution If the printer is picking up multiple sheets of paper, follow the recommendations below:
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=gb&dlc=en&docname=c00190540
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Jan 26, 2009 | Office Equipment & Supplies
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
