Question about GPS
My Garmin Nuvi (I see no model number on it..have had it about 4 years) has a touch screen that has become increasingly unresponsive. It seems to work when cold but as soon as it warms up a bit (in the sun on the windshield) it quits. Now I can't get it to work at all. I took the back off and unplugged and replugged the two connections that were immediately obvious and that made no difference? Do you have any suggestions, or what would be the approximate cost to repair if it's just a matter of "knowing what to whack and how hard"? Thanks Jim
  • 4,924 Answers
You can try to make a reset ..and see how it behaves after ....Take a look on this page and see these methods of reset
http://www.mydigitallife.info/2009/06/09/how-to-reset-garmin-nuvi-gps-device-access-maintenance-mode/
about how it will cost if it is getting to fix something physical on it ..I can not estimate ..but if it is that old..I guess the parts and the manual work will cost enough to make you go for a new one if this will not make the job done anymore..
Posted on Oct 03, 2010
Touch screen is defective. seems to have dimple under the face and when you push is indents, but not responsive
If there is physical damage to the touchscreen, then it can become unresponsive and will need to be replaced. The touchscreen is bonded to the glass (they are one piece), so both the touchscreen & glass will need to be replaced, even though the glass may not be cracked. Please see this link for more information and how to have the touchscreen replaced for you.
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Mar 30, 2014 | Garmin nuvi 780 GPS
Tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
My Nuvi 650 screen reads "The following map data is more than a year oldand should be updated. When I touch the "OK" on the screen, nothing happens, it seems the screen has become unresponsive.
I would suggest some caution here. I have noticed a trend in anything that can be updated by the consumer---they just blindly do it and I have also seen as the result of this dozens of units crash and burn---if you have not issues and the unit functions why risk losing it?
Turn this unit off and see later if turned on it functions or not, failing that the only way out of the mess would be a call to the maker.
Don't just blindly say ok, kind of like getting a email with a virus and saying OK.
Dec 20, 2012 | Garmin nuvi 650 GPS Receiver
Touch screen is unresponsive
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Oct 26, 2010 | Garmin GPS
I have a Garmin 885 the sceen does not work. touch keys do not work. I cannot get past the Garmin start up when plugged in . when I unplug it I get the warning page and select ok and get pge with wheree ti...
I recommend attempting a hard reset of your Garmin Nuvi 885.
Then I would upgrade the system software to the latest version. This often brings back unresponsive Nuvis.
Perform the Hard Reset
  1. Power the unit off.
  2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  3. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  4. Press "yes" and the unit will reboot.
Upgrade the System Software
The upgrade software is a download available from Garmin. Installation steps are detailed here.
I hope that helps.
Dec 30, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin - Nuvi 650 - Touch screen dead/unresponsive
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Try this:
1) Plug the device into the computer and allow it to go into Mass Storage Mode.
2) While in Mass Storage Mode, locate the device on the computer and delete the gupdate.gcd file in the Garmin folder.
3) Safely remove the nuvi via the Safely Remove Hardware feature on the computer.
4) Once prompted, unplug the nuvi from the computer, and power off the nuvi.
5) Power on the nuvi by holding the power button, continuing to hold the power button for about 1 minute, at which time the screen calibration option will display.
6) Calibrate the touch screen.
Sep 11, 2009 | Garmin nuvi 650 GPS Receiver
My garmin nuvi 670 touch screen is not calibrated
Have you tried using the screen calibration command? Press the Wrench symbol, then the Display symbol and then Calibrate screen. Press the dots as it tells you to and you should now have a calibrated touchscreen.
- Jim
SHARCNET- USA
Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
14 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
