I have a Bally 1088 three coin quarter slot machine. 1975 maybe??? It has gone into "tilt" and I cannot gettt it out of this mode. Help!!!
  • 12,061 Answers
Hi, with these older units, the Tilt switch, was usually a Mercury Relay, A glass tube with contacts at one end, and Mercury at the other, when this switch is tilted the Mercury shorts out the contacts and you get a signal. Most likely this is whats wrong, have a look for these in this unit. Other times, it was a pendulum arrangement, there is an outer ring and an inner spring, when tilted it makes contact with the outer ring and again we have a signal. So this is what you need to find, and fix.
We used to simply remove these Tilt switches to stop this from happening.
Also check that the electronics that "Reads" these switches are OK, and the Buffer IC, transistor, isn't faulty as would happen sometimes.
Also sometimes it was the reverse, they made contact always & when tilted they lost contact and again we have our signal.
Posted on Oct 03, 2010
How to fix a bally machine with this error code 88ff ?
https://youtu.be/fJ-yRz4AnYc
The video above should help with this error 88ff and should walk you through performing a complete clear.
You will have to hold the test and pseudo coin switches while turning on the slot in order to perform a complete clear.
You will need to perform the complete clear.
Nov 29, 2017 | Dancing
Hi. I have a 1964 Happy Tour Bally EM Pinball Machine. This is basically the same as the Grand Tour machine. It won't reset.
Hey Bill, if you have facebook, look up Tilt (Bar in toronto canada). the owner may be able to help you if you message him.
Jan 14, 2017 | Video Game Consoles & Games
Quarters will not let up drop them into the one at a time money slot
coin box is full company needs to empty
try to Shack machine will do a temporary fix as it will level coins in box
Jun 20, 2016 | Washing Machines
My hoover will not fill with water when the start button is pushed and three lights come on H G D and all three flash all the time .Can you help
It could be that the water pump is jammed with a coin or maybe a kirby grip or something of that nature , pull your machine out and switch off the power , then tilt the machine up at the rear and check to see if the pump is turning by hand , if it is not turning properly it could be hat coin or some other object is jammed in it , you will need to take the rear cover off the pump and check to see if there is anything in it , if you find anything in it this will probably be the problem , put the pump back together and try the machine to see if it fills , good luck , also if your machine is under 5 years old Hoover will replace any parts as you have a 5 year guarantee on parts
Aug 22, 2014 | Hoover Washing Machines
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bally coin slot machine wont let the handle pull
THIS IS DOCTOR FIX. MY BUSINESS IS GAMING REPAIR. (JUKE BOX=PINBALL= SLOT MACHINES
BOWLING =POKER, FOR 68 YEARS.) IF YOU HAVE NOT SOLVED YOU PROBLEM, I ASSUME IT IS ELECTRONIC, NOT MECHANICAL. IF MECHANICAL , LET ME KNOW, I WILL TELL YOU WHAT TO DO.
ON THE ELECTRONIC, OR ELECTRIC (NO COMPUTER)
THERE IS A BAR MOVES ON TO THE CAM ON TOP OF THE CATCH, ABOUT 3 INCHES ABOVE THE BOLT THAT HOLDS THE ARM IN PLACE, WHEN A COIN IS INSERTED INTO THE COIN SHOOT, THAT METAL BAR ENGAGES THE RATCHET , TO SPIN THE WHEELS. DOES THAT HAPPEN ON YOUR SLOT.? OPEN THE DOOR PULL THE WHITE SWITCH THAT CLOSE WHEN DOOR IS CLOSED (OUT) THESE ARE A THREE POSITION SWITCH.
IN-HOME JUKE BOX REPAIR
SEYLEVITT@JUNO.COM
HOPE IT HELPS.
May 03, 2009 | Bally Walk In 9 8"" X 19 3"" X 7 6"" high...
Want to swith from free mode to coin charge mode
there are buttons inside the coin door for programming. one to get into the programming mode, and the other(s) for selecting options. the options will appear on the screen. you should be able to chose it from there.
Mar 27, 2009 | Namco Ms. Pacman Galaga Cocktail Video...
Televison & Video Logo
265 people viewed this question
Top Televison & Video Experts
