Switched my linksys wireless USB300N adapter to another USB slot on my computer. Now the lights are working in reverse the power light blinks and the signal light stays on constant. However I am conected to my network. Why are the lights working in reverse?
  • 7,733 Answers
How you switch? With the machine turned on? If yes :
1-Unplug the USB
2- Turn off
3-Plug it back.
4-Restart
Post back!
Posted on Oct 03, 2010
Need help with a wusb54g ver4 network adapter
You are say link light means network light not on. Then you check network cable because network cable not proper response not link light on. or check you not break any cable. If possible reset Linksys adapter and wait some time then open and configure i hope solved your problem. If not solved then contact Good network engineer.
Thanks.
Computer Support
Mar 06, 2014 | Linksys Wireless-G Broadband Router
I use a H760 wireless headset of Logicool. Today, the wireless receiver usb showed only blinking green light. For 5 minutes later, the green light was disappeared. The headset didn't work. Can I...
Yes, it normally works for me to put the usb into a different usb slot. This will reinstall the driver for a different usb slot and make it work perfectly!! Make sure it is charged, and that you have powered it off and back on first.
May 18, 2011 | Logitech Computers & Internet
My Linksys usb network adapter is not working properly. When i plug it into the usb slot, the power light turns green, the link light is dimmed. then after a few seconds the power light turns off. As a...
There are several situations that could be the cause of the problem. I would try to uninstall all software and drivers related to the USB device, reboot your pc and follow the documentation for proper installation of the software, drivers, and device. Many USB devices are not Plug-n-Play, they require the installation of the software and drivers before you plug the device in. If it is not installed correctly it may malfunction. If this does not work you might check compatability with your version of Operating system, PC etc....If compatable then try installing on a different pc to see if the problem persists.
Apr 30, 2011 | Linksys Wireless-G Broadband Router
Cannot get truemobile 2300 to communicate with linksys usb network adapter Wireless light does not show in truemobile 2300 and link light does not light up on network adapter
To isolate the problem try installing the adapter to a different computer and if it works there it could be that your card slot is defective. As for the router try to reset it
Mar 06, 2010 | Dell TrueMobile 2300 Wireless Broadband...
In usb slot bt200c-usb not work or blue light not glow
Connect the device on another USB slot at the back of your computer. You may also try connecting the device on another computer to further isolate the problem. If the adapter will not be recognized on another USB slot or another computer I assume that your USB adapter is defective.
Jun 14, 2009 | AmbiCom Air2Net Bluetooth (bt2000c-usb)...
Power outage blew out adaptor?
You can try first to connect the adapter on a different USB port and check if it will be detected if not detected if possible try to connect it on a different computer and hopefully it will be detected but if still no adapter is already dead and needs a replacement and linksys has a 3 year warranty for this one so if its under warranty have it replace, you can contact Linksys via this number 8003267114...
Dec 11, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Wireless adapter
Try to reset computer by unplugging for 1 hours and put it back after 1hour. If the reset did not work try using an usb powered hub in the middle, this sometimes fix the problem.
If the HDD still does not work after the above then it is probably faulty.
Here you can buy an USB hub: Linksys ProConnect USB2HUB4 4 Port Wired USB Hub
Sep 06, 2008 | Computers & Internet
Dell D600 - Linksys wireless router/adapter
Seems there is a problem with the Linksys since there is not any lights coming on. Did you plug it into a switched outlet in the wall? Does it work if you plug the Linksys into an outlet in another room?
If you can get it to light up, the way you will access it is through your web browser. Type in 192.168.1.1 into your web browser and a login in screen should pop up.
Apr 28, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
