Question about Panasonic HDC-SD1 Camcorder
IMovie capture is poor quality.
I have a Panasonic HDC-SD1 HD camcorder.  iMovie will play the video when the camera is attached.  But after capturing, the picture is so distorted.  I've checked the settings on both the computer and the camera and can find no issue.  I am beginning to suspect something wrong in the camera that doesn't download the file correctly.  Can you assist?
  • Anonymous Aug 27, 2008
    I have a Panasonic SDR-H20 that, when connected to my TV, plays the video with great quality.  But when it's captured in iMovie, the quality is seriously reduced.  I'm sure I have the transfer settings at the highest quality.  Can anybody help?
Hello referring to the SD1 from Panasonic, i recommend to deinterlace the captured clips with "JES Deinterlacer" before editing them with imovie. be careful to use "apple intermediate code" at the output of JES Deinterlacer. i clearly get better results this way, max recommendable size at 1280x720p when exporting QT files... kind regards, bruno
Posted on Feb 28, 2009
HDC-SD1 No Power
Battery could be discharging or worse, power transfer within can is broken
Jul 21, 2014 | Panasonic HDC-SD1 Camcorder
Tip
Mac Keynote Video Converter-Split and Join TM90 1080/60p AVCHD MTS to Keynote...
Convert/Join Panasonic HDC-TM90 HD Videos on Keynote for Presentation-AVCHD MTS to MOV <br />Embed/Store Converted/Joined H.264 mov Videos to Keynote '09-Mac TM90 MTS to Keynote Converter <br /><br />I had recorded some .mts videos using Panasonic HDC-TM90 as part of research. I used Keynote to make presentation. I would like to insert the <b>Panasonic TM90 <a href="http://www.aunsoft.com/final-mate-mac/">HD Videos on Keynote for Presentation</a></b>. However, the resulting HD videos are in AVCHD .mts files which could not be imported to Keynote. With the 1080/60p recording mode, the videos play great on the TM90 camcorder, however, Mac keynote is not compatible with this format, not even iMovie, Final Cut or others. <br /><br />While looking for a solution to add recorded AVCHD videos to Keynote, Aunsoft <b>Final Mate for Mac-<a href="http://www.aunsoft.com/final-mate-mac/">Best Mac MTS to Keynote Converter</a></b> is recommended as the partner to <b>Panasonic TM90 MTS for Keynote presentation</b>. It helps easily creating a vivid slideshow presentation with HD videos by converting AVCHD video to HD MOV. <br /><br />Below is the quick guide to <b>Embed Panasonic HDC-TM90 AVCHD MTS 1920*1080P videos to a presentation created with Keynote</b>. <br /><br />Step 1: <b>Import/Capture Panasonic TM90 Camcorder AVCHD files to Aunsoft Final Mate for Mac</b>. <br />Free Download Final Mate for Mac as a <b><a href="http://canon-videoconverter.com/2011/06/convertjoin-panasonic-hdc-tm90-hd-videos-on-keynote-for-presentation-avchd-mts-to-mov/">Mac Keynote Video Converter</a></b>.When Aunsoft <b>Final Mate for Mac</b> is run, it can automatically detect and pop up a wizard for you to capture video from camcorder. The videos would be listed on the "Camcorder" tab. <br /><br />Step 2: Create a Movie for <b>converting TM90 1080/60p MTS files to MOV for Keynote</b>. <br />Just select one or multiple mts video files you would like to convert, cut from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created. <br /><br />Step 3: <b>Splitting and Joining .mts Clips for Keynote on Timeline</b>. <br />To cut/trim the video, just play it and click the Split button when it plays to the frame you want, and then click the" Delete" button next to the "Split" button to remove the unwanted .mts clips. As Final Mate for Mac is frame-accurate cutter, you can also pause the video, and click the Previous Frame or Next Frame for the exact frame you want to cut. <br /><br />To "join" another clip to the end of the movie, just select the file, drag and drop to the movie ID. The files will be joined into one file as output. <br /><br />Step 4: <b>Export H.264 MOV video file for Keynote</b>. <br />Click the Export button and choose HD MOV as output format. Follow HD Video &gt; H.264 HD Video (*.mov) to choose export format for further sharing your presentations by keynote. In this way, all video clips will be merged as one single movie for keynote. <br /><br /><b>Tips:</b> You are free to set/adjust output MOV files parameters (Bit rate - high quailty, Frame rate - 30, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality. <br /><br />After the conversion, I <b>store the mov video on Keynote '09</b>. Drag the <b><a href="http://panasonic-avchd-converter.com/2011/06/mac-keynote-video-converter-split-and-join-tm90-108060p-avchd-mts-to-keynote-for-presentation/">Full HD MTS videos to Keynote on Mac</a></b>,it is easy to display videos on business presentation. <br /><br /><b>Tips</b>: If you want to import and edit Panasonic HDC-TM90 MTS on iMovie and Final Cut Express, Final Cut Pro , you can choose the <b>Quicktime Movie Format &gt; Apple Intermediate Codec (AIC) (*.mov)</b> and <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> . AIC and ProrRes was advertised codecs to result in less compression and higher data rate/higher quality files for HD editing in iMovie/Final Cut Express and Final Cut Pro.
on Jun 10, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Convert/Import MTS, M2TS files to FCP MOV, MP4, DV on Mac OS
MTS format is high-definition MPEG, AVC, H.264 transport stream video file format which commonly used by HD camcorders such as Sony, Canon, Panasonic, JVC. HD camcorder makes use of MTS in the form of AVCHD, a format for recording and playback of high definition video.
Nowadays, most digital camcorders record videos in AVCHD MTS/M2TS format that is a high-definition and high quality video format.
Here you can check the list of some popular HD camcorders recording video in AVCHD MTS/M2TS format including Canon, Sony, Panasonic and JVC as follows:
Canon HF10, HF100, VIXIA HF S100, VIXIA HG21, VIXIA HF200, VIXIA HF S200, VIXIA HF M300, HG20, HG21, IVIS HF M31, IVIS HF R10
Sony HDR-SR1, HDR-SR10, HDR-XR100, SDR-SR10, HDR-SR11, HDR-XR100, HDR XR-500V, HDR-TG1, HDR-CX7, HDR-SR5, HDR-CX7
Panasonic HDC-SD60, HDC-SD100, HDC-SD200, HDC-HS100, HDC-HS350, HDC-HS700, HDC-TM35, HDC-TM350, HDC-TM700, HDR XR-500V
JVC GZ-HD10KR, GZ-HD30, GZ-HD40, GZ-HM200, Everio HD10, Everio GZ-MG130
HD camcorder owners can enjoy HD video with their HD camcorder, however, original AVCHD MTS, M2TS files cannot be directly imported to Mac. So for Mac users, if you want to import MTS/M2TS video to FCP(a highly-regarded video editing, compositing, and special effects package for the Macintosh) on Mac for editing, you have to convert MTS/M2TS files to MOV, MPEG-4, DV for FCP firstly.
Doremisoft MTS to FCP Converter for Mac is the best software to convert original MTS, M2TS files to Final Cut Pro with good quality. It can transfer MTS video to MOV, MP4, M4V, AVI, DV, 3GP, etc and other HD videos like HD MP4, HD MOV, etc. With this AVCHD Converter for Mac, you can convert MTS video to FCP, FCE, iMovie, Quicktime, iTunes, iDVD, iPad, iPod, iPhone, Blackberry, PSP and so on.
Easy Tutorial for you to convert MTS/M2TS files to FCP on Mac here:
Step1: Import MTS, M2TS Files to Mac MTS Converter
Click the "Add File" to upload your chosen AVCHD MTS, M2TS files to MTS to FCP Converter for Mac after you lauched it.
Step2: Set Output Video Format for FCP
Click "Profile" to open the Profile drop-up list to select MOV, MPEG-4, or DV as output video format for FCP on Mac OS. And you also can convert MTS files to iMovie, Quicktime, iDVD, iPod, iPhone, PS3, Blackberry, etc.
Step3: Convert MTS Files to FCP
Click "Start" to convert AVCHD MTS, M2TS videos to FCP on Mac. you can edit your converted MTS, M2TS files with FCP on Mac OS X after converting finished.
Related: How to Convert MTS, M2TS to iMovie for Editing?
How to Convert Panasonic HDC Series to Mac and Edit Panasonic HDC Video in iMovie, FCP?
on Oct 21, 2010 | Computers & Internet
Panasonic HDC-SD1 camcorder will not turn on
Are the Batt's full? because this looks like you have not enough power to keep the camera on.
Jun 06, 2010 | Panasonic HDC-SD1 Camcorder
Need the serial no for my panasonic HDC-SD1 camcorder
Do a model number search instead of serial no. The manufactor's website usually go by model instead of serial number, for that purposes.
Dec 06, 2009 | Panasonic HDC-SD1 Camcorder
Tip
Convert/Edit Panasonic HDC-SD9/HS700/TM700 to Mac, iMovie, FCP. FCE
Panasonic HDC camcorder family has a great number of High-Definition Camcorders that satisfy different people who want to record their interesting daily life, now, You can check the list of popular Panasonic HDC series camcorder as follows:
Panasonic HDC-SD Series: Panasonic HDC-SD9, HDC-SD10, HDC-SD60, HDC-SD100, HDC-SD200, HDC-SD700, etc.
Panasonic HDC-HS Series: Panasonic HDC-HS250, HDC-HS300, HDC-SD60, HDC-HS200, HDC HS100, HDC-HS700, etc.
Panasonic HDC-TM Series: Panasonic HDC-TM10, HDC-TM20, HDC-TM60, HDC-TM50, HDC-TM30, HDC-TM200, HDC-TM300, HDC-TM700, etc.
Most of Panasonic HDC Series Camcorders record video in AVCHD MTS/M2TS files, for example, Panasonic HDC-SD9 records 1080i 17Mbps video in M2TS files; Panasonic HDC-SD700, Panasonic HDC-HS700,
Panasonic HDC-TM700, these three types store videos in MTS format and all offer Full HD 1,920x1,080-pixel resolution at 50 frames per second. For Mac users, if you cannot import Panasonic HDC video to Mac to enjoy, or cannot directly edit Panasonic AVCHD MTS/M2TS files in iMovie, FCP, FCE, you need to convert Panasonic HDC videos to MOV, MP4, 3GP, M4V, H.264 for Mac and then you can edit converted AVCHD MTS/M2TS video with iMovie, iTunes, FCP, FCE, etc.
Mac Panasonic HDC Video Converter, a professional AVCHD Converter, is designed for converting videos collected from Camcorder Panasonic, Canon, Sony, etc to MP4, MOV, MPEG, 3GP, M4V, AVI, etc to Mac, then you can play AVCHD MTS/M2TS, videos on Mac, iPad, iPod, iPhone, PSP, Blackberry, and any other mobile phones.
How to convert and edit Panasonic HDC video to Mac?
Step1: Import Panasonic HDC Video to AVCHD Converter for Mac
Click "Add File" to upload your Panasonic HDC video to Mac AVCHD Converter after you launched it.
Step2: Set Output Video Format for Mac, iMovie, FCP
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, iMovie, iTunes, iDVD, FCP, FCE, etc.
Step3: Convert Panasonic HDC Video to Mac, iMovie
Click "Start" button to convert Panasonic AVCHD MTS/M2TS files for Mac. After conversion finished, you can enjoy converted MTS/M2TS files on Mac or edit these converted AVCHD video with iMovie, FCP, FCE, iDVD, etc as you like.
on Oct 19, 2010 | Computers & Internet
Tip
Best HD Camcorder for Mac, iMovie, iMovie? 08, iMovie? 09
Recording daily life and interesting things with a HD camcorder becomes a trend for our people. They like to share these digital camcorder videos on Mac or PC with family and friends. However, selecting a good digital camcorder for Mac is not easy for green hand. Maybe more tips need paying attention, for example, the types of your camcorder and Mac, the version of iMovie on Mac, Mac and PC compability with digital camcorder and so on.
iMovie has been a Mac OS X only application bundled in the iLife suite of Macintosh applications since iMovie3. From 2007 to 2010, Apple developed iMovie to iMovie' 08, iMovie' 09, and iMovie for iPhone and iPod Touch. Luckily, iMovie' 08, iMovie' 09 are designed to work with a wide range of digital video devices and formats, including tape-based(use a FireWire cable, also known as IEEE 1394 or i.Link) and the latest tapeless camcorders that record to flash memory, a hard disk drive(HDD), or DVD media.
A list of Digital Camcorders Compatible with iMovie' 08, iMovie' 09 on Mac OS X
NTSC Camcorders(a video format used in North America, Central America, Japan, and parts of South America)
Canon: DC20, DC50, DC220, DC230, FS10, FS11, FS100, HF10, HF11, HF100, HG10, HG20, HG21, HR10.
JVC: GZ-HD10, GZ-HD30, GZ-HD40, GZ-MG330, GZ-MG67, GZ-MG255, GZ-MG555U, GZ-MG505U.
Panasonic: HDC-DX1, HDC-SD5, HDC-SD9, HDC-SD20, HDC-SD200, HDC-HS9, HDC-HS20, HDC-HS100, HDC-HS200, HDC-HS300, HDC-SX5, SDR-H50, SDR-H60, SDR-H200, SDR-S10
Sony: HDR-CX11, HDR-CX12, HDR-SR1, HDR-SR7, HDR-SR11, HDR-TG1, DCR-SR82, DCR-SR200, DCR-DVD308, DCR-DVD508, DCR-DVD403.
PAL Camcorders(a video format used in Europe, Africa, the Middle East, most of Asia, and parts of South America)
Canon: DC50E, DC220E, DC330E, FS10E, FS100E, HF11E, HF100E, HG10E, HG20E, HG21E.
JVC: GZ-HD10KR, GZ-HD30, GZ-HD40, GZ-MG255, GZ-MG67, GZ-MG155, GZ-MG330.
Panasonic: HDC-DX1, HDC-SD9, HDC-SD200, HDC-TM20, HDC-TM300, HDC-HS20, HDC-HS200, HDC-HS300, SDR-H79, SDR-H60, SDR-S15, SDR-S26.
Sony: DCR-DVD908E, HDR-CX11E, HDR-CX12, HDR-SR1E, DCR-SR5E, HDR-SR12E, HDR-TG1E, HDR-CX7E, HDR-UX20E, DCR-SR82E, DCR-SR100E, DCR-SR300E.
Although iMovie' 08, iMovie' 09 on Mac OS work with most of HD digital camcorders using MPEG-2 (standard definition), MPEG-4, AVCHD, and H.264 formats, not all tapeless camcorders are compatible with iMovie' 08, iMovie '09 because of the wide range of media types and the different ways manufacturers store video on these media types.
How to fix it? To meet people editing AVCHD, MOD files with iMovie, enjoying HD camcorder video on Mac, a powerful HD Video Converter for Mac is specially designed for people who need to convert AVCHD MTS/M2TS, MOD, TS, TOD, MKV files to iMovie MP4, MOV, DV for better editing. Besides, that Mac HD Converter is also the very choice to convert HD video like TP, TRP, M5S, TOD, MPEG2 HD, MPEG4 HD, MOV HD, WMV HD, AVI HD to Mac application: iTunes, iDVD, FCP, FCE, etc.
Related: Click here to see more info of AVCHD Converter for Mac for people to convert AVCHD files to Mac iMovie, iPod, iPad, iPhones, PSP, BlackBerry, Zune and other handy device.
How to Convert AVCHD MTS/M2TS to Mac formats?
on Sep 21, 2010 | Computers & Internet
Can I use 32gb sdhc card on Panasonic hdc-sd1 camcorder
The camcorder only supports 4GB SDHC cards.
Regards
Jun 30, 2009 | Panasonic HDC-DX1 DVD Camcorder
When I tried to transfer my video files from Panasonic HDC-SD100, I get the message 'Cannot find image. It is possible that images which comply to AVCHD specifications were not recorded.'
With advanced HD (High-Definition) video conversion technology, HD Video Converter can easily convert among HD video formats, convert video to HD, convert HD videos to SD (Standard-Definition) videos. The HD video converter supports most of HD video formats such as AVCHD (mts, m2ts), H.264/AVC, MKV, MPEG-2 (ts), DivX, HD WMV, MPEG-4 and Quick Time.
Jun 06, 2009 | Panasonic HDC-SD1 Camcorder
Can't view or editvideo on my pc or mac computer
You need a PC with a fast core 2 duo or quad core processor, plus a NVIDIA Geforce 8400 or better grade graphics processor to play AVCHD files in native format. To convert them to other formats, a similarly strong PC and AVCHD compatible editing software also helps. Nero, Ulead, Vegas, iMovie, and Pinnacle offer competing programs. But make sure your PC is adequately powered.
Dec 03, 2007 | Panasonic HDC-SD1 Camcorder
Panasonic HDC-SD1 Camcorder Logo
378 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
