Question about LG GH22LS40 DVD-RW Burner
I have an LG GH22LS40 and when I first installed it everything worked fine. Months later, my PC bios showed it was still detected, yet in Windows the drive is not available. Somehow I got past that problem, but now the drive doesn't detect any CD or DVD I put in it. Drives and firmware are all up to date, but not matter what disc I use it says the drive is empty. Any clues on what I can do besides buy a new burner?
  • 3 Answers
SOURCE: Windows XP Pro - LG GCC-4243N combo drive not seeing data on disks
if you have lance cleaner then use it but shyore it one famouse brand otherwise it should damage yor cd om's lance if you found nothing then pls go to your hardware vendor
Posted on Jan 12, 2008
rustysheriff
  • 344 Answers
SOURCE: my pc recognises my dvdram as cdrom, after re installing.
Nothing to worry about, it all depends on what type of disc is in the drive at the time.
Posted on Jun 02, 2009
SOURCE: HL-DT-ST DVD-RAM GSA-H55N cannot detect dvd disc
I have same DVD writer and I am facing the same problem. During R&D for such failure on google I came to know there are two different Laser Diodes for CD and DVD. CD read write is working for me. I think DVD r-w laser has some problems. I am currently looking for options to get the new laser diode. As soon I replace the diode and see my DVD writer working. I will upload the video to replace the diode for you all.
Posted on Feb 19, 2010
elix0411
  • 3530 Answers
SOURCE: DVD Drive Can't Detect Any DVD or CD
hi there, this could be windows system glitch. please follow troubleshooting steps below
  1. Click Start , and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Let me know if you need more help. Thanks!
Posted on Apr 08, 2010
Testimonial: "thanks"
  • 1481 Answers
SOURCE: LG GH22 LS50 (Sata Dvd Writer) Will not write dvd discs
What software do u use to write DVDs on both PCs...
if they are different then that may be the issue....
dont spoil the DVDs....
try DVD RW disks...that way you can erase them later...
i too have the same DVD writer, not had any issue in either XP or Win7....i have dual boot and have made many movie DVDs using both OS...i use Nero and Power2Go of LG(the install disk that came with the LG DVD writer has this great software...."LG Power tool")
try this tool...it should work...
the inbuilt DVD creator in Win7 has some issues with DVD creation....due to non compatibility of graphics card and display drivers (WDDM)....+ you may not have the correct codec required to burn DVDs.....
get the FFDSHOW codec from google.... and install it...shutdown and restart and then try...
let me have a feedback pls...
reg
Posted on May 04, 2010
Just bought a new DVD burner, its a LG Super Multi DVD ReWriter 22x (Gh22LS40) I also had to buy a sata to IDE converter for my motherboard that has only IDE connectors on it. I can not get Windows 7 to...
ok here's what you need to do.....
first check your dvd burner if its is detected properly on your cmos. If it is located properly try to re install windows 7 again i've encountered this problem before and i just reinstalled windows 7 and it worked like charm.
If the dvd burner is not detected on cmos try to check the jumper settings for both hard disk and dvd burner one orf the other should not be on the same setting ex. if your disk drive is on master you should set the dvd on slave and vice versa. then redo the first step. hope this helps
Jan 11, 2010 | Gateway GT5220 PC Desktop
I recently formated my hd after a virus i had and have started to re-installed all my drivers everything was working ok untill i installed my graphic card drivers after i had installed them my pc asked me...
do you know how to reset the bios? open the case and look for the jumpers on the motherboard. swop the jumpers around and reseet the CMOS battery. Try that and let me know:)
Alt try reseeting your RAM and Graphics card
Oct 26, 2009 | Computers & Internet
LG GH22LS40 will not work
You will need to check few things to get it working.
1) See that you have attached your DVD cable on the proper port of your motherboard.
2) See that the required jumper is fixed in proper place of your DVD writer.
3) Power cable of your DVD writer.
All the Best
Sep 11, 2009 | LG Electronics 16x DVD and 48x CD-ROM...
Loads windows set up then re boots and bios states
just oen cpu cabinet and detect your harddrive.
Reattch all connection to harddisk.
Jun 11, 2009 | Dell OptiPlex GX150 PC Desktop
Hard Drive Not detected/Windows still boots
Try setting the first boot device as the device with the boot sector on it.
Feb 26, 2017 | Computers & Internet
My computer wont boot because it wont automatically detect my har
Usually when your BIO's doesn't detect the hard drives is usually a good indicator that the hard drive has failed. In rare instants it is the motherboard. In the boot sequence it will only show the hard drives it sees if it doesn't see any then none will be shown. I would start with a new hard drive.
Hope this helps.
Mar 01, 2009 | Dell Optiplex GX60 PC Desktop
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Odd boot
A "hung" system usually tells you that you have registry problems and/or buggy drivers and can include a virus (It can also include a corrupt boot sector). Well, there's a easy fix for this and a really difficult fix for this...And then there's the reinstallation of Windows. Ok, the easy fix is to goto: Start -> Programs -> System Tools -> System Restore Run the restore program back to the time where you were having no problems. Voila! If it is a virus, this will not get rid of it as some of the viruses make their way into the system restore. Then there's the difficult way to do it which is kinda like the installation of Windows but instead you hit "repair" (This is known as the Recovery Console and it's in DOS just to warn you...) Then you can type the following at the dos prompt: fixmbr - Fixes corrupt master boot record fixboot - Fixes corrupt boot sector bootcfg /rebuild - Fixes corrupt or missing boot.ini
Jan 29, 2007 | AOpen AX4SPE-UN Motherboard
LG GH22LS40  DVD-RW Burner Logo
78 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
