Acer sound card plug?
Put in new video card no sound ,,,plug out don't know where to plug it inside
  • wendel May 29, 2008
    It turned out to be that when thenew video card went in it had own sound so computer shut off the sound card automaticaly...had to turn card on again thru menu I think he did it......
    Champion:
    Scholar:
  • 209 Answers
Maybe the sound cable was disconnected. It is a 3 pins connector. It is not easy to see on the motherboard. The sound cable of your sound card has to be connected there. You might have to bring your computer to a repair service desk. I have also an Acer computer. And on mine, it is located near the rear on the computer.
Posted on May 27, 2008
Has my integrated video failed on my acer aspire am1100-b1401b?
Make sure your Acer works with a different monitor. Check Device Manager in the Windows Control panel and maybe update the monitor/graphics card driver.
Feb 02, 2018 | Acer Aspire Computers & Internet
How do i find and remove video card on my acer 1100-b1410a
Your video card is in what's called a PCI slot on the inside of your computer, most computers such as yours have an on board graphics card that's built into the motherboard itself. Thus in this situation you cannot really remove your video card. But if you want to put in a new video card, all you have to do is put in the video card in the PCI slot, and make sure your monitor is hooked onto the VGA, HDMI, or DVI slot. In fact, you can have more than one graphics card on your computer if you needed it.
Feb 24, 2013 | Computers & Internet
My acer z5600 crashes with multicoloured screen when playing games
Ya it sounds like your video Card is dying, though you can check with different RAM and try some normal games which don't need high Graphic. You have PCI Graphic card fitted on it then try removing and playing the game, then this way you can know what is the fault.
Aug 14, 2012 | Acer Aspire Z5600 PC Desktop
How to change the graphics card software in acer aspire desktop....
You'll just have to know what kind of graphics card expansion slot you have. Older systems have AGP slots & newer ones have PCI-Express. This will help you decide which type of card to install.
Once past that, you would have to physically open up the CPU tower case while the machine is off & unplugged from the power. If it has an existing graphics card, it will have to be removed & the new one will be installed in its place. If you had been using onboard video, make sure to plug the monitor data cable to the NEW video card's VGA slot.
Everything practically plugs into ONE SLOT & only goes in ONE WAY. so if it does not fit, then it's being placed incorrectly. After putting it back together, just restart the machine & insert the installation CD that came with the new video card & follow the program instructions.
Please take note that it may require that the software and drivers previous display adapter will have to be removed first.
Aug 12, 2011 | Computers & Internet
Acer x1300, front sound jack is not working, back one works fine, all the usb ports work fine on the front, its only the audio port... any idea's?
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
orbe sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Mar 01, 2011 | Acer (54.AA806.001) Sound Card
Acer aspire with no sound card fitted is this a reasonably easy job to fit one?
I am assuming this is an acer aspire laptop - the simple answer is no. The sound capabilities are built into the motherboard.
Dec 18, 2010 | Acer (54.AA806.001) Sound Card
Hi, I have an Acer AL1715s monitor and the VGA cable is cut about 5 cm from the backside. The monitor has no VGA input on the back but is connected inside with a 13 pin connector. I have to make a new...
you have a rgb connection or a dvi connection.
do not engineer your own version of a vga/dvi cable.
just go and buy a new cable, which should be cheap
here is a service guide for this monitor
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/s.g_al1715_book.pdf
Oct 15, 2010 | Acer AL1715 17" LCD Monitor
Installing a new video card
You can not upgrade the video in a notebook computer, or at least any that I've ever heard of. Sorry about that.
Jan 27, 2008 | Acer Aspire 5610-4648 Notebook
New video card keeps monitor blank
you have to reprogram your pc. or try changing the jumpersetting. disabling your onboard video display. hop this solves the problem.
Jan 10, 2008 | E-Machines W3052 PC Desktop
Video card
the computer should have the card in it. go to wal mart and look and some of them you will find one that will work. turn the computer off, take off the case, lay it on it's side take out the card, start up the computer, put in new disk, install software, turn computer off, lay it back on it's side, put the new card in, you will see how it goes in, case back on, start up computer. Your done!
Nov 26, 2007 | Acer Aspire™ T180 PC Desktop
Open Questions:
Cloud Backup, Data Recovery, Data Backup, Cloud Back up Solutions 'Dataalign These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With, Server Cloud Backup Solution end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer Cloud Backup For Small Business web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Online Backup Pricing some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
Apr 25, 2018 | Individual Computers & Internet
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
