Question about Mitac Mio A701 Smartphone
What kind off program i need to update my device.? how i update my windows 5.0
Windows 7 driver
Search for the Samsung website. you should find all of the info you need. Also windows 7 will find a driver for your monitor if you go to your device manager and click the device driver drop-down-window for your computer's video card. Check your Windows 7 updates in all programs on the 'start button'. What kind of problem are you having with the monitor? If only the driver update finding that isn't too difficult.
Nov 07, 2013 | Samsung SyncMaster 920NW Monitor
My pc camera is not operating need help
Hi, go to control panel,device manager,check there that your laptop dont have problem with it(check any yellow or red icon around the camera name)double click there make sure you see this message:
(your device is working properly)if you have this message so go get some web cam software or chat program to use it,if have error on that screen go to hp website type your model number in the search bar and download the software driver for your web cam from hp website or use windows update to update your driver software,windows need driver to identify your hardware and can use it,u can use update the driver software in the device manager,right click on the web cam device(Imaging devices) and choose update driver software,if u dont have software issues may be u have hardware problem,
kind regards
Apr 17, 2013 | Compaq Computers & Internet
I wanna DSL-2370u driver for Windows xp
Click start control panel administration tools computer management device manager scroll through all of your devices or for Windows 7 click start right click on computer select properties in the left pane device manager scroll through all of your devices. If you see a yellow question / exclamation mark ? ! or a Red X you will need to update the drivers for this device right click select update driver/reinstall driver software. If you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. or you might have to download them Rather doing a driver hunt which can take hours. http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 This might take some time being a freeware driver solution Note: The Driver program will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. also at cnet http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: Motherboard name sound drivers. Place a tick in either windows software or all software box. You might have to try a few times to get it right. http://download.cnet.com/drivermax/3000-18513_4-10572602.html Windows 2000/XP/Vista/7/8 free driver program http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html Windows XP/2003/Vista/Server 2008/7/8 free drivers http://www.downloadcollection.com/device_doctor.htm Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use http://www.innovative-sol.com/drivermax/ free program, paid update available Hope this helps.
Dec 08, 2012 | D-Link DSL 200 (DSL-200) Modem
DRIVER
Please be more specific so we can do a search for your driver that you need. Post computer make which Windows Operating System you use also what kind of driver is it a audio or video or what kind that you know of which program is not working or device. We are here to assist you thanks for using FixYa! John
May 05, 2011 | Computers & Internet
Need software to install hplaserjet p1006
Kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,
very minute but technical tip is to
connect the printer first and insert program CD for printer in the ROM drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in next few minutes your device shall be ready to use. In case there is problem with installation with CD kindly go to manufacturers website and download windows compatible drivers.
For Safe Computing Kindly keep your antivirus updated and firewall is on.
Thanks And Regards
Kindly rate this solution
Mar 03, 2010 | HP LASERJET P1006 Printer
Computer running under Windows XP says my device is not connected and yet it shows in Windows explorer?
Hi There..
When you say device is listed in windows explorer, butif the XP says device is not connected. Then i'd say the device is detecting as storage media (i.e MSC).
It needs to be connected as MTP. In this case i'd request you to update the MTP driver.
To update the MTP driver you can try two ways.
First Step:
1) When you connect the MP3 player to the computer you could see a SAFETY REMOVE HARDWARE on the system tray.
2) Right click on that safety remove hardware.
3) You will get a popup, in which you need to click on properties
4) That will bring the window in which you can see your MP3 player listed.
5) Right click on it and choose the option update driver.
6) This will update the MTP driver of the player and after that unplug the device
7) Restart the computer and now connect the device.
8) That will automatically update the drivers.
SECOND METHOD:
1) Go to device manager
2) Locate for the option that says USB and right click on it.
3) Try updating the drivers.
4) Now restart the computer.
5) That should work.
Kindly revert if you have any clarifications.
Jan 30, 2010 | Creative Labs ZEN V Plus MP3 Player
I need a driver for a ASUS motherboard version N13219 so that we will have a audio. Can you help me?
You can use Device Manager and/or Windows Update to locate the necessary driver for your system. If you know the manufacture of the hardware in question you can visit their respective website and obtain the driver from there.
Also, feel free to visit this help article found on the Windows Help and How-to website about Tips for fixing common hardware problems.
How to update drivers using Windows Update
1. Click Start, click All programs, then click Windows Update.
2. If prompted press Continue or provide administrator credentials.
3. In the left pane, click Check for updates.
4. To see if updated drivers are available, click View available updates.
5. Windows Update will list any updated drivers that are available under Optional downloads.
6. If any updates are available, click the driver that you want to install, and the click Install.
How to manually update drivers using Device Manager in Windows
1. Click Start, right-click Computer, and select Manage.
3. In the left pane, click Device Manager.
4. In the middle pane you will see a list of categories for installed hardware.
5. Check for any devices that have a yellow warning icon.
6. Right-click that particular device entry, and select Update Driver Software.
7. If you have already downloaded the driver select Browse my computer for driver software.
a. Specify the location of the driver you downloaded and follow the on-screen instructions.
8. If you have not already downloaded the driver you can have Windows search online.
a. Click Search automatically for updated driver software, and follow the onscreen instructions.
Jan 28, 2010 | Computers & Internet
Why and what is my PC continuously downloading from Internet eventhough I am not myself downloading anything. Kindly help. Thanks
Probably your PC is doing one of two things - it is either updating software, windows updates or antivirus or firewall updates, these can be turned off in the options menus for programs that are running, OR , it has a virus or spyware and those programs are updating and sending data back to their makers. Windows update is usually automatically enabled, to turn it off use control panel, administrative options, services.
Aug 30, 2009 | Computers & Internet
After windows update restart, driver program missing
- Kindly download the latest driver of the certain hardware.
Mar 13, 2009 | E-Machines eMachines Desktop PC
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might...
I have an Fujitsu Siemens Amilo D7830. I was updating chipsets to the laptop when it bluescreened. I had to reformat the HDD and reinstalled Windows Xp Pro SP2. Since then I have installed every conceivable Windows Update file there is and have updated all other drivers and chipsets. However, my soundcard is no longer working.
When clicking on the device in question in the device management screen, the following error messages are displayed for the Realtek AC'97 soundcard: This device cannot start. (Code 10), PCI bus 0, device 31, function 5.
I have attempted at downloading and installing almost every drive I can find for this device, and have followed the standard Microsoft help routines. i.e. uninstalling the device and reinstalling the device still with no luck.
I hope you will be able to assist, as my last resort will be to take it into the a techie shop i.e. PC World for them to have a look at it.
Kind regards,
Sean
Sep 28, 2008 | Audio Players & Recorders
Mitac Mio A701 Smartphone Logo
48 people viewed this question
Top Mitac Computers & Internet Experts
matt
matt
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
