What steps do I need to take to do a pc refresh
    Guru:
  • 1,082 Answers
You need your restore CDs or a restore partition. Check your computer documentation on how to do it.
Posted on Oct 03, 2010
How do i do a hard reset on my ematic ewt716. i downloaded windows 10 and now the keyboard wont work so i can put n the password.
To reset the device follow the steps below:
In the Settings Charm, tap on Change PC Settings. Tap on Update and recovery. Tap Recovery. Tap on Update and recovery. Tap Recovery.
. Choose how you want to refresh the tablet. Choose "Remove everything and reinstall Windows.
Refresh/Reset
Refresh Device
Jan 24, 2016 | Computers & Internet
My screen keeps flickering and its only two weeks old
Step 1 Change the refresh rate to match the capabilities of your monitor. The refresh rate is a measurement of how many times the screen redraws each second. Although this setting is related to older, desktop monitors, it can affect the quality of the Liquid Crystal Displays found in laptops. Right-click the desktop and choose "Screen Resolution," then click "Advanced Settings" and "Monitor." If enabled, place a check beside "Hide Modes That This Monitor Cannot Display" and choose a higher refresh rate from the list.
Step 2
Update your graphics card drivers. This is the most likely cause if you've always had a problem with flicker. Look for "Hardware and Sound" in the Control Panel and click "Device Manager." Under "Display Adapters," you'll see the exact brand and model of your video card. Go to the manufacturer's driver Web page and search for this model to download the appropriate drivers. Alternatively, you can revert to an older driver if the flicker began immediately after an update. In this case, return to the Device Manager, right-click your adapter and then "Driver." Click "Roll Back Driver" and "Yes" to confirm.
Step 3 Turn on Vertical Sync if the flicker occurs when DirectX or OpenGL is in use, for example, while playing a PC game. Vertical Sync, or VSync, locks the refresh rate of the application to the refresh rate of the monitor. Horizontal flicker is reduced, which improves image quality. For Nvidia cards, VSync is found in "Manage 3D Settings." For Intel, look for "3D Settings" or "Asynchronous Flip." On ATI/AMD cards, turn on "Wait for Vertical Refresh."
Step 4
Lower and raise the laptop screen repeatedly to determine if the flicker is related to movement. Hardware failure is the likely cause when flicker occurs only when the laptop moves. Most likely, the screen cable is loose or damaged, but the inverter and backlight can also cause this problem. The laptop needs to be opened in order to confirm the problem, but do not attempt this unless you are familiar with PC repair and do not mind voiding the warranty. For the best results, take the laptop to a licensed technician or send it back to the manufacturer.
Apr 20, 2015 | Computers & Internet
Reset my w10 pro.
Step 1: Make sure Surface is shut down and plugged in. Step 2: Insert the USB recovery drive into the USB port on Surface. Step 3: Press and hold the volume-down button while you press and release the power button. Step 4: When the Surface logo appears, release the volume-down button. Step 5: When prompted, select the language and keyboard layout you want. Step 6: Tap or click Troubleshoot, tap or click Refresh your PC, then tap or click the target operating system you wish to refresh. Step 7: On the Refresh your PC screen, tap or click Next, then tap or click Refresh.
Surface restarts and the Surface logo displays while the refresh process completes (this can take several minutes).
Feb 01, 2015 | Computers & Internet
How can I change the time between auto refreshes?
You can't do anything about this website because is design in such a that it keeps on updating every time.
To read full then you can try the Full Score board.
Aug 06, 2012 | ESPN EMEA ESPN Cricinfo
"Windows has encountered a problem
Symptoms
Consider the following scenario:
  • You have Windows 8 or Windows 8 Pro installed on your PC.
  • Your PC fails to boot into Windows and launches Automatic Repair to attempt to repair Windows.
  • Automatic Repair is unable to repair your PC and you select "Advanced options".
  • After selecting "Troubleshoot", you choose to either "Refresh your PC" or "Reset your PC".
In this scenario, recovery may fail and you are returned back to the main WinRE screen.
Cause
This issue may occur if the System or Software registry hives have become damaged or corrupted.
Resolution
To attempt to resolve this issue, follow the steps below.
NOTE: Following these steps should only be used if you are attempting to use the "Refresh your PC" or "Reset your PC" options in Windows RE because your system is in a non-bootable state.
  1. After Automatic Repair fails to repair your PC, select "Advanced options" and then "Troubleshoot".
  2. Select "Advanced options" and then select "Command Prompt".
  3. If prompted, enter in the password for the user name.
  4. At the Command Prompt, go to the \windows\system32\config folder by typing the following command: cd %windir%\system32\config.
  5. Rename the System and Software registry hives to System.001 and Software.001 by using the following commands:
    ren system system.001ren software software.001
    NOTE: Renaming the Software hive will not allow you to use the "Refresh your PC" option. If you want to use the "Refresh your PC" option, only rename the System hive. If the Software hive is also corrupt, you may not be able to use the "Refresh your PC" option.
  6. Type "exit" without the quotes to exit the Command Prompt and reboot the PC back to the Automatic Repair screen.
  7. After selecting "Advanced options" and then "Troubleshoot", select either "Refresh your PC" or "Reset your PC".
More Information
Using the "Reset your PC" option will remove all of the files on your hard drive and resets your PC back to the version of Windows 8 that was preinstalled by the OEM on your PC. All new applications that were installed on your PC after you purchased it will need to be reinstalled.
Apr 12, 2017 | Acer Aspire 5745-5425 Notebook
I have an LT Series Gateway Netbook. I am trying to connect to a Sony VPL-AW15. I am using a Sony STR-K7000 A/V receiver. The projector is giving the error message "Frequency out of range". I have...
HEy try changing the refresh rate
1. Right click on a empty space on the desktop and click on Screen Resolution. (See screenshot below)
2. Select the monitor Display you want to change the screen refresh rate for. (See screenshot below step 3)
NOTE: You will only be able to select a different display if you have more than one monitor connected.
3. Click on the Advanced settings link. (See screenshot below)
4. To Change Only the Screen Refresh Rate -
A) Click on the Monitor tab. (See screenshot below step 4C)
B) Select an available Screen refesh rate from the drop down menu.
WARNING: It is recommended to leave the Hide modes that this monitor cannot display box checked to prevent possible damage to your monitor.
C) Click on OK. 143d1229784117t-screen-refresh-rate-display-settings-monitor_settings.jpg
D) Go to step 6.
5. To Select from a List of All Display Modes -
A) Click on the Adapter tab, and on the List All Modes button. (See screenshot below) 7331d1238960189t-screen-refresh-rate-display-settings-adapter1.jpg
B) Select the display mode with the screen resolution, color depth, and screen refresh rate that you want to use, and click on OK. (See screenshot below)
NOTE: It is recommended to use a native screen resolution with a True Color (32-bit) color depth. 7332d1238960189t-screen-refresh-rate-display-settings-adapter2.jpg
C) Click on OK. (See screenshot below step 5A)
6. Click on Yes to confirm the screen refresh rate change. (See screenshot below)
7. Click on OK. (See screenshot below step 3)
Apr 28, 2010 | Lenovo IdeaPad S10e Netbook
I have started the services of print spooler and the fax in discrepancies.. still not printing. says rpc service not available..
RPC is yet another service that you need to enable so that printing will take place.
Usually, when I encountered this printing error while printing a networked printer, I do the following steps (in Win XP):
  1. Open the Control Panel
  2. Open Administrative Tools => Services
  3. Disable the following services in order: (a) Print Spooler (b) Remote Procedure Call (RPC) (c) Remote Procedure Call (RPC) Locator and (d) Server.
  4. Minimize all open windows
  5. Refresh the PC/Laptop by pressing F5
  6. Enable the same services in item 3 in the same order
  7. Refresh PC again
  8. Print.
If the same error re-occurs, restart your computer.
Mar 21, 2010 | Computers & Internet
Cant use my usb
Refresh and reinstall USB Ports Of Your Computer Hello there, the other day i tried refreshing and reinstalling the USB ports on my PC, as some of my connecting devices are not recognized. I present the detailed procedure on refreshing the USB ports.
Let’s go!!
Here are the steps to refresh/reinstall/uninstalling the USB ports on the computer.
The USB port needs to be refreshed to make sure that no other device has captured the USB port of the computer. The Mouse, video camera, your external USB hard disk; what ever it may be.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager Button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external USB hard disk...USB hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main USB devices at the rear end USB port. As they require more power to initiate.
The above steps are for XP operating system. When coming to the matter of Vista, please note the changes below:
1) Right-click Computer icon from the desktop , and then click Properties to open the System Properties window, and then select the Device Manager tab.
2) Click the Plus (+) sign next to Universal Serial Bus Controllers/Root hub.
3) Click the USB Composite Device entry to highlight it, and then click Remove. If a screen appears to confirm the deletion, confirm the deletion.
4) Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
5) A New Hardware found screen may appear, click next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Toshiba Satellite M35X-S311 Notebook
When refreshing data in excell 2007 from web page, position shift
The macro you have is set to create a row upon refresh. You can change this by stepping into the macro and using VB to edit this step.
Mar 15, 2009 | Microsoft Computers & Internet
Keyboard layout
step one
unplug keyboard from machine
step two
try another keyboard
if none of that helps, then you'll need a bios refresh
Nov 01, 2007 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
