Question about Maytag Neptune MCE8000AY Electric Dryer
Lower dryer has no heat for drying. Upper dryer continues to work with heat. Can it be fixed?
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Not heating during drying cycle
Heating problems always seem to involve the thermostats. Check the thermostats for continuity. Usually the upper limit thermostat is bad, but replace both thermostats if one is bad. Check the continuity of the heater and the thermal fuse. Disconnect one wire and test between the terminals. You should have continuity, or they are bad.
Apr 01, 2010 | Kenmore Elite HE4 Electric Dryer
Heat level in dryer
A dryer usually overheats because of a kink or blockage in the duct work, blockage in the outside wall cap, or because of a defective cycling thermostat. The cycling thermostat tells the dryer when to heat and not to heat. Clean any lint from the inner and outer ductwork. You can also remove the vent from the back of the dryer for a load or two to determine if the clothes dry faster or not. If this doesn't fix it, go ahead and replace the cycling thermostat. Make sure to use the appropriate setting to dry the clothes.
Aug 09, 2008 | LG DLG0452W Gas Dryer
Danyby laundry dryer works but has no heat
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
Dec 08, 2009 | Danby DCD5505W Electric Dryer
DRYER WILL NOT HEAT UP. "COOLING" LIGHT STAYS ON CONTINUOUSLY.
You dry by sensor???
Clean your sensor. The machine thinks the clothes are dry because the sensor is covered with who knows what???
Check your owner manual for the proper way to clean the sensor.
I hope this works for you
a
Sep 25, 2009 | LG DLE7177 Dryer
Dryer not heating. problem has happened before but has staring working agin in the past. Not this time.
Possibly the heating element. Sometimes they stop heating and then the element welds itself together again and works for a while. Other wise it could be a thermal fuse. If it is gas it could be the valve solenoids.
Sep 01, 2009 | Estate TEDS740JQ Electric Dryer
No heat from dryer
You have a bad heating element and or a bad high limit switch. Check them for continuity with a volt meter. No continuity, replace the part.
May 24, 2009 | Maytag MDE2400 Dryer
Dryer runs as usual but won't heat up.
you need to check continuity across the heating element with an ohm meter looks can be deceiving
Apr 14, 2009 | Dryers
There is heat but not enough to dry the clothes
Remove the connecting vent on the rear and try it.
If that works clean the connecting vent and the wall vent.
If it does not work, replace the gas valve coils.
Mar 28, 2009 | Frigidaire FSG748GF Dryer
Dryer not heating
normally, it is the thermal cutoff switch. test this part for continuity and if there is non, then that is your problem.
tnx 4 using fixya,
drcool
Sep 29, 2008 | Dryers
Dryer heats &revolves but clothes do not dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
if this helps please vote me a fix ya
Jul 15, 2008 | Maytag Dryers
Maytag Neptune MCE8000AY Electric Dryer Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
