Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Kenmore side by side with ice/water in the door
My kenmore frig is defrosting after 24 hours of changing a bad relay. what else could my problem be?
    Scholar:
  • 42 Answers
Hello Mike,
I need more information. What model # do you have. If the model # starts with 596, you most likely have a locked up compressor. Give me a little more information on what sounds you may hear or anything else you may notice about the running of the refrigeratior. Age?
Posted on May 27, 2008
I saw your response to another Kenmore frig and I have a similar problem I want to ask you about. I have a Side-by-side Kenmore frig(model 106.9555722) that we've had for 16 years!! Other than r
I have seen this one other time in all my years of appliance repair and changing out the "water inlet valve" corrected the problem. I don't have an answer to why it did, but it did. Here is the valve for your unit.
After you change the valve be sure to purge the water line for a good 5 - 10 mins to get all the nasty water out. Keep me posted!
Nov 24, 2012 | Kenmore Side by Side Refrigerator
GE Profile French door fridge. Water collecting below the bottom tray in the refrigerator. In addition some of the vents in the back panel are iced up. What causes this and how can I fix? Thanks
Sounds like your drain line is frozen. Every 6-8 hours your frig goes on defrost and takes the ice off the evaporator coil (the back panel you have ice on covers the evap coil). Besides the clogged drain you either 1)left the frig open and if you did turn it off for 24 hours or 2)you have a problem with your defrost system (heater, terminator, thermister, and either a defrost timer or board. It could be 1 or all of these and only using a meter will know for sure.
Aug 19, 2011 | GE Profile PSI23NCR Side by Side...
Upper portion (frig not cooling properly) Lower portion (freezer) forming ice on #3 setting.
Is it forming ice or frost? It sounds like an automatic defrost problem. If the freezer frosts up it won't circulate enough air up to the fresh food compartment. Try defrosting it manually for 24 hours by shutting it down and leaving the freezer door open. Afterwards, if it resumes normal operation I would bet that there is something faulty in the defrost circuit, i.e., defrost heater not working or defrost control.
Feb 23, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is icing up on back wall and not keeping food frozen
what is the model i beleave the techincan did not change the defrost thermostart
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have the same problem as most. I have a GE
its sound like your defrost timer is not working a fridge should defrost every 8 hours replace your defrost timer leave your door open to defrost all the ice buld up the timer shoul be located in the back lower where the compressor is located it about 3 sqare inch normally black with a small motor on or some are white in coulours thanks from gilles
Mar 05, 2009 | GE GSS20IEP Side by Side Refrigerator
Freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Aug 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer staying cold but defrosting on Kenmore Refrigerator dripping into bottom frig
I bought kenmore refigerator 21 cu.ft. year ago, but recently on top of freeze door side produces ice would you please tell me what's happen and how to prevent.
Sincerely,
Tim Kao
Jul 09, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice maker not getting water
PULL THE TUBE BEHIND THE ICEMAKER OUT AND SEE INSIDE IF IT IS FROZEN,IF NOT ALL THAT'S WRONG IS THE WATER INLET VALVE ON LOWER BACK OF FRIG.IS BAD,YOU HAVE A WATER DISPENSER HOSE ON ONE SIDE AND A ICEMAKER HOSE ON THE OTHER,THE ICE MAKER SIDE OF THE VALVE IS BAD,THANKS-MIKE
May 29, 2008 | Whirlpool GS5SHGXLS Side by Side...
Relay in kenmore frig
Yes it can. a short in the windings will cause a relay to fail. let me know if you want to make sure it is a compressor
May 26, 2008 | Kenmore Refrigerators
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
130 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
