Question about JVC MX-KA3 CD Shelf System
Ihave not use the system for while, yesterday thought let me turn ON nothing works, It says "protect" what I do ?
Dacor DCM24S microwave not working--not heating and table not rotating
The bottom door switch or its mount is bad.
See the service manual here and a help file on door switches here.
Nov 23, 2012 | Dacor Microwave Ovens
I have a Tevion AVR/2006. Soon as you turn it on, it comes up overload protect. Nothing works. Tried resetting nothing works. We have gone all through the manual & can not find anything in the...
The overload protect has activated because the audio output ic has shorted, as a thought! check all speaker connections to make sure wire has not crossed causing issues. I suggest a professional to further inspect your system.
Jan 05, 2011 | Audio Players & Recorders
Cambridge azur amp 640a working brill till yesterday !! now protection light !!!! turned it off numerous time etc plenty of venterlation carnt get it to work
Looks like the fuse blown.. or the classic symptom of electrical fault inside the amp. 640A uses a sensitive protection circuit often ends up in this irritating situation. Normally, there is nothing much you can do, but just check your wall plug connection for Open Ground or Left & Neutral reversed issues. If the wall plug is free of error, then you should better contact CA technical support.
Dec 08, 2010 | Cambridge Audio Azur 640A Amplifier
Ihave IE8 Windows XP. In the History drop down
this looks very strange and seems to be virus activity. Please scan your system and reinstall IE8.
Jun 07, 2009 | Computers & Internet
Protect
The protect message indicates that a problem was found in the output stage of the amplifier. Unless this gets repaired, nothing will work. As a verification that the speakers or the wires are not the problem, unplug all of the speakers and try again. If protect still is displayed, the problem is inside the unit.
Dan
Apr 09, 2008 | Sony DAV-S400 System
Ipod not working
try the soft reset.. it shd be normal then...
Feb 15, 2008 | Apple iPod nano 3rd Generation
Dvr 50
Hi I have jamo Dvr50 system and it has been frozen since yesterday. I have power down few times but nothing is happening. It comes on and panel lights up but that is all.
Nov 08, 2007 | Jamo DVR-50 System
JVC MX-KA3 CD Shelf System Logo
48 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
