Question about LG LW20-EV Notebook
I have my laptop hooked up to my Sony LCDTV (using it as a big screen) via HDMI cable, but now the laptop screen doesn't work. I disconnected the HDMI cable and restarted the laptop but the screen comes up blank (not blue, just a grey colour). I hook it back up to the tv and it works fine. What could be wrong?
  • R M
    R M Oct 03, 2010
    what is the make & model number of the computer, and also the make & model number of the LCDTV - thanks
    Master:
  • 397 Answers
Go into your display driver, and make certain you have it set to have the internal LCD as your primary display. There should be an option to go ahead and have it either act as a second display just cloning what's on your screen or to have it extend. (select the option to clone)
Posted on Oct 03, 2010
  • the3skis Oct 03, 2010
    Found this option but it won't save the changes. When I went into the display driver it showed the TV as the primary so like you said I changed it to the laptop (primary) and tv (secondary) and cloned it, then applied it, hit OK and closed out of that portion. Once I go back into it , it has reverted back to tv primary...arrrgh!!!
Can someone please help me get my laptop working through HDMI cable onto TV on a sony VAIO VGN-FW23G. I need to know the process to do this
1. Check the computer for changing output (some computers use <F5>, <F8>, depending on which brand they are. I believe Sony uses <Function><F7> or <F7>).
2. Check what channel the HDMI port is on (e.g. AV1, HDMI1, HDMI2, etc.) - you need to know this if your TV doesn't automatically switch to the new input.
3. Plug the HDMI cable into the TV HDMI cable-in port.
4. Plug the HDMI cable into the laptop HDMI cable-out port.
5. Turn on the computer.
6. Press the <Function><F7> simultaneously ONCE. The screen should flicker and show up on TV.
7. Sometimes you may have to go to "Display Preferences" and select Dual Monitors or external monitor if your computer doesn't do it automatically. Repeat Step 6 after.
** You may have to adjust Display Resolution to 1024 x 768 or lower in order for the TV to work. After it works at a lower display (800 x 600, for example), you can adjust the resolution to the maximum the TV can accept.
Oct 26, 2012 | Fujitsu Computers & Internet
Polaroid tlx-01911c hdmi with laptop says not support!
You either lost HDMI on the TV or the Laptop. The way to tell is hook up the laptop to another set aand see if it works. If it does than the problem is in the Main PCB of your TV.
Apr 10, 2012 | Polaroid TLX-01911C LCD TV
The receiver is hooked up via HDMI and after about
user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
Mar 21, 2010 | Sony STR-DG1000 7.1 Channels Receiver
I am trying to hook up a Sony BDP-S360 via HDMI
I don't know what kind of TV you have, but on some TVs the HDMI inputs have to be enabled via the TV setup menu. Try looking at the setup status.
Dec 27, 2009 | Sony BDP-S360 DVD Player
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
Line going up and down TV when i play ps3?
did you reset the setting in your xmb on your ps3 from hdmi to a/v cables?
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
HDMI Connection
is the hdmi connected to the tv
Apr 09, 2008 | Sony STR-DG510 Receiver
LG LW20-EV Notebook Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
