Question about Compaq A1500 All-In-One InkJet Printer
Won't print It states that my compaq A1500 all in one is either in use by another application, orit is busy printing a copy or fax. Please try again when the compaq A1500 is available. But It shows that there isn't any documents pending. I deleted them all. I have deleted and reinstalled my disc three times without sucess. Please help me I am at witts end. Thanks
  • 31 Answers
Ok I just solved a persons problem that is very similar to yours. OK So I'll just paste what I told the other person. You might have tried printing a doc/app out earlier and it might have failed so while you trying to print out this present app/doc the printer still might be focused on that failed or it might be confused. Now to stop this follow these instructions. Go to the start bar click control panel. Then once that window pops up ( control panel ) click printers and other hardware. Then once that window pops up ( printers and other hardware ).  Click Printers and faxes and that page will have all the printers and faxes ever installed to your computer. Now click on the printer thats yours and then a smaller wider window will appear you will that window will have all the doc/app you have ever tried printing out. the status bar will show what is going on with each doc/app. Now you should first stop all the doc/apps and refresh. To do this you should highlight all the doc/app and then go into the document tab ( there are several tabs in this window such as document , printer, view and help) then click cancel and cancel all the doc/apps. last step is to go into the view tab and click refresh and it should work :-). If not contact your printer manufactor.
Posted on Jul 10, 2008
When I try to scan, I get an error msg that says "printer is busy."
Check your printer to see if you have any printing jobs in queue;
if so, clear them out and try again.
Oct 21, 2013 | Lexmark Impact S305 Wireless All-in-One...
My fax won't print copy's or incoming faxes.If I do a self test there are lines that are printed. The ink level says 4 / 8. I took the cartridge out and cleaned the copper area as said in manual...
Based ENTIRELY of the total LACK of make and model information about your fax unit, my guess is that the software DRIVER is corrupted! But of course, that is a total GUESS! Let me show you why that is SO IMPORTANT!
My favorite ant broke her leg ... leaving her only FIVE good legs to run around on! Most people know that ants (INSECTS) have six legs. But you MIGHT have assumed that my ant was my mom's sister, or my dad's sister, and that I simply misspelled AUNT!
May 11, 2017 | HP 1040 Plain Paper Inkjet Fax
Which way do I put the paper in my Compaq A1500 fax machine when I want to send a fax? Up, Down, print front or back? Thanks.
Is this the correct Model number? I looked it up and it doesn't seems to match the database. It doesn't matter if it's up or down. Experiment with the front or back. Once you get the correct placement - then you're good to go.
Dec 15, 2010 | Compaq Office Equipment & Supplies
Need to send 8 page fax. How do I do this with A1500? Can't seem to get past first page.
Save your 8 pages to file start a new fax select attachment add you file to the attachment & send your fill
Dec 03, 2009 | Compaq A1500 All-In-One InkJet Printer
Compaq A1500 all in one
Did you trying going to printers and setting default printer? Also click online for the Compaq A1500.
Aug 24, 2008 | Compaq A3000 All-In-One InkJet Printer
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Compaq a1500 printing probs
ok you might have tried printing a doc/app out earlier and it might have failed so while you trying to print out this present app/doc the printer still might be focused on that failed or it might be confused. Now to stop this follow these instructions. Go to the start bar click control panel. Then once that window pops up ( control panel ) click printers and other hardware. Then once that window pops up ( printers and other hardware ).  Click Printers and faxes and that page will have all the printers and faxes ever installed to your computer. Now click on the printer thats yours and then a smaller wider window will appear you will that window will have all the doc/app you have ever tried printing out. the status bar will show what is going on with each doc/app. Now you should first stop all the doc/apps and refresh. To do this you should highlight all the doc/app and then go into the document tab ( there are several tabs in this window such as document , printer, view and help) then click cancel and cancel all the doc/apps. last step is to go into the view tab and click refresh and it should work :-). If not contact your printer manufactor.
Jul 09, 2008 | Compaq A1500 All-In-One InkJet Printer
Printer
You may have the printer settings set to pause accidentally or set to work offline. Go to printer icon, right click and scroll down to check all your settings, if any of above apply, untick them. Try again. The error message is telling you it cannot communicate with the pc. Have you updated anything on your pc, sometimes new systems settings, particulary windows updates and service packs can cause drivers to become incompatable. If all else fails, you could try getting updated drivers from the Compaq website.
Aug 17, 2007 | Compaq A1500 All-In-One InkJet Printer
How Can I Reprint a Fax?
Here's a trick that I used on the Canon thermal transfer years ago. First take out the thermal transfer unit and roll up the black transfer sheet to the begining of the lost fax. Then reload the paper. Next get a solid black original equal and make a copy. The result you should get a negative copy of the lost fax. Repeat this step until all the faxes are recovered..
May 31, 2007 | Panasonic KX-FC195E Plain Paper Thermal...
Compaq A1500 All-In-One InkJet Printer Logo
106 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
