Question about Epson Stylus CX4800 All-In-One InkJet Printer
Says it is out of paper...?
My printer will bring down the piece of paper a little of the ways and then I can hear the ink cartridge moving as if it is printing, but the paper is never brought down far enough to be printed on, and after a few seconds it says it is out of paper when it is not!
    Problem Solver:
  • 14 Answers
Does this happen when you use the copy function of the printer? If it does, try to check if there are any objects stuck in the rollers or if there are any obstructions inside the printer that may cause a paper jam.
If if doesnt happen when you do the copy function, it may be driver related. What is the operating system of your computer? You may have to uninstall/reinstall the drivers.
Posted on May 27, 2008
Printing blank pages
Hi Wendy,
This is known issue with Canon printers. Try the steps below.
Instructions
    • 1
      Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    • 2
      Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
      • 3
        Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
      • 4
        Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
      • 5
        Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Regards,
    Suhail
    May 20, 2012 | Canon PIXMA iP1600 Printer
    Keep getting paper jam fault 3618
    Hi!
    If the error comes up during the initial setup of the printer:
    • Select All-in-One Printers.
    • Double-click the Setup Guide for your printer.
    1. Open the printer access door.
    2. Remove all:
      • orange shipping tape
      • foam pieces
    3. Follow the steps in the Setup Guide to insure that you have properly installed the printhead and ink cartridges.
    4. Close the printer access door.
    5. Press OK to clear the error.
    6. Make a print.
    OR
    Check the printhead carriage area:
    Debris and Obstructions:
    1. Remove any paper, tape or other obstructions from the printhead carriage area.
    2. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
    Ink Cartridges:
    1. Lift the printer access door, then remove the ink cartridges from the printhead.
      NOTE: If the printhead does not move to the center position, press Home, then Maintenance on your printer. Check if the Install Ink Cartridge option is available. If so, select Install Ink Cartridges, press OK, and follow the instructions. Otherwise do the following:
      1. If an error is displayed on your printer control panel or the status monitor on your computer, press Cancel to clear the error.
      2. Go to KODAK All-in-One Printer Downloads and Drivers, select your printer from the All-in-One Printers pull-down list, and download and install the latest firmware version for your printer. Follow the on-screen instructions.
      3. After you upgrade the firmware, press Home on the printer control panel.
      4. Select Maintenance, then press OK.
      5. Select Install Ink Cartridges, then press OK.
      6. Follow the instructions on the control panel LCD.
      7. Go to the next step.
    2. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
    3. Verify that the KODAK Ink Cartridges have not been refilled.
    4. Insert the black ink cartridge into the printhead, then press down firmly until you hear it click into position.
    5. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
    6. Close the printer access door.
    7. Press OK to clear the error.
    8. Make a print.
    Hope this helps.
    Apr 19, 2011 | Kodak ESP5250 All-In-One InkJet Printer
    Paper unable to feed
    All the Best..
    Nov 27, 2010 | Canon PIXMA MP470 All-in-One Printer
    How do you fix a paper feed problem in a Cannon iP1600
    1. Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    2. Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
    3. Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
    4. Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
    5. Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Good Luck!
    Aug 23, 2010 | Canon PIXMA iP1600 Printer
    How di I reset my Pixma printer MP150 from
    Use this method with your own risk!!
    E2-2 = No paper (ASF)
    E3-3 = Paper jam
    E4 = No ink
    E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
    E8 = Waste ink absorber full, or platen waste ink absorber full
    E9 The connected digital camera / video camera does not support Camera
    Direct Printing
    E14 The Ink cartridges whose destination are wrong
    E15 Ink cartridge is not installed E16 - Ink remaining is unknown
    E16 -E19 Failed to scan head alignment sheet
    E22 Carriage error
    E23 Paper feed error
    E24 Purge unit error
    E25 ASF(cam) sensor error
    E26 Internal temperature rise error
    E27 Waste ink absorber full or platen waste ink absorber full
    E28 Ink cartridge temperature rise error -
    E29 EEPROM error
    E33 Paper feed position error
    E35 15 USB Host VBUD overcurrent error - USB
    E37 17 Abnormal motor driver error
    E40 20 Other hardware error
    E42 22 Scanner error
    Reset E27 Waste ink absorber full or platen waste ink absorber full
    First way
    turn off printer.
    - put your finger and hold on/off with reset/stop button together
    - turn on printer power switch
    - release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
    - wait at the moment
    - relese stop/reset button 2X.( your will see alarm led blingking for 2X)
    - relese on/off button.
    wait until your printer digital screen shows number 0.
    - after printer panel screen shows number 0.
    - press reset button 4x
    - press on/off button 1x
    wait until your hear printer roller is moving
    after your hear roller moving, wait until your dont hear anything from your printer :)
    then turn off and turn on your printer again and your will see your printer back to normal.
    Second Way
    turn off printer.
    Good Luck
    Jul 18, 2010 | Canon Office Equipment & Supplies
    The printer shows error code 5100 I think it has
    Hi You can Try 2 things.
    ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
    If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
    Next try.
    It may be a piece of paper or a scotch tape or a staple wire.
    Solution 1:
    Clean the timing strip.
    Solution 2:
    The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
    Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
    Good Luck.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    May 05, 2010 | Canon PIXMA MP460 All-In-One InkJet...
    Screen says cartridge cradle is stuck but it moves freely
    Ok there
    You may not see a paper jam.
    This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
    And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
    Mar 05, 2010 | HP PhotoSmart 7760 InkJet Printer
    Epson workforcs 500 keep bringing up paper jam
    Hello there
    Feb 20, 2010 | Office Equipment & Supplies
    Printer making buzzing noise when turned on, moving part that holds ink cartridges do not move, blinks red lights within eight seconds after powering on.
    Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    Feb 16, 2010 | Office Equipment & Supplies
    The paper wont go through the printer
    Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    Jan 23, 2009 | Canon Pixma MP450 All-In-One InkJet...
    Epson Stylus CX4800 All-In-One InkJet Printer Logo
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
