Older Maytag Dryer: Never had a problem over many years of use. I had selected the air-dry cycle to tumble dry two sweaters. The dryer was working normally when suddenly the dryer bell rang and the Dryer shut down. I reset the door switch and pushed the starter button again and it an alarm buzzer sounded and failed to turn the dryer on. A few minutes later the dryer bell rang as if the load had been completed. I tried different cycle settings to no avail. Just the buzzer and light comes on. No drum action. What could be causing this problem?
Tom D.
sounds like she might be stuck in an econemy mode ,if its digital try to find its reset button,sometimes very small and out of the way,might have to look up the manual on the net to find this tiny button ,good luck
The control unit on the tumble dryer will vary among
different makes and models. The main purpose of the controls is to allow
the user to select the drying cycle. You can choose the time and
temperature setting on most units, while others allow custom settings
such as moisture sensors and end-of-cycle alert signals. The controls
may include a dial or a touch panel and LED screen display. Some tumble
dryers allow you to independently select the appropriate time for the
load you are drying and separate programs for temperature.
Motor
The motor inside the tumble dryer spins the basket to allow
the clothes to tumble while being dried. The tumbling action allows the
air to pass through the clothing to dry them faster. Heating laundry
that is stagnant will likely dry the clothing on the outside while
leaving damp clothing inside the pile. The constant motion, along with
the heat and steam created by heating the clothing, reduces wrinkles.
The motor also powers the fan that delivers the heated air to the basket
of laundry. The heater can be an electrical element or gas powered.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Hi dear.Here is some help from the user manual.I hope that helps.Thanks.
DryingRack To use the drying rack Do not remove the lint screen. 1. Open dryer door.
2. Place drying rack inside dryer drum, positioning the back wire
on the ledge of the inner dryer back panel. Push down on
front edge of drying rack to secure over the lint screen.
3. Put the wet items on top of the rack. Leave space between
the items so air can reach all the surfaces.
NOTE: Do not allow items to hang over the edge of the rack.
4. Close the door.
5. Select a timed drying cycle and temperature, or an air cycle
(see following chart). Items containing foam, rubber, or plastic
must be dried on a clothesline or by using the Air Only
temperature setting.
6. You must select a time by pressing MORE TIME or LESS
TIME. Reset time as needed to complete drying. Refer to the
following table.
7. Press (and hold) HOLD TO START button (about 1 second).
NOTE: You must remove rack for normal tumbling. Do not use
automatic cycles with the drying rack.
This chart shows examples of items that can be rack dried and
the suggested cycle, temperature setting and drying time. Actual
Rack Dry Setting Temp. Time*
Wool Sweaters
Block to shape and lay flat onthe rack.TimedDryLow 60
Stuffed toys or pillows
Cotton or polyester fiber filledTimedDryLow 60
Foam rubber filled
N/A Air Only(noheat)90
Sneakers or canvas shoes N/A Air Only(noheat)90
drying time will depend on the amount of moisture items hold.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
On mine, nothing "clamps down". There are 3 positions in the plastic rack into which you can insert the wire rest - "F", "H", and "A". God knows what they mean (I think the one rack is intended to be used in various dryers, of different depths), but if I use the rearmost position = "A", the back end of the wire rest rests on the non-moving rear of the drum, and the front of the rack rests on the lint screen holder. Seems to work, but the instructions leave a lot to be desired.
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
