Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Error code 31, heater not working, red light flashing
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
There is something wrong with the room sensor. Wires cut, shorted or disconnected.
Tom
Posted on Oct 13, 2010
Carrier furnace 58pav090-14 5 flashing red light, how do I determine which code it is please
The code is read short flashes first then long flashes. 3 short and 1 long would be a 31 code. usually on the door of the unit would be the codes and their explanation
Nov 20, 2017 | Carrier Heating & Cooling
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Why doesn't my Webasto Dual Top RHA 100 heater work?
Try to locate Webasto own fuses then check them and reinsert them. If fail, locate nearest Webasto dealer which capable of reading of Webasto's logical unit's error codes.
Also try to disconnect your motorhome from battery for about an hour.
Oct 05, 2014 | Office Equipment & Supplies
Green light will not come on. red light continues flashing
I have experience in Dolce Gusto melody 3. I think that means that the machine warms up the heater. If it continues giving red flasher, i expect that no electricity reaches to the heater or there is something wrong with the heater sensor. In my machine there is Triac (BTB08-600CW) that drives the heater. Please check and show us what is happen.
Dec 30, 2013 | De'Longhi EDG200T Nescafe Dolce Gusto...
Pentair heater will not light
This could be a temperature sensor issue, however you should open the panel and look at the ignition control module, there is a red light that will flash and based on the number of flashes it may tell you more information. Open the panel the. Try to fire the heater and watch the light and see which flashing sequence it gives you, post back with that information and we may be able to figure it out
Dec 06, 2013 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
Apr 24, 2010 | Zanussi ZWF10070W Front Load Washer
Clean light keep on flashing
The solution is...press cancel one time and you will see the red light, press another time and the red light will disapear, after press one time on heated dry and after press one time on normal wash after press start and it's suppose to work. For me it was the solution, I hope it will be the same for you.
Apr 05, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
187 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
