Question about Breville Kitchen Appliances - Others
I have a breville muffin magic which stopped working. I traced it to the microtemp g4a00 and removed it. is that dangerous?
That is a temperature sensitive thermo-fuse. It is set to cut off power if the device's temperature goes past the point the design engineers decided it would be dangerous at (typically a temperature followed by a "c" for celsius printed on the fuse). Without it, you usually won't get any power / heat. Short circuiting it with another wire could be dangerous. If the coil/thermo couple/heating element should go haywire (say, grossly overheat), there would be nothing to stop it from an assortment of bad things (fire, burns, melting insulation and plastic, etc). Very bad ju-ju. It typically indicates that some other part of the device has gone bad or shorted (heat element, etc). If you replace the fuse (a dollar at Fry's electronics) and it works, you're in business. If not, then your heating element or some other component is shorting or fried (often just as pricy as a spare part as for a whole new appliance). If it works, then it was just worn out or spiked or something, and you can keep on trucking. Realize that the fuses are sensitive. If you're soldering, use a proper electronics soldering iron with adjustable temp and a fine tip, proper solder, and use heat sinks to either side of the fuse (NTE replacement parts have the instructions inside & should explain this). An electronic store could help you, although if you have to invest $75+ for eqpt to fix it, perhaps you might just want to ask your local adult ed center, jr. college or high school electronics teacher for help soldering. Good project. If it simply uses crimped blade connectors, that's easy to buy & fix.
Posted on Dec 07, 2010
Testimonial: "thank you very much. very helpful. : )"
I am looking for a copy of the Breville Muffin Magic Maker MFM50XL Manual or user guide please.
I have the manual...all that's left of the unit after it stopped working. I can send you the manual OR you could sell me your muffin maker. ;)
Aug 29, 2011 | Microwave Ovens
The damn cakes and muffins for the easy rise oven will not rise for me oh yeah and where do I find the cake and additional cupcake accessories for this toy in canada
The muffin is controlled by using magnets. Get any magnet and put it on the bottom part of the muffin and the muffin should inflate. If not, you can remove the bottom plate on the bottom and manually remove the plunger inside.
Mar 17, 2011 | Disney Princess Magic Rise Oven
I need a couple microtemp fuses 240 degrees C G4A00 for the wolfgang puck swivel waffle maker.
Radio Shack has a 228C and a 262C.
Google '240C thermal fuse' for online purchasing.
If you live near an urban area, try an appliance repair facility or electronics supply.
Feb 28, 2011 | Vacuums
WEAR CAN I GET A BREVILLE MF-M5OXL MUFFIN MAGIC MACHINE
Try ebay
Lots of choice there, or browse brevilles web site for a dealer.
Jan 10, 2011 | Microwave Ovens
Have a Breville Ikon Panini Press ... doesn't work
First point of call would be to check the microtemp, which is the small heat regulating fuse inside. If that has blown, you most likely will have no power.
Otherwise call you local Breville Service Centre. If you're in Australia you'll find them at http://www.breville.com.au/care_agentsearch.asp
NOTE: In Australia, this model has a Two year product guarantee. Check your receipt as it may be under warranty!
May 19, 2010 | Breville 800 Class 800GR Indoor Grill
My gr31sb grill wont heat up, i found the microtemp g4 thermal fuse is bad by by passing it and the grill works. how do i get a new fuse?
Don't know if this helps but Radio Shack has Microtemp 10 amp G4A00 Tf 144c (144 deg Celcius) Thermal Fuses. These are the ones with the little red conical end on them. Under $2 each. I needed one to put in my toaster oven. Couldn't find the small metal clips to attach it to the wiring though. Since it is very diffucult to solder these without damaging the fuse, I'll have to recycle the old clips.
Jul 24, 2009 | George Foreman GR31SB Indoor Grill
Blown microtemp fuse
Hi man, take a look here" http://www.tod.com/productdetail.asp?ProductID=30. I think u know what to do next ...
Apr 08, 2009 | Toastmaster TOV200 Toaster Oven with...
Kitchen Appliances - Others Logo
422 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
