Question about Acer Aspire 5672WLMi Notebook
Runs alright on mains power - without battery in. has problems with touchpad starting windows. battery problem or board?
    Master:
  • 397 Answers
If it has problems starting windows while on battery, that could indicate processor AND motherboard issues- since the processor needs to shift to lower voltage when on battery, and the motherboard needs to be able to fully function on battery. The touchpad issue may be secondary to the underlying problems. If you are under warranty, get it into the depot for a repair. If not, your best step would be to get a replacement battery- if the issue is still there, unfortunately it would be almost as expensive to get a different laptop as getting replacement processor and motherboard for your system
Posted on Oct 03, 2010
No power
test this steps and fix it.God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Jul 22, 2013 | Westinghouse Dishwashers
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
Sep 28, 2012 | Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
Touch pad isstP Pavilion cursor starts drifting uncontrollably
try removing your battery and replace it back. its like resetting it.
May 16, 2009 | HP Pavilion dv4000 Notebook
Keyboard and Touchpad not working
When the batteries on that laptop no longer hold a charge it will cause teh problem you indicated. Remove the battery and restart from the AC power to check. If that fixes the problem you need to go into the devive manager and turn off the Microsoft battery manager. This will allow you to reinstall the battery without the problem.
Jan 07, 2009 | Acer Aspire 3003LCi Notebook
Problem with battery on Acer Travelmate 4060
There are probably some corrupt files on the harddrive or there is damage on the hard drive. I would suggest to try using the windows setup cd or sony recovery cd to restore the system back to normal, if the problem is not solved by that then you most likely have a hardware problem which is most likely in the harddrive, might have to replace it, they don't cost much.
if you press f8 in start up to get the advanced startup menu, select safe mode.
start in safe mode and login
then
press start -> now run -> type in Cmd -> Type in the shell window -> chkdsk /F /X /R C:
if asked select Y to perform the operation on next start up.
see if the problem is solved.
Nov 15, 2008 | Acer TravelMate 2300 Notebook
Sharp LC-45D40U Won't Power On! Need Help!
If doesn't give error code most probably is something wrong with 5 and 3.3 volts lines. Check first the power supply and try to start the tv with all connectors removed. Let only the one between main pcb and power supply. Look for shorted voltages lines.
Apr 10, 2008 | Televison & Video
Travelmate 2310 keyboard and touchpad problem
Boot up the system (without the battery).
When the system runs normaly then place the battery on its normal bay.
Shut down bij removing the power from the system.
* Make sure you have not installed any Windows power saving tools, meaning let it run on the battery till it dies *
Wait till the systems shuts down by itself.
Boot your system again (with the battery in its bay and everything will work out fine.
Shuting down by removing the power support (AC) booting up AND your keyboard with touchpad will work again.
So intill you have a new battery, you need to shut-down by removing the AC power and leave the battery in its bay.
You can not shut-down on the normal way any more untill you have replaced the battery.
Feb 04, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 5672WLMi Notebook Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
