Question about Shotzoom Software Golfshot
I just bought Golfshot GPS & it won't show "Near by Facilities" says "access to location denied" how can I fix this ?
Golfshot gps access to location denied
Many thanks for your mail. Meanwhile I found the solution to my problem: I suspected from the beginning that this had something to do with "Location Services". Therefore I did Settings -> Privacy-> Location Services on my iPhone. I then noticed that GolfShot was set OFF. I just had to re-set it to ON (after enabling "Restrictions" function).
Sep 19, 2012 | Shotzoom Software GolfshotGolf GPS
How do you reload golfshot app on iPhone?
As long as you are still using the same iTunes account you can re-download the app for free from the app store. Go to updates and select Purchased. Scroll through the list to find the app you'd like to download.
Apr 03, 2012 | Apple iPhone Smartphone
How i fix msdc write sector error in memory card..........
sir i have a 2gb memory card but its not be deleted then i try to delete this , after loading show this message MSDC wright sector error, & then moved any file then show this message "access denied" please help me.
Dec 17, 2010 | Electronics - Others
Gps won,t move from last location
When you put in a new location how are you entering it? If you are using the "Where to?" menu then you will need to click on the "Map" button instead of GO when you find the point you are looking for, may it be an address or a Point of Interest. This will show the location on the map. If you want that to be your current location you must have the GPS turned off. Then on some units you will Have the option to set as your current location.
I hope this was some help.
Cheers
Jul 14, 2010 | Garmin StreetPilot C330 GPS Receiver
My HP W1907 monitor needs a driver update. Told access is denied
yes the monitor bad , which means your lcd lamps gone ....
May 09, 2010 | HP w1907 LCD Monitor
Tomtom XL GPS shows an incorrect home location
change it through your gps
where you set favourites or home
it obviously did'nt set your correct settings through the map
make sure home settings on system itself are correct such as country city etc
Jan 06, 2009 | Tomtom One XL GPS Receiver
SQL Server does not exist or access denied
check your firewall or the sql server machine firewall.
Jan 06, 2009 | Microsoft SQL Server 2005 Standard Edition
My 320GB External hard drive is showing access denied when I click on it.
the file you need is called takeownership you have to google for it as it's in one of the forums the file is in the form of a zip file and when extracted you select the takeownership and install a little code into your reg and when you select a folder right mouse button on it and select takeownership this willl get rid of access denied garbage and give you full control over the folder and you do the same on any hard drive.
hope this will solve problems of access denied
Nov 02, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Copying files to the Garmin nuvi 610T
The pin should not be necessary if you are operating your garmin in your 'secure location' that you established when you enabled the garmin lock feature.
How are you accessing the device?
Jan 08, 2008 | Garmin Nuvi 610 GPS Receiver
Shotzoom Software Golfshot Logo
334 people viewed this question
Top Shotzoom Software Apps Experts
Erin Wood
Erin Wood
Are you a Shotzoom Software App Expert? Answer questions, earn points and help others
