Question about LG WM-2277HW Front Load Washer
Water doesnt rinse
Cant figure what has gone wrong, but the water sits in the machine and just doesnt want to rinse
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Or click 'thanks for trying', your prob will be back for someone else to hv a try.
Posted on May 29, 2008
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Whirlpool washing machine sticks on rinse cycle
it proberly your cold water valve or the hose filter blocked. when its on rinse lisen at the back where the cold pipe goes into your machine and see if you can hear a buzing noise if you can its blocked take off and clean if you cant hear anything the inner cold valve has gone
Nov 27, 2011 | Washing Machines
What has gone wrong when washing machine fills
possible heater fault.Try it in rinse cycle only if it works then the heater IS faulty
Jun 29, 2010 | Washing Machines
Water doesnt pump out to start rinse cycle
Seems the timer is sticking at the drain cycle. Manually move the timer and see if this helps. If this works then the timer is bad.
Jul 05, 2009 | Washing Machines
My Kitchenaid washer stops on the rinse cycle...
Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
Jul 31, 2017 | KitchenAid KAWS750L Top Load Washer
No rinsing water coming in
There are 2 versions of this washer dryer, a cold fill only one and a hot and cold fill version.
If it is the cold fill version, it could be the water level switch that is malfunctioning, cutting off before the correct level is reached, or a sticking water inlet valve.
If it is the other version, then the same thing applys, plus the coil on the valve that controls the rinse cycle could be open circuit.
You need a meter to test the valve coils for continuity..
Make sure that there is actually cold water to the valve, if it is a hot and cold fill model.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit W 123 Front Load Washer
ZANUSSI ZWD162701 washing always comes out cold - WHY?
Washers are meant to rinse in cold water, so clothes should come out cold.
If you are not sure if it is getting hot, then select a very hot wash, and feel the door glass periodically, it should gradually get hotter, if it does not , then it is washing in cold water only.
This could mean that the heater element has gone.
Thanks.
Jan 07, 2009 | Zanussi ZWD1270 Front Load Washer / Dryer
Cold/Hot water
if this is a machine with two fill hoses, then you have them the wrong way round. to check, put on rinse and cold water should come in. if not, swap the hoses round. don't rely on what you house plumbing says is hot or cold - this is often wrong
Aug 28, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing machine filling
turn the power off if the water stops it most likley a pressure switch problem or the pressure tube on the side of the outer tank may have pulled off.if you turn the power off and the water doesnt stop then the valve is faulty (cold)if it was on the rinse.hope this helps.
Mar 17, 2008 | Admiral AW22 Top Load Washer
LG WM-2277HW Front Load Washer Logo
26 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
