How to refill hp photosmart C4280 psc all in one ink cartridges?
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
check here for color one
for black
and for black XL
if i help you pls vote for me
Posted on Nov 01, 2010
  • 570 Answers
Please just follow the below instructions and fix your problem.
1.
Lay down a piece of newspaper on a table where you will work. Remove the supplies that come in the refill kit. The HP 74 kit will have one bottle of black ink and one syringe. The HP 75 kit will have one bottle of each color ink and three syringes.
2.
Use your fingernail to lift up a corner of the label on each cartridge and pull back to remove the label. Use the toothpick to test the color cartridge vent holes so that you know what color will go in each vent hole. The magenta should be on the lower left side, the cyan on the lower right side and the yellow at the top. The black cartridge vent hole is at the top.
3.
Fill each syringe with one color by inserting the needle into the ink bottle and pulling back on the top of the syringe. The color ink syringes should have 6 milliliters of ink and the black ink syringe should have 20 milliliters of ink.
4.
Place the tip of the needle into the vent hole for the corresponding color. Push down as far as the needle will go easily without force. Press down on the top of the syringe slowly so that the ink is injected into the cartridge. Do this for each of the colors and the black ink. If any ink seeps out of the fill hole, use the rag to wipe up the ink and stop filling. This could mean that the sponge may not be entirely empty.
5.
Replace the HP 74 and HP 75 ink cartridge in the printer. Run two to three test pages so that the ink can cycle. Use any document with some color and black text for the test.
And now you are done with it
Thanks.
Posted on Oct 03, 2010
New black very faint
1. hope you have not touched the contacts or head those protected by pink tape.
2. or the ink is dried up
Replacing Cartridge HP Photosmart C4280 All in One Printer
Apr 06, 2016 | HP Photosmart C4280 Aio Printer
Will lexmark 17 black inkt cartridge and a lexmark 27 color ink cartridge fit in a hp photosmart c4280 all in one printer and work properly?
Negative, but you may want to think about refilling your HP74/75 ink cartridges for your HP PS C4280 printer....it's actually quite affordable.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
Jun 12, 2013 | Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
I have refilled the ink in my hp74 cartridge and it does not register as full on the printer. It also, does not print anything?? Barely ledgable when it does...very very light.
Your refilled hp 74 will not register as full after you do a refill.
You will have to remove some ink out of the ink cartridge.
There is a special clip that can be purchase to do this.
You could just leave the cartridge in overnight for the ink to reach the bottom.
The ink cartridge will then be able to print.
Sep 14, 2010 | HP Photosmart C4280 Aio Printer
My HP photosmart c4280 keeps aligning the cartridge when on!
probably the alignment its not succeed
be cause on of color is missing
check if you see and the 4 colors on paper (yellow cyan magenta black)
if one color is try cleaning , refilling or replacing the cartridge
if you need instructions for refilling check here
http://www.youtube.com/watch?v=Ybj4awp_1ic
May 01, 2010 | HP Photosmart C4240 All-In-One InkJet...
HP C4280 hasn't worked for months now and hardly been used - message comes up saying ink cartridge is empty when it isn't. I'm not an expert but a couple of experts have looked at it and various things...
Remove the ink cartridge.
Place it, bottom-down, on a wet paper-towel.
How much ink is "pulled" from the ink-cartridge.
Move to a different spot on the paper-towel,
and touch it again.
If you see "less" ink, or none at all, then it is an EMPTY cartridge. Refill it, or replace it.
Jan 14, 2010 | HP Photosmart C4280 Aio Printer
Error code: incompatible ink cartridges
I get this error message when I try to refill the same cartridge. I noticed that in some refilling station they have a device called the reseter.
This will reset the device in order to use it again.
Jul 24, 2009 | HP PhotoSmart C4280 Laser Printer
I NEED HP PHOTOSMARTD7100 CARTRIDGES BUT I DO NOT SEEM TO FIND THAT NO ANYWHERE
Here's a link that will sell to you
http://www.ink-refills-ink.com/printer/HP+PhotoSmart+D7100+Cartridges/15097/?src=gpsearch&gpprod=HP+PhotoSmart+D7100&gptype=cartridge
Nov 23, 2008 | HP PSC 1410 All-In-One InkJet Printer
Help me replace the ink cartridge on my photosmart copier/printer
Step 1: Turn printer on -- open front door.
Step 2: Tilt cartridge down in front and remove cartridge.
Step 4: Refill cartridge with ink per instructions on refill kit.
Step 5: Reinstall cartridge by reverse of step 2, then 1.
Works for me -- I refill 6 or more times before replacing the
cartridge.
HP 1401 PSC
Aug 29, 2008 | HP Office Equipment & Supplies
Computers & Internet Logo
266 people viewed this question
David Payne
David Payne
