Question about Zenith DVB412 DVD Player
Can I change the parental control setting on my dvd player with no remote?
I do believe you need the remote control, there is no other way that parental controls can be accessed
Posted on Oct 03, 2010
How do I change the zone on my Soniq E32W13D-AU?
You should have got a red card with the AU and NZ customer support numbers on it. If you phone them, they will tell you how to unblock the player to make it region free.
On the Soniq QV191LC TV and DVD player, you follow these steps. It may work for your model but if it doesn't, try the support line.
1. Switch on
2. Switch to DVD mode (use Source button on remote)
3. Select DVD setup menu (press DVD button on remote)
4. Select Preferences page (use > key on remote)
5. Press '0' key 4 times on remote: the Region Code menu will appear
6. Use up and down on remote to select region (0 of course)
7. Press exit button.
You should now be region free.
Try these numbers:
AU 1300 765 663 / (61) 3 9543 5111
NZ (64) 9 2667512
If it's any help, you can download the manual here:
ftp://ftp.quatius.com.au/Manuals/E32W13D-AU.pdf
Jul 31, 2014 | Sony Playstation 3 (PS3) Console
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
I'm trying to play a dvd but it says that parental controls have been set. I know the passcode is 8888 but when I type that in on my remote (universal, not original) it doesn't even recognize that I've...
Sorry u have to buy an original remote for this.The universal remote,will not be response by the tv for tthis function.Try website like Remotes.com to buy an exact to the original remote.
Oct 21, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
How can I change the parental control? Somehow the parental controls are set on the DVD player and it will not allow me to play certain dvds without a password
Unfortunately there are no known ways to change the user code. The parental controls are set because it's a DVD player for kids - and you must input the password every time you want to play a DVD.
1369 is the code to allow you to play blocked movies. I still haven't found a way to change the level. Again, you have to input the code each time. I know it stinks, but I guess they didn't think of the parental feature in its entirety.
Jun 24, 2010 | Disney Ramone DVD Player
I am trying to play a dvd and it is asking me for a code or password, I never set one I have played the dvd player before, so this is a puzzle.
There are a few different "default" codes that you can try.
0000 or 1111 or 1234 or 9876 etc.
Here is something that i just came across, I do not know if it will work but it maybe worth a try:
1. Turn the DVD player on with No Disc in.
2. Press MENU on the remote (Ignore the 'NO' symbol that appears)
3. With the remote, press 1, then press 9 (Ignore the 'NO' symbol that appears)
4. A menu should appear.
5. Use the Down Arrow to highlight the PARENTAL CC then press ENTER. Now type the Parental Control setting you want with the remote (8 is the highest setting, press 8 on the remote for a fully unlocked player). Then press ENTER on the remote after entering your new setting.
6. Use the Down Arrow to highlight the PARENTAL PW. If you wnat to change this, press ENTER. You can enter any 4-digit code here. Press ENTER on the remote after you enter the 4-digit code.
7. To exit the menu and save your settings and push OPEN/CLOSE with the remote.
Feb 12, 2010 | Philips Televison & Video
Parental control
i posted the site on tips and tricks where you will find the manual.parental control 8 is the default setting. the factory setting password(enter this in the new password bar)is 3351 and youll have to take it from there.it seems you have a password on your machine you can change it to your own with the factory setting number.good luck, SLEWEY.
Feb 16, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD parental lock
I have a GE 13TVR62 (with a problem listed here). I've learned that the Parental Lock Settings are changed by using the Remote Control. Usually the actual Settings are changed by pressing the Up or Down or Left or Right Arrows to make the Change; while the Parental Lock is Highlighted on the Menu.
Dec 22, 2007 | GE 13V110TD 13 in. TV/DVD Combo
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
Zenith DVB412 DVD Player Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
