Question about HP Compaq Presario V2000 Notebook
I have a compaq v2401 cl, screen is turning black but when i pressed the lid button it turns back on for a while and after that goes back off.need help. thanks
    Master:
  • 397 Answers
This is likely an issue with power management- are you using the computer when the screen goes black? Or does it happen if you step away from the system...? If this is the case, go to control panel > power options and adjust the delay for your LCD turning off. If the situation is where the screen turns off constantly, that is an issue w/in the hardware of the laptop, and requires you to contact either HP or a local IT firm like Geeksquad or others for repairs to your laptop.
Posted on Oct 03, 2010
Hello, My laptop turns on and begins to start up but then goes to a black screen instead of the home login screen. What should I do?
If the normal login in screen is still partially visible under a bright light, you may have a faulty backlight. Get your machine checked.
The way to work around it could be to wait until the computer has started up (look at the hard drive light) and then put your machine into standby by closing the lid or pressing the power button (according to your settings). When you start back up again the screen should turn on as normal.
Aug 30, 2011 | Compaq Presario CQ60-220US PC Laptop
Wont turn on screen remains black as in not on black and it stays this way even when plugged in
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Sep 30, 2009 | SanDisk Sansa e250 MP3 Player
Laptop screen goes dark.
Is your computer setup to go to sleep when you close the lid?
Click on start -->control panel-->power options and then check the option that says choose what closing the lid does. You have to change this setting to 'do nothing' if you want the computer to stay on when you close the lid.
May 19, 2009 | HP Compaq Presario C700T
Screen goes black
Could be a loose cable connection the cable that runs between the LCD and the laptop my come loose from time to time and the screen will go black you have to be carful with this because you may be shorting out the inverter and eventuly you will have no picture it should be and eas fix if the cable is loose Go to the manue or service guide and find out how to open the Lcd cover behind the Lcd sceen there should be a connector make sure it is properly connected
Mar 24, 2009 | Compaq Computers & Internet
My compaq nx6110 screen goes black and on, why?
This is the issue with the monitor.This is a hardware issue.Please connect the notebook to external monitor and check .If it is working fine then it is the issue with the LCD of notebook If not then this is the issue with the video card.
And ckeck the power cables tooi think this is the issue with the monitor of the notebookAny how you can try to install the latest version of video drivers
Jan 08, 2009 | HP Compaq nx6110 PC Laptop
Compaq Presario 1700 Laptop screen flickers and locks up
it sounds possibly that it is going into hibernation. a single press of the power button should bring it back alive.
also feel the bottom of the laptop.... if it is getting close to meltdown you need to clean the dust and dirt from the heatsinks. the fan area may appear to be clear but all the junk gets blown against copper heat sinks so you need to remove the covers to get at it.
Robert
Sep 05, 2008 | Computers & Internet
Black screen when i turn on computer.
Do a power drain :- Disconnect every cord from the back of computer tower while the pc is oiff and then press and hold down the power supply button in front of the tower..
have u tried updating the bios any time before?
Secondly,is it possible to go to the safe mode or the screen goes blank even before that?
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Compaq Presario V2000 Screen went black
that's a video issue..most likely the lcd, since you have drive to external video connector?
got backup for that Presario?
Feb 18, 2008 | HP Compaq Presario V2000 Notebook
Laptop
it turns on for a second while raising the lid and then goes right back out leading me to believe its the lid switch or senser. But i am unable to locate it. My machine is a toshiba satellite A135-S2276. Please help!
Aug 26, 2007 | Toshiba Satellite A135-S2276 Notebook
HP Compaq Presario V2000 Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
