Question about Sony Handycam DCR-TRV350 Digital Camcorder
The tape will not come out. The eject cursor keeps blinking and beeping when on.
    Genius:
  • 1,812 Answers
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Oct 03, 2010
Hi my sony CCD-TRV57E keeps ejecting the tape, and
My SONY CCD-TRV57E isn't recording or any function.seem to be working. Bty ok. In view finder I'm getting "SP C:31:22" also a symbol like and inverted coathanger with a line thru it and a + sign on top.
May 15, 2010 | Canon ZR80 Mini DV Digital Camcorder
The tape will not eject, battery is charged, help! Thank you!
Unplug battery and reattach it again, then try to eject the tape.
If problem still exist and camera shows error code "C:..:.." and beeps then it is problem of tape mechanism.
Dec 13, 2008 | Sony Handycam DCR-TRV50 Mini DV Digital...
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Sony Handycam DCR-HC32 Not Working, Not Ejecting Tape, LCD Flicker
DCR-HC32 need new tape mechanism as shown in below exploded view.
Its part number is as follows..
A-1082-424-A MD (Z210) SUB ASSY
Nov 06, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Eject tape message
We get the eject message and then it will not eject tape.  Any suggestions
Mar 04, 2008 | Canon GL1 Mini DV Digital Camcorder
High pitched noise, then ejects tape
Hi friends. (Excuse my poor English). Well, i bought a SCD364 Samsung CamCoder that is physically and mechanically exactly as scd363. My scd364 also have the same problem. Because the warranty has expired, i discovered a solution. The problem ocurs due to a missing calibrati?n at tape motion mechanism then when the cam goes heat, the motor grazes with another part of the mechanism that this located very near (wax)causing a metallic noise, eating the battery and, finally the blinking "D" eject signal. I amazing when discovered that the solution is to open the tape compartment and place the opened camera infront of the air conditioning machine by 2 minutes in order to cool it. Once cold, the camera is ready to play or record again without noise and blinking "D".
Jun 04, 2007 | Samsung SC-D365 Mini DV Digital Camcorder
Ejects Tape after high pitched noise
A beeping noise goes off, when i put in a tape, like it starts beeping then ejects it out, and the screen shows "remove casset", ive already tried the dry video head cleaners, but it ejects that tape back...
Does the unit say anything about moisture? This sounds like a moisture fault. Leave the unit open for a day in a dry area and try it. If it is moisture and everything is OK this should solve your problem. If it doesn't solve your problem you could have a bad moisture detector. This is a small square metal looking device near the video drum with two wires hooked to it. It's job is to protect the camcorder and keep it from damaging tapes when moisture is present in the unit. The simplist way to verify if it is defective is to jump a wire across the two connections and try the unit. If it works this is your problem and you will need it replaced. A good repair shop should be able to do it for about $50 US. Two websites which give free estimates are http://www.videotech.com and http://www.camcorderrepair.com Good luck.
Jun 16, 2006 | Canon ZR100 Mini DV Digital Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
21 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
