Question about Mitsubishi VS-50705 50" Rear Projection Television
Cracking sounds my tv, unplugged from any sound cable, does all kind of cracking sounds. just the power is on, any idea of what it could be. electrical
  • Mitsubishi Master
  • 8,617 Answers
Either the flyback or the HV splitter are the two most likely causes followed by one of the CRTs.
Posted on May 27, 2008
My insignia flatscreen tv monitor doesn't work. I
Shut off the tv, unplug it, hold the power button on the tv for 90 seconds. Plug it back in. Hit menu? Do you see a menu? (if not, your tv needs serviced)
You might also have a cracked LCD.
Jul 01, 2012 | Televison & Video
Re:toshiba 55h70 tv i unplugged the tv to paint. when i plugged back in a wk later i have no picture or sound. nothing. can't access the menu - completely dark screen. the red lite "on" button...
I would check the fuse on the main board. Check the Capacitors on the Power Supply board. Seeing that you unplugged it and replugged it in you might have bad caps that were weak to begin with. Please learn how to safely work on a TV before attempting . Even when a tv is unplugged it has enough power to kill you. Discharge all Capacitors first. make sure its unplugged of course.
Jan 06, 2011 | Toshiba 55H70 55" Rear Projection...
Tv turns on but makes an electric cracking sound and shuts off another one turns on then the screen wigs out and turns off with the power light flashing
Try to unplug tv from the power source for 2-5 minutes and if still have the crackling sound it means the tv needs to be fix. So check your tv's warranty and call the tv's manufacturer to have it fix or replaced.
Sep 09, 2010 | Philips 32PT6441/37 32" TV
TV made a loud crack or pop and the screen went black
Well if it is DLP TV then crack/ pop sound was broken lamp in TV and if its another kind of TV as you did not mention its model and brand then have to check accordingly.
Nov 10, 2009 | Audio Players & Recorders
If i turn off my tv it wont turn back on
This problem is either the TV's software or how the mainboard is distributing power so instead of just unplugging the TV, try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power/on-off button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
Since hardware either works or it doesn't, your issue is either software or power related since you can get it to work so hopefully the power drain will indicate further.
Mar 25, 2009 | Proscan PS36109 36" TV
245BW Snap/Crack sound and then does not work
Be very careful! Some monitors/TV's have 30,000+ volts DC in them even when not plugged into AC house current. The crack/snap sound was most likely an electrical component breaking down and shorting against the metal of the case of the monitor. I would take the monitor to an authorized repair center because the danger of getting shocked/killed is very possible while working on this type of problem at home.
Nov 10, 2008 | Samsung SyncMaster 245BW Monitor
Sound but no picture
Can you bring up the TV's onscreen menu at all when the sound is being heard? Are you hearing the sound from the TV's speakers or from external speakers like a surround setup? If the OSD is not showing up, then a video sustain boards appears to be corrupt and the TV would require service.
You still could at least try a power drain as this has rarely fixed this kind of issue:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
Oct 16, 2008 | Televison & Video
Power failure
OLEVIA SAYS UNPLUG ALL (ELECTRIC, CABLE ECT. FOR 2 HOURS THEN REPLUG IN, THIS WILL RESET POWER PROGRAMMING0
Jul 12, 2008 | Syntax LT27HV 27 in. LCD HDTV
Bad electric shorting sound
when your tv starts making this kind of noises is ussually related to high voltage or a degraded component,If you are familiar with tv service you can remove the back and take a look just to check if you can see what is making the sound,sometimes you can see it if it is a degraded component cooking but if it is a heavy leakage of high voltage you will not see it and it can be dangerous to be even close to it,If you decide to go in to check you need to be very carefull ,I would suggest you call for assistance from a servicer if you are not too familiar with tv service.
Oct 25, 2006 | Zenith R40W46 40" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
