Question about Marantz SR-7200 Receiver
I have Marantz sr 5002, red light is rapidly blinking.
hawkwatcher
  • 67 Answers
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
This unit went into protect either due to overcurrent or dc detect. There is no way to disable protection that Marantz or Authorized servicers are allowed to give out. The early versions of this model all you had to do was unplug for a few minutes then plug back in and unit if it did not have blown amp unit would powerup and work fine. But if amp had failure it may cause more parts to fail so they changed software to not allow users ability to disable protection. Send to Marantz Authorized servicer for them to check for amp failure or mayby they just have to disable Protect Mode.
Posted on Feb 16, 2008
tech48
  • 624 Answers
SOURCE: marantz sr 4200
This is an indication of some bad solder connections on one of the boards. It could be the power supply board, amp board, or the digital board. I would like to be more specific, but this is not a common problem with those symptoms. Bad solder connection are a common problem and can cause many different unusual symptoms. Unless you have excellent soldering skills, it would be best to let a service center repair this for you. This is a very good receiver and is well worth getting fixed. If you have excellent soldering skills and are willing to take a chance on fixing it yourself you could save yourself some money, but be aware that if you make even one mistake while soldering, you could easily cause much more damage than you started with. Some of the components that may need to be resoldered are surface mounted IC's that are very difficult to resolder and if you have never done this before it is not a good idea to start learning how to solder on such a nice receiver.
Let me know if you need any further help.
Dave
Posted on Oct 27, 2008
SOURCE: Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Posted on Nov 04, 2010
I have a SR7001 with that problem. I found 2 shorted amp NPN & PNP transistors. Part #'s SAP17NY & SAP17PY.
Posted on Feb 08, 2011
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Posted on Jun 13, 2011
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Mar 01, 2014 | Marantz SR-7200 Receiver
Is it worth fixing a marantz sr5002?
if it's a blown amp channel, might cost around $150 to repair
Nov 21, 2013 | Marantz SR-7200 Receiver
Sr 5003 is stuck in standby
The reciever has a internal problem, It will have to be taken in to be repaired, It is that simple to figure out, They do not stay in the stand buy mode , Just for something to do,
Nov 26, 2012 | Marantz Sr 5003 Home Theater Receiver 7.1...
Marantz sr5600 reciever click and goes to blinking standby
I have the same problem. Earlier it got sorted out itself and now it has started coming up again.
Feb 26, 2012 | Marantz SR-5600 Receiver
Do have an idiots guide as to how to wire up the SR-4200 to a TV
I will interperate this as:
"So you want to play sound through your Marantz SR-4200?"
You need to clarify what sort of system setup you have, however i will put down a few ways to wire this up to your TV.
If you have a Set-top-box that gets the TV Channels, that is where the sound comes from. If you have a TV that plugs straight into the wall, you will have to get the sound from the TV. Grab a RCA Stereo cable - (White and Red heads, if you don't know what they look like, Google it).
If you are unclear about this, i have tried to make a diagram down the bottom to explain how this is to work. What you will do is Take the sound from the Set-Top-Box or TV and reroute it into your fantastic Marantz SR-4200.
1. Plug Red Plug into the the Red Slot, and White into the White on the back of your set-top-box or TV Out (if you get it around the wrong way, the speakers will be reversed.)
2. Plug the other end of the cable into the back of your Marantz SR-4200 in the TAPE input or VHS input as they are analog signal inputs. Turn on Marantz SR-4200 and turn it onto Tape or Vhs (depending on where you plugged it in).
[Set-Top-Box or TV out] >-------> into >------> [Marantz SR-4200]
If you still don't get it, then try searching You-Tube for a guide "Plug Tv into Stereo". I myself couldn't turn up anything useful
Mar 09, 2010 | Marantz SR-4200 Receiver
Hello there Ed.
Kind regards
Evangelos
Oct 17, 2009 | Marantz SR8001
Marantz SR5001 Rapidly Blinking Standby Light
if u want to sove your problem then contact me on my number 9555503717
Jun 21, 2009 | Marantz SR-7200 Receiver
Jan 21, 2009 | Marantz SR6001
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Marantz SR 5002 Won't power on
I've just been told by my AV person that is a known flaw in the SR5002 that the power supply runs hot, blows out, and sometimes takes out other components by cooking them. Thanks Marantz. How about a recall?
Jun 08, 2008 | Marantz SR-5000
Marantz SR-7200 Receiver Logo
970 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
