Question about Roper RGX4634KQ Gas Dryer
Where is the pilot light located - Roper RGX4634KQ Gas Dryer
    Sergeant:
    Champion:
  • 351 Answers
More than likely it doesn't have pilot lite. it has has an ignitor if it not heating that may be bad
Posted on Oct 03, 2010
What do I need to do to lite my heater after a summer rest?
How to Light a Furnace Pilot Light Here, we'll explain the basic steps for re-lighting the pilot light of a gas furnace.
#1: Locate the Instructions Label on Your Furnace
Every furnace should have a label on it that tells you how to light a furnace. Sometimes, however, the printing may be small or the furnace area may be dark. In these cases, the label may be difficult to read. Keeping the following instructions near your furnace or in another safe spot where they can be located easily will make the task much easier.
#2: Find Pilot Light and Components
Near the bottom of your furnace is a switch that normally says "Pilot," "On" and "Off." Find this switch and turn it to the "Off" position. Wait at least five minutes. This is important because it gives the gas time to dissipate, which is necessary to avoid possibly starting a fire. While you are waiting, take note of the location of the reset button, which should be near the dial you just turned to "Off."
#3: Re-Light the Pilot Light
Once the gas has had time to dissipate, turn the knob to "Pilot." Then, hold down the "Reset" button and bring the flame of a long lighter close to the pilot light opening. This should light the furnace pilot light. Once you are sure the pilot light is on, release your pressure on the reset button.
Sometimes, seeing a job bein
Oct 28, 2017 | Heating & Cooling
How to light pilot light with sealed broiler oven
What make and model is it? I maybe able to help.
Aug 25, 2016 | Kitchen Ranges
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
My jotul 200 direct vent gas stove pilot light won't stay lit. The pilot lights normally, and fires when the thermostat calls for heat. But when it turns off the pilot goes out as well. We cleaned ou
There's a little screw that adjusts the pilot light. It is usually on the block with all the other valves. Follow the pilot lite supply line to where the screw probably is located.
Nov 22, 2013 | Stoves Heating & Cooling
How to light the pilot. The pilot went off when I shut the power off during the Irene storm. I cannot locate where to open so I can light the pilot. I have a GE Profile Gas Dryer, Mod.PDSR 610GG8WT
unless this is a very very old dryer,, it will have a glow plug element in it and should light without the need to light a pilot, just try starting it and see if it lights, But it would have to be ages old to need a pilot lit, I'll try and locate that model, But lemme know if it fires up will ya
Sep 11, 2011 | Dryers
I own a Kenmore Pro Series Gas Range. We just moved in and cannot locate the pilot light location
there is no pilot light.oven and stivetops have been using a electronic spark or ignitor for more than 30 years now so gas isnt wasted by burning a pilot 24/7/365
Jul 18, 2011 | Kenmore Ovens
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
My pilot light is out on pitco 35cs fryer, i cant locate it to relight it
Pilot assembly is located between the two middle burners, this is where the pilot is lighted. You have to turn the gas valve knob to pilot position then push it while lighting the pilot assembly.
Jan 27, 2011 | Pitco Frialator 35CS Deep Fryer
How do I light pilot light, the top burners will light,but the oven won't come on please respond asap
the pilot assembly should be located behind the drawer ..pull door open at the bottom of range pilot assembly should be located way in the back ..look with flash light its their..let me know if it works ..good luck ..a model would help me more and how old is it
Aug 25, 2010 | Ovens
Pilot light
Ok the OVEN pilot light is located in the broiler part of the over (at the bottom) If you open the broiler and get a flashlight you will see the pilot light unit for the over at the rear on the top. What a cheap piece of **** these Galaxy ovens are.
Nov 21, 2007 | Sears 61301 Gas Kitchen Range
Roper RGX4634KQ Gas Dryer Logo
59 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
