Question about InFocus Projector Lamp for LP340, LP340B, LP350
Have Infocus X2 projector. When on a dark shadow line appears down the left side of screen. Could it be a bad lamp?
    Problem Solver:
  • 6 Answers
No it is not lamp problem. it must be light tunnel problem.
after lamp there is tunnel for light travel, made from 4 pieces of mirror.
this tunnel is glued. glue tend to break in time so the tunnel is no longer doing its purpose.
open this part of projector, there should be 2 little screws holding it. repair it by reposition mirrors and glue them from outside by little drop of temperature resistant and elastic glue. that's it !
Posted on Mar 29, 2011
X2 OHP mounted on ceiling fixture. Image is dark on right side
Yes it will have to come off the ceiling. It sounds like the light tunnel has collasped. This is located under the colorwheel. If you can get a new tunnel , be careful removing the colorwheel so no segments break off of it...make sure the new tunnel is pushed against the "lip" before screwing the tunnel clip back into place.
Aug 02, 2010 | InFocus X2 Projector
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
X2 projector A somewhat irregular vertical line has appeared near the middle. A slight rainbow affect at the line, right of the line gets progresively darker. The blank screen is normal. The projector is...
this projector does not have lcd's. it has a colorwheel and a light tunnel. the light tunnel has probably collapsed and needs to be replaced if you have distortion in the middle of the display. if it were to one side or the other or a the top or bottom it may have been adjustable. But wiith it being in the middle, I'd have to say you needed a new light tunnel.
Mar 12, 2010 | InFocus SP-LAMP-018 Projector Lamp for X2,...
I have an infocus X2 projector that has a shadow on one side of the image. After reading other posts, this appears to be indicative of a light tunnel collapse. Is this problem repairable in an X2 and if so...
the light tunnel has collapsed and needs to be replaced. it's pretty simple to repair. there are directions on the "tips" part of my profile. so, you can get the part from an infocus service center and do it yourself or send it in to them for repair. either way, try www.avsolutionsny.com. they're really good.
Jan 29, 2010 | InFocus Office Equipment & Supplies
It has a shadow on half the screen
the light tunnel has collapsed. you can get the part from an infocus service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 18, 2010 | InFocus ScreenPlay 4805 Multimedia...
Infocus X2 projector shows picture in black and white only...
that little glass square broke off of the colorwheel, and it needs to be replaced. that yellow/gray line is from the light tunnel collapsing. both parts can be purchased and replaced by you. if you don't feel comfortable doing it, you can send it in to an authorized service center. try av solutions. they're pretty good. you can purchase infocus parts from them, too.
Oct 27, 2009 | InFocus Office Equipment & Supplies
Infocus X2 projector, white vertical strip on right quadrant.
on the X2, the dmd chip is attached to the main board on the bottom of the machine. you need to take the top case off, as well as the 2 power supply boards. push the dmd chip (behind the lens assembly) back onto the board.
Jun 04, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
2 bulbs blown.
To be honest, most people who experience short lamp life on the Infocus X2 is on the genuine infocus lamps. If you read the user opinions here, you'll know what I mean. Me personally think that the X2 lamp filter some how manage to block the vents with dust which results in inefficient cooling in effect reducing the life of the lamp. The best thing to do is vacuum the lamp filters regularly and stick to cheap lamps as the oem ones on the Infocus X2 are also no good. Or better still, just replaace the bulb on it's own from here and save a lot of money.
Jan 26, 2008 | InFocus ScreenPlay 4805 Multimedia...
1/2 the screen is viewable
You would be wrong. Lamps do not do that. They either work or they don't, they do not cast shadows or give half an image.
What is going on is the light tunnel has failed. It is a small, 4-sided mirrored tunnel that focuses the light into the optical chamber. It is directly behind the color wheel. I've seen this probelm dozens of times.
Mar 30, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus  Projector Lamp for LP340, LP340B, LP350 Logo
351 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
