Question about GE Monogram Side by Side Refrigerator
GE side by side freezer door won't stay closed. doesn't seem to be holding the "suction". and the frig door seems to be an issue too.
SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
How do I clear the frozen drain in the bottom of freezer?
Posted on Apr 06, 2008
IFIXALL
  • 868 Answers
SOURCE: Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Posted on Jun 06, 2008
The water on the floor below the freezer door is due to an inadequate door seal. The door is not closing completely, either a foreign object at the bottom, or more likely, the freezer door gasket needs replacing.
Posted on Aug 25, 2008
  • 10 Answers
SOURCE: sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Posted on Feb 11, 2009
lenwest
  • 150 Answers
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
GE Profile side by side refrigerator. The freezer side started to have leakage and caused frozen ice along the walls & Extreme suction on freezer side.
Not sure on this one, but many freezers draw a vacuum like that for a little while to try to get all of the air and moisture out. Commercial units are designed that way. If Ice is building up, there is most likely an air leak. Check the door gaskets and see if they are sealing up properly.
Aug 02, 2016 | GE Refrigerators
Does this pull a vacumn when either door closes? The freezer side doesn't seem to do that now. Getting frost buildup in chut where ice is dispensed. Don't see a problem with the door seal.
Take a knee at freezer door while closed - LOOK UP! Look up through where the ice comes out, that door is stuck open! Try cleaning with warm hot soapy water.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | GE GSS20IEP Side by Side Refrigerator
Temp set at 5(as always) but food in the refrigerator is freeezing. Ice maker and water distpenser do now work. just started happening.
Try unclogging the drain line for the freezer. What seems to be happening is your refrigerator is working too hard to keep the temperature that it reads inaccuately. Usually a light defrost will do the trick , sometimes a longer defrost or one using warmers...don't be too tempted to use anything like a hair dryer for safety reasons.
Make sure you keep your frig door closed and use the frozen food in the frig to hold temps down.
Good luck.
Mar 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer door stays ajar after closing the refrigerator door.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 16, 2009 | GE GTS22KBP Top Freezer Refrigerator
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Upright freezer door won't stay shut
the door maybe disaligned. Look at the the door side on to see if it has dropped a little. It may just need adjusting.
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Jun 06, 2008 | GE GSS25QSTSS Stainless Steel
Side by side GE profile
I have a GE side by side refrigerater freezer. I thas the diagnostic center on the freezer door. The de symbol started flashing afew days ago and the refridgerater side isn't getting cold. the fan is on and doen't seem to cut off, If someone could steer me in the right direction I would appreciate it.
Jan 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram Side by Side Refrigerator Logo
139 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
