Question about Kidde Nighthawk Combo Gas/co Detector
Code 266 and 263, alarm sounding - Kidde Nighthawk Combo Gas/co Detector
    Problem Solver:
  • 5 Answers
This is urgent to check immediately - From what I can tell in the manual you are having high levels of CO detected. This is the parts per million reading in your home. See page 6-3 in manual - this the link - -
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COEG-3_900-0113en.pdf
On page 4-2 it says:
If the alarm sounds for carbon monoxide:
1) Operate test/reset button;
2) Call your emergency services ( fire dept. or 911);
3) Immediately move to fresh air - outdoors or by an open
door/window. Do a head count to check that all persons are accounted for. Do not reenter the premises nor
move away from the open door/window until the emergency services responders have arrived, the premises
have been aired out, and your CO and Gas alarm remains in its normal condition.
4) After following steps 1-3, if your alarm reactivates within a 24 hour period, repeat steps 1-3 and call a qualified
technician to investigate for sources of CO from fuel burning equipment and appliances, and inspect for
proper operation of this equipment. If
problems are identified during this inspection
have the equipment serviced immediately.
Note any combustion equipment not inspected by the technician and consult the manufacturer's instructions,
or contact the manufacturer's directly, for more information about CO safety and this equipment. Make sure
that motor vehicles are not, and have not been, operating in an attached garage or adjacent to the residence.
! WARNING:
Actuation of your CO and Gas alarm indicates the presence of
Carbon Monoxide (CO) or explosive Gas which can KILL YOU.
PHONE NUMBER
PHONE NUMBER
When the CO and Gas alarm senses a dangerous level of CO, the unit will emit a loud alarm pattern and display the concentration
of CO in parts per million (PPM). The alarm pattern is 4 short beeps - followed by 5 seconds of silence - followed by 4 short
beeps repeating. (Note: When the unit is disconnected from the 120V power supply and is on battery backup, the alarm pattern will
continue for the first 4 minutes after detecting CO and then the cycle will repeat every one minute). Know how to respond to a CO
or Gas emergency. Periodically review this user's guide and discuss with all members of your family.
4-
Posted on Oct 03, 2010
How do I get the alarm sound works.
The alarm beep was a option that was dealer installed. It has a factory option installed at the dealer. The siren itself is up front under the right front(passenger side ) of the cowl. If you remove the cover for the micro filter and the micro filter and look under cowl you should see the siren. If it is not there then you would have to buy the alarm system and have it installed and coded to the vehicle. If it is already there then it may have to be coded by the dealer to make it sound when locking and unlocking thru flash coding. Did it ever make a sound? If so it is there and may be a bad siren?
Dec 02, 2014 | 2004 BMW 3 Series
OUR REFRIGERATOR HAS A ALARM GOING OFF WITH A ERROR CODE LC ER
this sounds like the door alarm- it occurs after the door is open (or the switch has failed) for more than 2 minutes. Remember that both doors have one and also turn on/ off the lights which may or may not be tied together.
May 04, 2014 | GE Profile Stainless Bottom-Freezer...
Reset factory alarm
run fault codes to find which sensor set off the alarm and killed the motor. If all ok then reset using a code reader.
Jan 22, 2014 | Dodge Stratus Cars & Trucks
Ford transit on 06 plate alarm just goes off when it feels like, check doors all sound can u help.
see if it has a glass breakage sensor.
If it has it may need to be adjusted. Arm your alarm and tape on your windows or put your mobile phone in the cab and call it. see if your alarm goes off
Jul 04, 2010 | Code-Alarm Code Alarm Transponder
The alarm system i'm having probems on 1994 ford lincoln continental the alarm would not let me start the car
dark green with purple is your disarm wire, it's behind the drivers kick panel, if you ground this wire it will disarm the factory alarm for good, but it almost sounds like you have a starter kill relay on the red with light blue starter wire under your dash, you can remove the relay on this wire if you have one and jump pin 30 to pin 87 with a wire
Jan 03, 2010 | Code-Alarm Code Alarm Transponder
Keyless entry alarm sounds off at a set time, How
If you have children that play with the remote itself, it's very possible that they have pressed a certain code and set the alarm to do that. My 18 month old loves to play with my keys... which was fine until my tahoe started cranking every 3 hours. When I took it to a mechanic, they determined he had pressed a key code to make it auto crank. They reset it and I haven't had a problem since. Hope this helps!
Jul 30, 2009 | 2008 Chevrolet Suburban
When i lock the doors on a 2002 ford explorer about thirty minutes or so the alarm sounds. even if not activated. the only way it doesnt is when i leave it unlocked. any suggestions?
Check to see if when the alarm goes off if the interior lights are lit. Ford's have a problem at times with the door pinswitch in the door latch leaving the interior lights on, or coming on unexpectedly. Is this a factory installed alarm? WD40 sprayed into the latch will sometimes fix this problem.
Jun 12, 2009 | Code-Alarm Code Alarm Transponder
Volvo s80 alarm
Have the codes read out for the vehicle. It is likely that the siren for the alarm is causing the false alarm. If the siren is bad, there will be a code set in the central electrical module. (CEM)
Jun 26, 2008 | 2003 Volvo S80
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Kidde Nighthawk Combo Gas/co Detector Logo
337 people viewed this question
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
