Question about Beverage-Air UCR27 Refrigerator
Beverage air ucr27 was working fine when plugged in and checked one day, then few days later went to plug in to use, and it produced heat-unplugged, left for day or two, plugged in again, not making heat now, but coils not getting cold either, compressor making noise-any ideas?
  • Beverage-Air Master
  • 1,253 Answers
I would first check to see of the condenser fan is working and the condenser is clean. Some noisy compressor could be bad but I'd check make some checks first. Let me know if we need to go any further.
Posted on Oct 10, 2010
Ffbm 920w won't cool
It appears that your auto defrosting system (if you have one) is not working. So your evaporator coil is frozen up - all that ice serves as an insulator and not enough cold air is getting down into frig section. Until you replace either the freezer defrost element or the defrost timer all you need to do is unplug for a few hours till it fully defrosts then plug back in - will work fine for a few days at normal internal temps till the ice builds up again.
If your timer and defrost element are both working properly, THEN, you might want to check if you have enough refrigerant in the system - you may have a leak.
Mar 31, 2014 | Avanti FFBM921PS 9.2 cu. ft. Bottom...
2004 900 efi mountain cat no start, seems like no spark
try unplugging the throttle switch to see if its ok. then of course replace...thats a quick sled
Sep 01, 2017 | Arctic Cars & Trucks
My wii will not turn on
Unplug it for a few hours to a day or so, mine did that but afteer i unplugged it then plugged it in a day later it worked again.
Jan 28, 2012 | Nintendo Wii Console
Drove my '99 Stratus through high water & wont start 2 weeks later
If water went over the hood and into your air cleaner there's probably water in your engine. change your oil. Pull your spark plugs, leave them out for a few days to let any water in there dry out. pull your air cleaner, if it's wet, throw it away and get another one. After a few days pour some Marvel Mystery Oil into your spark plug tubes or spray PB Blaster (encase your pistons are rusted to the block)
This may not get it working, if there was water in the engine when your were trying to start it you may have bent the valves, water doesn't compress.
However I would do these things before condemning your engine.
Nov 25, 2011 | Cars & Trucks
Dryer does not turn off, and now no heat, what could it be?
At first blush, it sounds like the timer failed. Try unplugging the dryer, leave it off for several minutes, plug it back in (or turn the breaker on) and try again.
If it doesn't work, it sounds like the timer.
Mar 15, 2010 | Dryers
My Bauknecht dishwasher stopped working
Check all your breakers. Remove the wall plug, count to 20 and plug it back in and count to 5. This will reset it.
Jul 17, 2017 | Bauknecht 24 in. GSFP3988 Built-in...
Maytag wide by side not cooling
no cold, no compression.
Expansion of compressed freon or ammonia (these days) genartes the cold. You need a compressor running, a proper working expansion valve (not frozen in position) and ventilation over heat exchanger to get lost of generated heat from compression.
Thermostat may be broken. Check this with other temperature gauge around.
May 05, 2009 | Maytag MZD2766GES Side by Side...
Dometic DM2862 made in 2007
Heating element is out. They are usually about $40.00 give or take.
Aug 13, 2008 | Dometic RM2652 Refrigerator
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Beverage-Air UCR27 Refrigerator Logo
150 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
