Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
My Pro6, Model #KP2671XER, was just fine and had almost finished mixing my cake. I added egg whites and milk, put it on STIR (lowest speed) and suddenly my kitchen and I were covered in white cake batter. STIR had suddenly become 12 and then having done its messy deed turned itself off. After removing the bowl and beater and cleaning up, I again tried STIR and the same thing keeps happening - 0 to 60 mph and then stop. What is happening and how do we fix it?
  • 2976 Answers
SOURCE: Clicking
I have the same mixer. Make sure the bowl is firmly latched into the base. also, make sure the bowl didn't get bent in shipping. If the paddle hits at a regular timed interval, it's must likely a problem with the way the bowl seats. As long as you don't hear a loud hit verses just a click, it shouldn't be a problem, just an annoyance. In time, you will probably heat tapping when you use the wire wisk. I am glad I bought mine. I hope you enjoy the difference a good mixer makes.
Posted on Jan 03, 2009
  • 12 Answers
SOURCE: Oil Leak
There are screws under that metallic ring on the mixer head. Gently remove the metalic ring by pushing down on its edge with a screwdriver. Once the ring is removed the screws are exposed. Tighten each one and then again to make sure they are snug. If this doesn't work, you need a new grease gasket. Good luck.
Posted on Mar 16, 2009
  • 16 Answers
SOURCE: kitchenaid mixer speed
I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was defective, so I put it back in mixer and again made sure all of the connections were snug and tight. Guess what?  My original sensor also made my mixer work!  There was nothing wrong with the original Hall Effect sensor except that the connection between the control board and sensor was not tight--unfortunately I didn't check the connection before I decided to buy another sensor. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations. To fix your problem:
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall Effect sensor looks like. BTW the part number is 9703312.
2.  You'll need a phillips head screwdriver to open up the mixer gear case cover.
3.  Make sure that the connection between the control board and sensor is absolutely tight and snug.
4.  Also, make sure that the orientation of the sensor is correct.  It's difficult to tell which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or down. After you've made the connection, run the mixer. If it still doesn't work, disconnect the sensor, reconnect it with the prongs facing the opposite direction and try it again.  I actually found the right sensor orientation through a little trial and error.  But by going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work if it were reconnected with correct orientation.
5.  This whole process probably takes about 10-15 minutes to perform.
6.  Finally, use your common sense and make sure to unplug the mixer before checking, connecting or disconnecting anything.
Posted on Mar 21, 2009
  • 145 Answers
SOURCE: Kitchenaid beater rubs bottom of the bowl
Your beater to bowl clearance has come out of alignment. This can happen naturally over time and with normal use of the appliance. This is something you may correct from home using a flathead screwdriver.
Unplug the mixer, with the bowl and flat beater removed. Tilt the mixing head back as far as the machine will allow. In the exposed hinge, behind where the bowl would normally sit, you will see a 3/8 screw exposed. Turn this screw half a turn counterclockwise (to your left) in order to raise the flat beater from the bottom of the bowl.
This may take a few attempts until the beater is clearing the bottom of the bowl again. If the adjustment screw will no longer turn, do not force it. It is only designed to move so far to make the appropriate adjustment.
Be cautious. Raising the flat beater too high may leave dry ingredients at the bottom of the bowl.
If further information is needed, I would advise you to contact Kitchenaid Customer Service. They may walk through this adjustment through you over the phone and can look into ordering replacement beaters for you also.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
hslincoln
  • 235 Answers
SOURCE: Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Posted on Nov 28, 2009
Testimonial: "Thanks to this answer, I was able to fix the problem in about five minutes. I am very grateful. Joe McCutchen"
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Mar 02, 2013 | KitchenAid K5SS Heavy Duty Commercial...
I have a KP26MIXWH mixer that when I turn it on at it's lowest speed it immediately runs up to it's highest speed and then stops. None of the other settings will get the motor to turn althoug
On the professional 600 model there is a speed control board (Computer board) that is probably the culprit. Easy fix cost $30-$35.00 dollars for the part plus shipping. if you are under warranty then Kitchenaid will fix. If not you can do it quickly. Go to kitchenaid site look for support tab on right top side of window and click it, look for get user guides and manuals in the next window, click it, enter on the right side of the next page the model number and who you are (consumer), then you will be taken to another page that has the manuals listed on the left the upper manual is for user guide the lower manual is for parts list. Down load the parts guide / list so that you can find your particular speed board and it will show you how to disassemble and replace. It really is an easy fix. Not messy or complicated, just take your time and lay your parts out in a manner that will make YOU remember how they go back in. There are no other computer boards in the mixer so you will have no problem recognizing it. call Kitchenaid customer service and ask where the nearest service center is, if you live close by take your part number to the center and you can probably get it at the parts desk (fast parts, more expensive than internet, no shipping costs) Please let us know if this helps or if you need more help, that's why we're here.
Sep 17, 2012 | KitchenAid KP26M1XPM Professional 600...
I have just purchased an ice cream freezer for my mixer. It is an older model and does not have a "stir speed" delineated. What is the equivalent of stir speed on the older models? -- 1 or 2?
On models with the "STIR" speed, the RPM (Rounds Per Minute) is 60.
Set your mixer speed to "1" or "2" and do the following:
Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. In your case, the correct STIR speed is 60.
Jul 29, 2011 | KitchenAid KSM50PR Professional Series...
Kitchenaid Artisan KSM150 Stir problem - Stir speed is the same as setting 2, but all others (4, 6, 8, 10) work fine. Tried adjusting the control board but "stir" and "2" still spin...
You are not adjusting the screws correctly. All three screws (2 top left and right, and 1 bottom)
must all be adjusted. Here is how:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Hi there, I was doing cake mixing and turn off
If you can hear the motor spinning and the beater does not spin, the worm gear has probably failed. These fail frequently, specially after using them beyond there designed limits. The motor heats up and the gear, which is a type of plastic or nylon, melts.
Feb 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Dec 11, 2010 | KitchenAid Classic Stand Mixer
My KitchenAid KSM90 will not turn off. All the speed settings seem to work, it just won't shut off. I have it open, but don't understand how the switch operates such that it turns the mixer off. The...
I determined that the switch that controls whether the mixer is on or off is controlled by a copper bar with a contact. The contact got fused to the copper bar, possibly due to a short. Since the contact got fused to the copper bar, the circuit was always connected, so the mixer was always on. The solution was to 1) unplug the mixer, and 2) take a screw driver and gently pry the contact away from the copper bar. When the mixer is in the off position, the copper bar and contact are no longer in contact. When the mixer is on, the copper bar and contact make contact. My mixer now works just fine. Yea!
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Kenwood Chef model A901 smoke & burning electric smell from motor
there is a kit on ebay for both 701 and 901 kenwoods requires use of soldering iron do a search for Kenwood motor repair it is unlikely to be the motor usually the speed contoller components
Dec 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
99 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
