Question about Toshiba (MK1516GAP) 15 GB Hard Drive
Hard disk failure for tosiba - Toshiba (MK1516GAP) 15 GB Hard Drive
    Master:
  • 397 Answers
If the hard drive has failed, you will need to replace it- generally contact your system manufacturer/consult your system manufacturer's website to find a drive compatible with your system. If you wish to recover files off of that drive- you may need to contact a data recovery firm- or try putting the drive in a freezer bag, then placing the bag in your freezer for 48hrs- try to recover all you can, because that technique is a last-ditch effort.
Posted on Oct 03, 2010
Free Boot disk for PSLB8U-14F025 Tosiba
You will have to try to get a disk from the hard drive manufacturer
Mar 14, 2013 | Toshiba L305-S5957 (PSLB8U-14F025) PC...
I have a tosiba nb305 tried to partition c drive but I don' get the partition optiion when I right click on the disk management interface
If the hard disk has been partition as a single partition, you do not get an option to create another partition.
the only way to do this is you install Windows again. During the installation process you can delete the single partition and then create two or more partitions and then install Windows on the first partition.
Nov 01, 2010 | Computers & Internet
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
Printer displays c-0096 on display
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
Aug 14, 2009 | Office Equipment & Supplies
How to install window vista in my tosiba satalite L 40 model
hi dear inste Vista CD. boot from CD .. and install.
May 14, 2009 | Computers & Internet
Exterenal harddrive unreadable
Please try it on another computer and see if you get the same results.
Mar 03, 2009 | Toshiba 120GB USB 2.0 Portable External...
Hard drive failure
you should replace with a SATA laptop hard disk....
Feb 10, 2009 | Acer TravelMate 3260-4874 Notebook
When laptop on passward asking
If this is a hard disk password and you do not know it
You can format the pc with your windows cd or recovery cd.
Hope this helps
Jan 12, 2009 | Toshiba Computers & Internet
Tosiba satellite m45
Not sure but I believe the M45-S331 came w/ a standard PATA drive and that could be a problem if you replaced the old drive.
Oct 17, 2008 | Toshiba Satellite M45-S331 Notebook
Smart disk
well you go to
CONTROL PANEL--->ADD NEW HARDWARE--->CLICK NEXT...
And your problem is solved....
if not then again contact me....
i will tell you other method tocheck it in your pc....
reply soon...
Dec 01, 2007 | Computers & Internet
Toshiba (MK1516GAP) 15 GB Hard Drive Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
