Bosch TF 250 hot water service, can not get the pilot light to stay on...
  • Anonymous Jun 08, 2008
    I also found that problem. Iinitiallly a change of batteries helped but the iginition kept firing all the time and the next batteries were empty after two weeks. Eventually new batteries could not fix the problem. Yes it seems that the power supply from the battery 1.5V to the High Voltage converter runs via a thermo couple. But shorting this did not help the ignition problem. How can I check whether the HV converter is broken?
  • Englandrules Mar 16, 2009
    Yep sounds familiar, mine starts intermitently. I've put a ammeter between the feed to the pilot solenoid (green one) and the solenoid valve itself and measured 10mA. I've then removed the solenoid and fed it directly from a 1.5V cell with the same ammeter setup and measured 30mA continuous. I've then put a voltmeter across the battery box and tried to start the heater (turned on the tap). Battery voltage hardly drops at all. I therefore think there must be a transistor in control box with has gone low current gain. To check it I got he missus to turn the water on with me giving a direct 1.5V feed from the battery box to the pilot solenoid and voila! She fired up! Plumbing supplier now want $150 for new controller *!!@
  • 20 Answers
Thre is a sensor thaat goes from the gas valve to the pilot that is called a themocouple change that and you will have no more problem
Posted on May 27, 2008
FixYa - Bosch tf250 is not an air conditioner, it is a instantaneous gas hot water service...
Posted on Nov 26, 2011
  • Robyn Sprod Nov 26, 2011
Pilot light wont stay lit once button is released unit is about 11 years old
call your plumber and have it serviced possibly just needs the thermocouple replaced .
Dec 28, 2015 | Bosch & Tankless LP Hot Water Heater
My fathers Bosch water wizard tf 250 will not start. the water will flow but no gas will not ignite or come through the pipe to the heater. the gas bottle is full. thanks Dave Tooley
Dave, make sure that the gas valve on the Propane tank, is fully open and that the inline gas shutoff valve near the heater is turned ON. Those are the basic two things that would prevent the gas from flowing thru the gas line, to the heater.
If the above valves are ON, the problem then lies with the gas control valve on the water heater. If it has pilot light that has to be lit, make sure that the heater's gas control valve is properly in the PILOT Position, before attempting to light it. It must be able to be pushed ALL the way in and you should feel strong pressure pushing back at you (other than spring pressure). When you feel that, it's in the PILOT Position and ready to be lit. Once it's lit, continue to hold the Pilot Button in for 1 minute, then release it. If the Pilot stays lit, turn it to the ON Position.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 22, 2011 | Heating & Cooling
I have a Bosch Water Wizard 10P - have no hot water, no water comes out the hot water tap, can't light Pilot Light, not sure where to start would love a step by step diagram how to start pilot light -...
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Before calling service technician, read manual for fault finding and possible solutions.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch_water-wizard.pdf
http://waterheatertimer.org/pdf/Bosch_13P_16P_In.pdf
Following links talk about keeping pilot lit, and describe location somewhat. Bosch water wizard has standing pilot light.
http://www.fixya.com/support/t2961646-water_wizard_10p_pilot_light_keeps_going
http://www.fixya.com/support/t2960079-bosh_water_wizard_10p_pilot_light_keeps
http://www.fixya.com/support/t6182021-bosch_10p_tankless_hot_water
1) The manual does not show diagrams you asked for.
2) Website that sells Bosch parts does not show parts for water wizard, nor does Bosch site for parts: Instruction manual says: replace pilot injector
http://www.boschhotwater.com/HelpfulResources/PurchaseParts/tabid/837/Default.aspx
http://www.houseneeds.com/shop/heatingproducts/waterheating/parts/bosch2400espartsbuy.asp#
3) Searching "pilot injector for Bosch Water wizard" turns up fixya questions which is generally bad news for do-it-yourselfer because it means information sources are through service technician.
4) As a general rule, tankless are not do-it-yourself repairs or installation because they are affected by so many internal and external factors, including air quality, air flow, venting, other gas appliances, gas pressure, gas supply, water pressure, water flow, plumbing problems, water quality, plus internal parts and including any combination of things listed above..
Replacement parts each come will disclaimer.
Add a comment with your experience so others with same-similar problem can benefit.
Send some photos so the internet can see the problem.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 03, 2011 | Bosch & Tankless LP Hot Water Heater
TF-250 Boschs water heater is not producing any hot water. Pilot light is on but the ignition for the burners will not work. Is there a simple solution to this problem without replacing any parts?
I don't know. Tankless problem can be internal and external factors, or combination of factors, and vary by model, and brand.
For example low gas pressure, or gas valve partially closed (gas handle should be parallel to gas line), gas line should be 3/4", venting could be issue, or failed sensor, or gas control, or circuit board.
Below are Bosch resources.
Bosch website is model for helpfulness and easy navigation.
BOSCH:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Bosch problems at Fixya:
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
Add a comment for more free help.
Mar 06, 2011 | Bosch Water Heaters
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
What's up with My Bosch Hot water heater??
it sounds like a thermocoupler
its located inside the unit next to the pilot flame and should be screwed in next to the pilot button at the other end
May 28, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
No hot water
If the pilot light stays on, the thermocouple and pilot flame are good. If you turn the control to "on" and turn up the thermostatic control knob to call for heating and get nothing else then the control (gas valve, thermostatic control) is bad. The control can be replaced - they are mostly generic except for gas type - but they are not cheap and if the control is bad the tank is probably not far behind (changing the control could cause it to leak). Unless the water heater is less than 3-5 years old, replace the whole thing!
Please rate my answer!
Mar 18, 2009 | Bosch Water Heaters
Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Jan 25, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosck Water Wizard not getting hot
Bosch 780 main burner is not starting when tap is turned on. Pilot is working
Jun 13, 2008 | Heating & Cooling
Heating & Cooling Logo
1,164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
