Question about ASUS P5PE-VM Motherboard
Audio i mean the audio plug in in the front of casing
    President:
  • 2,351 Answers
Hay jake,
goto page 1-27 in the Asus P5PE-VM manual.
There is a diagram of the pin-outs for front case audio/sound connector.
Mike
Posted on May 29, 2008
Compaq dc 7600 small form factor, front usb and audio not recognized
I am assuming you have moved the board to another case and have connected front-mounted card readers etc. but none are working. I would check in device manager and see if there are any devices with exclamation points beside them.....which would indicate that windows sees the device, but that you are missing some of the drivers for the board which can be downloaded from HP. If you have devices in device manager that are labelled "unknown device", then a program like SIW or unknown devices may help you determine which drivers to get. A safe bet would be to go to HP's download section and get everything available for that board.
Also, check the bios and ensure that "plug and play OS" is set to on or yes
I would also look in the bios/setup and ensure that the connectors on the board are actually turned on. USB headers on motherboards are pretty generic, meaning that you should be able to plug in pretty much any front panel device (audio,card readers,usb).
Please check these things and get back to me. If you need instructions on how to do any of this stuff, then get back to me and I will be happy to help further.
Hope this helps!!
-Joe
Jan 31, 2013 | Computers & Internet
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
I have a dell desktop with two jacks in the front.One is marked Micophone and the other is marked headphones.I cannot get the headphones to work at all and have checked all possible volume controls.Iam not...
Some-times those connectors are not connected to the respective plug in points on the mainboard. That is a possible reason for them not working.
A solution to this problem would be to open up the chassis and ensure that the ports are indeed plugged into the mainboard.
Intel based computer systems use AC'97 and AMD based computers use HD Audio.
You may need to consult the mainboard manual to correctly plug the ports in.
The other way is to use the ports located at the rear of your computer chassis, however as you may have experienced it may mean that the cables on your mic/earphones are not long enough. In which case you will have to check that the front headers are plugged in.
Remember that when using a microphone you need to specify which port/audio in port you are using rear or front.
Take care!
damnor01
May 24, 2011 | Dell Vostro 220 Desktop Computer
Hi i have a Codegen model 450x case and i am trying to install a Gigabite GA-P35-DS3R motherboard and am having troulbe with the start switch wires, the cases wires do not matgh the diagram in the...
I'm not sure what you mean when you say the case wires don't match the diagram. You might mean there is already a plug on the end of the wiring, and this plug doesn't match the board header. If you're reusing the case from a name-brand machine like a Dell or HP, this is possible. They often get custom versions of motherboards made, and their front panel connectors are usually a nonstandard layout. On the other hand, in a generic retail case, the front panel wires normally have separate connectors on the ends for the switches, indicator LEDs and any front panel USB and audio jacks.
This is the front panel header diagram I found in the manual for your board (I looked at version 2, but the connections should be the same if yours is a different version):
This board has an Intel standard layout for the header. If your wiring has separate connectors, the start (power) switch wires will plug onto pins 3 and 4. I have never seen a retail case come with anything other than a two-pin plug on the end of the power switch.
If you are dealing with a custom plug on your case's wiring, what you can do is remove the pins from the housing. They almost always are held in by a plastic tab on the connector shell that engages a tang on the pin. Use a thin object like a small flat-blade screwdriver or a knife tip to lift the tab and you can slide the pin out. Insulate each pin with small-diameter heat-shrink tubing if you have it, or a layer of electrical tape. (I prefer the heat-shrink tubing, which is neater and more permanent.) Then you can put each pin over the corresponding pin on the motherboard's front panel header. Unless the pins are very loose, they will stay in place by friction. I often use this technique when salvaging a case.
As for the CPU fan, be sure you have the connector over the right pins. Here is the diagram from the manual:
You might need to rearrange the pins in your fan power connector if they don't line up correctly. This layout looks a little strange.
Dec 21, 2010 | Codegen (PS-450W) (PS450W) 450-Watt Power...
I switched gabinets and the new one has a audio and mic imput on the front and i need to connect them the the MB corectly and idk where to plug them
The PCChips support page for your board is here, where you can download the full manual as well as drivers or other information you may need. This picture shows the front panel audio header location (AUDIO1):
And here is the pin information:
I believe the header complies with standard layout, so the plug on the cable to the front panel audio connectors on your new case may fit as-is. Or on many cases the wires have individual connectors on the ends to push over the pins. If yours is like this, you can put them on the correct pins by following the table. The wires are marked with their functions.
Good luck and thanks for using Fixya!
Dec 15, 2010 | Chips M863G V1.5 Motherboard
FRONT AUDIO PORT
If you are familiar with electronic parts you can fix this with your own. Open you CPU casing and locate the wire connected to your front audio. At the end part of the wire from your front panel you need to plug the end part to your motherboard. You can see the audio port at the lower part to the motherboard. You can read there a label audio input so you plug at this port
Mar 30, 2010 | Mercury P4VM800M7 Motherboard
Sound cable connection
Look more closely at your motherboard, for a 4-pin "PC Speaker" label.
The "HD Audio" is _OUTPUT_ (left front, sub-woofer, right front, left back, right back) to Surround Sound speakers.
Dec 31, 2009 | Foxconn (945G7MA-8KS2) Motherboard
I am trying to install a new stereo in a 94 rodeo but my wire harness is cut off
here are the wire colors and what each does.
1994 Isuzu Rodeo Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Brown/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue/Yellow
Left Front Speaker Negative Wire (-): Yellow
Right Front Speaker Positive Wire (+): Green/White
Right Front Speaker Negative Wire (-): Gray/White
Car Audio Rear Speakers Size: 4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Red/White
Right Rear Speaker Positive Wire (+): Orange
Right Rear Speaker Negative Wire (-): Black/Orange
Nov 22, 2009 | 1993 Isuzu Rodeo
K9N6PGM2 motherboard cant get front audio micrphone and headphone sockets to work
In my case, it was solved by tweeking the sound utility, and not by touching anything in the computer:
  1. Make sure "Realtek Audio Manager" is installed (should come with the drivers)
  2. Start The "Realtek Audio Manager" (can do it by plugging earphones to the audio jack on the rear - the one the works)
  3. Look for the configuration tab - something like "Connector Settings"
  4. Set the "Disable front panel jack detection" checkbox
  5. Press [OK]
  6. Try again to connect the earphones to the front panel
See link from MSI forums:
http://forum-en.msi.com/index.php?topic=120665.msg911410#msg911410
Oct 16, 2009 | Computers & Internet
How to Hook DVD to tv with audo IN & Video IN in front no other plugs
what do you mean only to plugs in front does it have scart lead in back of dvd and in back of telly or do you mean that you only have to plugs that are different colours let me know
Feb 08, 2008 | RCA 36F530T 36" TV
ASUS P5PE-VM Motherboard Logo
158 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
