Question about Frigidaire GLTF2940F Front Load Washer
Pump works intermittenly,grinds and chugs - Frigidaire GLTF2940F Front Load Washer
    Sergeant:
    Champion:
  • 351 Answers
May have someting in it
Posted on Oct 03, 2010
Pentair minimax heater works but why is it making a chugging sound?
sounds like you have air in the system u will need to bleed it out while the pump is running.
May 23, 2014 | Pentair Minimax NT Heater
Pentair Minimax Heater - Why is it chugging?
sounds like you have air in the system. locate a bleed point and with the pump running open the valve and try and bleed all of the air out of the system.
I have a 92 GMC Sierra 5.7l and it barely runs and the tachometer is all over the place.
Pull the distrubitor cap and check for any side to side play at the rotor shaft,a little up and down is ok but any side to side makes the magnet hit the pickup. The top bushings are prone to failure .
Jan 29, 2014 | GMC Cars & Trucks
I have a timing problem. Low idle speed that is intermitten and causes a stumble at starts. This problem also occurres during normal running RPM's. Missing electronic signal but intermitten?
Could be bad sensor whether crank sensor, sam sensor, idle air control sensor, bad ignition module, bad coil or even timing belt. if you have a service engine soon light/creck engine light it's more than likely a sensor. If no light, probably timing belt/fuel filter plugged/ or weak fuel pump.
Jan 17, 2013 | 1995 Toyota Camry
2003 Lincoln Navigator starter grinding when starting
If you mean the starter grinds from time to time and won't crank the engine when it happens, the problem could be a bad spot on the flywheel and/or a faulty starter. The starter uses a magnet and bendix gear to push the starter gear into the flywheel. If the magnet or bendix is weak, the gear will not engage and can damage the teeth on the flywheel.
You need to have the starter removed and check the flywheel teeth for damage.
Aug 03, 2012 | 2003 Lincoln Navigator
My 2001 VW Golf will not turn over when it is started or it will chug a couple of times and then stop. It seems to be more tempermental when the weather is rainy and/or damp. FYI...it has 102000 miles on...
It is tough to tell without looking at the engine, but I would recommend checking your spark plugs. If you hear a chugging, at least you know that your fuel pump is working. The gas sounds like it is not being ignited properly. Hope this helps!
Apr 19, 2011 | 2001 Volkswagen Golf
My car will start and run for about 1/2 hr then it will chug and stall. It will not start again until it sits for about 1 hr. Added fuel injector cleaner but problem still there. I can hear the fuel pump...
you say you can hear the fuel pump working is that shortly after when it quits running you hear it or when it starts and runs,fuel pumps will work sometimes until it gets hot then it seizes until it cools off then there is enough clearance for it to work until it gets hot again.the chugging you mentioned sounds like it is running out of fuel.
Mar 09, 2011 | 1998 Plymouth Breeze
Pump works intermittently on LG T753A washing machine.
replace pump drain pump is using postive row of magnets to push against a row of negative magnets if any of those magnets internally crack or align a bad magnet unit will intermittenly not drain out replace drain pump
Jan 23, 2011 | Washing Machines
Car stalled. restarted and did a
try blowing out all the fule lines and changing the fule filters the lines may be blocked up also check the fule tank vent if this is blocked the pump cant **** fule from it
Mar 07, 2010 | 2000 Dodge Intrepid
Frigidaire GLTF2940F Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
