Question about Acer Aspire 6530-5143 Notebook PC
Acer aspire 6530 will not run windows vista, will not allow safe mode, just keeps loading files on screen then nothing! LOADED: :WINDOWS:SYSTEM32:DRIVERS:FILEINFO.SYS (loading files message but with a number of different file types) will not even allow me boot from vista installation disk :( pleeeeease help
    Master:
  • 397 Answers
When your computer is first booting, try tapping F12 to get to the boot menu. Once there, boot from the Vista installation disk- you may need to fully reinstall windows from that point. Try doing a repair first- if that does not work, do a full reinstall.
Posted on Oct 03, 2010
Recovery 32 type mismatch message
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 03, 2013 | Acer Aspire 4720 Notebook
When i power up my Acer M3400, everything loads then after the 'welcome' windows part the screen goes black and i can only see the mouse cursor? I tried to restart but nothing happens. It keep
Not sure, but try loading Safe Mode by pressing F8 during boot and lowering screen resolution. In Safe Mode you can even run System Restore. It load to a previous date that you choose.
Jan 11, 2013 | Acer Aspire M3400 PC Desktop
I have an Acer Aspire 6530 running Windows Vista and today it started shutting off at random. When it shuts off the bottom 2/3 of the screen has blue stripes across it, and on the blue is text I cannot...
Good question.
Does the computer feel hot when it shuts off?
Does it always happen at the same exact time?
Can you try booting the computer into Safe Mode? (What Happens?)
First thing I'd try is uninstalling the video adapter driver under device manager and restart the computer.
Let me know what happens!
May 20, 2010 | Acer Aspire 6530-5143 Notebook PC
Windows will not boot on acer 5315 notebook
As the unit will not boot at, i am afraid you are going to have to do a recovery which will also wipe any data on the notebook.
To run a recovery make sure it is powered off then power on, as soon as you power on you must tap the left Alt + F10 keys together at the same time, now timing is important and can take several attempts before you enter the recovery manager. Keep tapping the keys at approx every half a second or so and wait for a message at the bottom of the screen which will state " Windows is loading files" then you can stop tapping. A new screen may appear after that which will state " edit windows boot options: for windows setup or it may say acer e-recovery" if this screen appears then simply press the enter key, you will then enter the Acer e-recovery manager which will then ask you "How would you like to restore?" select the first option for a factory default reset, hope this helps.
Sharky
Jul 05, 2009 | Acer Aspire 5315 Notebook
Laptop is loading OS vista but doesnot open windows it seem to affect by virus nameof laptop acer aspire
There might be 3 options.
1. Restart notebook. Press F8. Enter in safe mode. Delete the file affected by virus and check whether that would solve the issue.Try running anti-virus if that would allow you.
2. Restore the system.Again enter in Safe Mode and restore the settings to back date.
3. Repair/Reinstall windows or Download registry files and add to the windows menu.
Any further help, let me know.
Thanks for using "Fixya".
Jun 12, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Windows vista on Accer aspire 5315 reboots over and over
Try starting in safe mode (press f8 on start up) once in safe mode use system restore to restore your operating system to a earlier point.
For XP
Start - programs - accessories - system tools - system restore.
For Vista
Start - all programs - maintenance - backup and restore center
May 17, 2008 | Acer Aspire 5315 Notebook
Acer 5610z will not start
I had the same problem with my neices Acer 5100...Went into safe mode, it loaded the drivers and sat that for what seemed forever...almost like it was hung up....I had a few things to do...and a couple hours later, it finally booted into safe mode.
I was able to save her files, but ultimatly ended up wiping everything out because of the corrupt files.
On another Acer, the same hang up "unable to boot into safe mode" even after a long period of time, and that Acer was a total loss..had to format...
I presume nothing was saved to a CD? i.e. her gsce files?
Doing a factory restore/reset will loose everything.
Try to boot into safe mode and allow it to boot up...see if it eventually comes up...I will keep reading for a solution other than the two here...and will post as soon as I find one...
Unfortunately, Acer do not have a good fix for most of their computer problems....
~~Jasta~~
Mar 29, 2008 | Acer Aspire 5610 Notebook
My Acer aspire 5100
If you are able, when the pc is booting up keep pressing F8, this will take you to safe mode and not allow the graphics driver to run. When in the safe mode options, select either Last known good configuration or start windows in safe mode. Last known good configuration should find the last good system settings, when it reboots. Start windows in safe mode allows you to go into windows using the administartor account, and then you should select system restore and restore back to the day before or just before you updated the graphics driver.
Aug 16, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 6530-5143 Notebook PC Logo
221 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
