Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Is there a password that I created for my wireless router? I thought it was the "key" numbers/letters on the bottom of the unit. Does this Actiontec GT704WG work with Mac Notepads?
  • petruc5 Oct 03, 2010
    OK...so is there an IP address for this router? where or how do i get to that?
    Master:
  • 397 Answers
By default the WEP key is on the bottom of the gateway- however to login to the gateway, the user name and password are admin and password
Posted on Oct 03, 2010
    So how can i find the IP address for my ActionTecGT704WG??
  • Susan Fender
    Susan Fender Oct 03, 2010
    The default IP address for your model is 192.168.1.1
    And yes, the Actiontec works with Macs- the interface is web-based, so technically you can use it on any OS platform- as long as said OS supports HTML!
How to set router password
Make sure that you are connected via ethernet cable or hard wired connection:
1. Open a browser ( internet explorer, mozilla firefox,google chrome or safari)2. Delete all of the characters in the address bar3. Type the numbers 192.168.1.14. Press enter.5. You will be able to view the modem settings page.6. Select Basic Setup or the second tab with the word interface.7. Select Wireless Setup8. Enter the SSID or (service set ID), this will be your wifi name.9. Select WEP or WPA for your router's wi-fi password.10. Select ASCII for the passworrd.11. Enter any password ( around 10 alpha numeric characters to make sure that it is a strong password)**alpha numeric means combination of letters and numbers.12. Select Save or Apply.13. Disconnect the network cable for you to test the Wireless password connection.14. Scan for new wireless network on the lower left hand of your computer's screen.15. Look for the wireless name that you entered for your SSID.16. Connect and it will ask you for the wireless / pre-shared key17. Enter the WPA password that you created ( the 10 letters and numbers that you entered for ASCII)18. Press connect.
there you go... you will be connected to your router via wireless with password protection. No one can connect to your router unless you gave them your PSK or wi-fi pre-shared key.
Dec 24, 2011 | Linksys Computers & Internet
I want to find the pin for linksys router to give to house guest. can't find it on router
when you say pin do you mean the encryption key? and if so what operating system is on the computers in which are currently connected to wirelessly ? and did you try going to 192.168.1.1 and typing in your admin info? (default is usually admin for name and no password or password as password) and going to wireless then security and you should see something written next to the generate option and hit generate and that shall be hte key
Jun 02, 2011 | Linksys Wireless-G WRT54G Router
I tried to change from WEP to WPA but the password will not go through. It makes it an unsecure line for wireless. What am I doing wrong?
The Short Answer:
Your password might not meet criteria. It also depends on whether you use a custom encryption key. If so, then you either need to create a 10-digit or 26-digit hexadecimal number (numbers 0-9 & letters a-f) depending on whether you use 64 or 128-bit encryption.
The Long Answer:
A WPA password must be between 8-63 characters long, and must only contain ASCII printable characters.
The 2Wire User Guide for the 2700 states the following:
"You can customize the following wireless settings in the Wireless Security panel.
1. From the Authentication pull-down menu, select an authentication setting: WEP-Open, WEP-Shared, or WPA-PSK.
Note: WPA-PSK authentication is supported only on HG model gateways.
Open authentication allows users to configure their wireless adapter as either Open or Shared; in either case an encryption key is required. Shared authentication allows users to configure their wireless adapter for Shared authentication, which requires an encryption key. WPA-PSK requires that users configure their wireless adapter using TKIP.
2. To use the encryption key that came with your gateway, click the Use default encryption key radio button.
To create a custom encryption key, click the Use custom encryption key radio button. If you select Use custom encryption key, you can define a 64-bit or 128-bit encryption key. For 64-bit encryption, enter a 10-digit hexadecimal number. For 128-bit encryption, enter a 26-digit hexadecimal number. A hexadecimal number uses the characters 0-9, a-f, or A-F.
3. Click SAVE"
May 04, 2011 | 2wire 2700HG-B Router (2700HGB)
How can I find or reset the security key on my D-link WBR-2310 wireless router?
In order to find the wireless security password of your Dlink wireless router G WBR-2310 , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Web key wireless internet service
I think you meant WEP key. this is a wireless encryption security key. and it is normally required when you try to connect to a secured network. Your administrator should be able to provide you with this. because it varies. i.e you can set it to whatever you want if you have access to the wireless router. in your case Belkin 54g Wireless DSL/Cable Router
so please if you have access to it, log in to the router and check from wireless security settings.
Regards
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
My Linksys will not connect to my WII
Well the first thing is that you have WRT160N router. This router has issues with the firmware. So first you will need to upgrade the firmware of the router. Download the firmware of the router from the manufacturer's web site. Connect your computer to the router. Open the router page. Click on Administration tab. Just below administration you will find firmware upgrade subtab. If you click on it, you will find the browse option. Browse the file that you have downloaded from the web site. and Click upgrade.
For WII, you will also need to change the MTU to 1365 and open some port numbers on the router.
Apr 17, 2010 | Linksys WRT160N Wireless Router
I have forgotten my wireless password
To reset your router, use the following steps:
Press the reset button for 30 seconds. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
Open up your Web browser and enter “192.168.1.1′ in the address bar. For the login, leave a blank ID and enter “admin” as the password. The router has now been reset. Follow the steps in Securing Linksys WRT54G Wireless-G Router to secure your router
To secure your Linksys WRT54G wireless router, follow these steps:
Open your Internet browser and enter the following in the address bar: http://192.168.1.1. Enter the user ID and password for your router. If you haven’t changed it, the default password is “admin”. We will change it later if you haven’t already changed it. You should now see the “Basic Setup” Web page display in your browser. Scroll down the page until you see “Maximum Number of DHCP Users”. This option will assign a specific number of IP address to computers. If more than this number of computers tries to connect to your router, they will not be able to.
Count the number of computers that will connect to the router, and type it into the “Maximum Number of DHCP Users textbox”. Scroll down to the bottom of the Web page and click “Save Settings”. Once the settings have been saved, click “Continue” to return to the Web page. At the top of the Web page, click the “Administration” option in the menu bar. On the “Management” Web page, you should see two password text boxes. This is where you should change your administrative password. Type in a new secure password into both boxes. If you need help creating a secure password, please read Creating Secure Passwords. Once you have changed your password, click “Save Settings” at the bottom of the Web page. You may be prompted to login again, if you are then enter you new password in the password field. Navigate back to the “Management” Web page by clicking the “Administrative” option in the menu. We will now encrypt your connection to your router setup from your computer. To do this click the “HTTPS” checkbox next to the “Access Server” option. Once again, click the “Save Settings” button at the bottom of the Web page. You won’t get the settings saved page again because the URL in the address bar is not longer correct. Since you have changed your connection to HTTPS, it you need to specify that in the address when you connect to the router setup.
In your browser, change the address to: https://192.168.1.1. If you get a security error, ignore the error and continue to the Web page.
Login with your password and then click the “Wireless” menu option. Beside the “Wireless Network Name (SSID)” option, type in a name for you network connection. Click the “Save Settings” button and the “Continue” button to return to the “Basic Wireless Settings” page. Click the “Wireless Security” sub-menu option at the top of the page. This is where we will provide the most important security setting. Next to “Security Mode”, select “WPA – Personal” from the drop-down list. If you have trouble connecting to your wireless connection, you can try selecting “WEP”, but your connection will be much less secure. For more information about WEP and WPA please read Wireless Security: WEP and WPA. Next to “WPA Algorithms”, select “AES”. Once again if you have trouble connecting to your wireless router, select “TKIP”. Now you must get very creative. Specify a long “WPA Shared Key” with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
Click the “Save Settings” button at the bottom of the Web page, and then the “Continue” button. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your “WPA Shared Key” exactly as you specified it.
Dec 24, 2009 | Linksys Wireless-G WRT54G Router
Need to change password from previously changed password
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network
Click Here for more info
Dec 19, 2009 | 2wire 1800HG Router (RG1800HG00)
USB Wireless Network Setup Values
during setup it should asked you to create password but anyways those letters are security protocals for your router to prevent peeps from accessing your network...wep is easiest
Dec 02, 2008 | U.S. Robotics MAXg USR5461 (738168036790)...
Need to secure my wireless router. do not know how?
Go to your wireless router software and click on the security setting section. Create a WEP key by providing a secret code or password that restricts access to the network. (to get access type http://192.168.0.1) Step2Be sure to choose a key with a combination of letters, numbers and symbols. These types of codes are the most difficult to break. Step3Click on the wireless connections options on your wireless router software. Find your router from the list of found servers and click on security settings. Step4Add the WEP key that you used on the main router settings to the wireless device. A lock symbol should now appear next to the name of your wireless router from the list of available routers. Step5Access the Internet via your router using only devices that have the WEP installed in their wireless settings. Without it, they will not be able to complete the connections to the network. This information must be added to all wireless devices that you plan to access via the router.
Nov 12, 2008 | Belkin Computers & Internet
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
117 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
