Question about HP LaserJet 3050 All-In-One Printer
Paper jam in 3050 laser jet printer. How do I fix the problem?
  • HP Master
  • 7,733 Answers
Did you tyr to remove the JAM paper? or is a error code?
Posted on Oct 03, 2010
2 Suggested Answers
  • 10406 Answers
SOURCE: hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Posted on Dec 13, 2009
My HP color Laser Jet 2600 printer has a paper jam
Jul 21, 2014 | HP Office Equipment & Supplies
Cartige area jam in hp laserjet m1522nf
Open the cover and remove the toner cartridge, check to see if there is any paper or bits of paper along the path (check on the back as well).
Dec 30, 2013 | HP LaserJet 3050 All-In-One Printer
Feeder jam hp 3050 laser Print
Fisrt check if there damage or strange in the path of paper or , remove paper then with Wet clean pack up roller ,if you alcohol spary ,use it to clean rubber , hope help you
Mohamed Hejazi
Afaqnama - LIbya
ipg@hplibya.com
Feb 19, 2013 | HP LaserJet 3050 All-In-One Printer
Hp laser jet 5025 paper jam
Clear the paper jam...
Also make sure all the pick up rollers are not smooth, if they are replace them. Also make sure the tray is set to the right paper and not offset. A lot of times people slam the tray and it moves the setting bar.
Jul 09, 2012 | HP LaserJet M5025 Printer
Cartrige jam how do i fix
  • Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.
  • Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
  • If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
  • Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.
  • If you have a laser printer, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
  • If you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available at electronics shops or drugstores).
  • Try changing the toner or ink cartridge.
  • If you hear a clinking sound during printing, your printer probably has a broken gear and needs to be serviced by a technician.
Please rate my response!!
Jan 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
My laser jet just stopped printing. the symbol
indicate paper jam light but not paper jam in it , some times it it works what shall i do
Dec 16, 2009 | HP LaserJet P2015dn Printer
No paper pickup
Hi damodarbk:
it sounds like you need to replace the paper feed rollers.
pdouglasss
Jan 03, 2009 | HP LaserJet 3050 All-In-One Printer
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050 No paper pickup
My printer now spits out the paper all over the place and jams up all the time. Did not happen when I first got my 3050 a few months ago.
Jun 06, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
250 people viewed this question
Seeker5211
Seeker5211
