Question about Mico DVDR311
DVD Player/Recorder DVD tray won't open on the panel it keeps on saying BLOCKED displays blocked on lcd
I need help hooking up my dvd recorder to my cable box and my tv what do i need to do to recored tv programs....
Posted on May 27, 2008
Unplug the machine take out the screws take the top of turn it upside down and a 6 nch bar should fall out don't where it came from. Put it back together and switch it on it should work, well mine did, best of luck. Mike
Posted on Jul 15, 2008
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
Display says BLOCKED and DVD tray wont open anyone any ideas
To open the DVD tray: -
1. Remove Power
2. Invert the player, and look for the slot (about 2.5cm long) near the front of the player under the tray.
3. Shine a light into this slot to locate a white plastic lever
4. Insert a plastic blade an slide the lever to the opposite side of its travel, and the tray will start to open
5. Turn the player the right way up and continue to open the tray and remove DVD
NOTE: Depending on what caused the blockage to be reported, they player may or may not revert to normal operation. If like mine there is an underlying fault, then once power is re-applied the fault will still be reported whenever the tray is closed. In this case the motors that operate the tray are inoperative, and I've no didea why. In fact that's what made me read this website. So I hope you have more luck than me.
Regards, D.
Feb 09, 2010 | Philips DVDR70 DVD Recorder
DVD WILL NOT OPEN - DISPLAY SAYS BLOCKED
press and hold stop button on the front panel on the dvd player more then 10 sec.ur palyer will be unlocked
Jan 26, 2010 | Philips DVDR80 DVD Recorder
Philips DVD 723 . the tray is not opening. blocked message comes.
There will be a slotted hole on the underside slide a screw driver across this will manually activate the tray dogleg and will part open the tray for you.
Dec 05, 2009 | Philips DVDR3380/05 DVD Recorder
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
The tray on my Phillips DVDR 3380 won't open. It says blocked or no disc. I have pressed open /close many times but to no avail.I have turned the power off, makes no difference. I have press stop when it...
I have the same problem. What I do is push my hand down firmly on top of the DVD Recorder above the tray and while doing this press the open button. If this doesn't work get a screwdriver and poke it into the sides of the tray and pull it away. I find that the first method works best! XD
Hope This Helps!
Jul 04, 2009 | Philips DVDR3380/05 DVD Recorder
Drawer won't open. Says "blocked".
I had the same problem with a comparable device. It turned out that the drive belt that operates the ejection mechanism wears out or breaks.
To get at it you need to do the following:
1. remove device cover
2. remove the identification cover on the front of the DVD tray. This may be tricky if you can't open the tray. You need to find a way, because otherwise you can't remove the DVD unit, at least not on my unit.
3. remove the DVD unit by detaching the cables and removing four screws.
4. remove the two top screws on the DVD unit
5. remove the front top cover of the DVD unit by pushing the two tabs on the top of the unit, near the front.
6. Now remove the tray, by pulling it out as far as it goes and then pressing two tabs on either side of the tray. These tabs look like this:
7. Now you get at the drive belt. Originally it was black; I replaced it (temporarily) with a red one in the picture below:
8. Now put everything back together.
May 31, 2009 | Philips DVDR3450H DVD Recorder/HDD...
Dvdr tray
You have one of the following problems:
  • The device freezes and does not react anymore to the remote control commands.
  • The DVD is stuck in the tray. Sometimes the message BLOCKED appears.
  • A feature is not available in the menu without any logical reason.
  • A feature of the device does not work (for example start install).
  • There is some problem with the device you cannot solve.
Reset the DVD recorder.
  1. Unplug the mains cord from the mains wall outlet.
  2. Press the POWER/ON button on the DVD recorder itself.
  3. While keeping the POWER/ON button pressed connect the main power cord to the wall outlet again. A message IS TV ON? or a demo message will appear in the display.
  4. Start the first installation process.
Notes:
    1. The settings of the DVD recorder will return to their default settings. Install the DVD recorder as if it came out of the box.
    2. The data on the hard disc will not be affected.
Apr 28, 2009 | Philips DVDR7260H DVD Recorder / HDD...
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Blocked dvd tray
The disk inside is most likely jammed. It would be best to take it to a repairman, or you can try to remove it your self.
Jul 14, 2007 | Philips DVDR75 DVD Recorder
Televison & Video Logo
101 people viewed this question
Top Mico Televison & Video Experts
Are you a Mico Televison and Video Expert? Answer questions, earn points and help others
