Question about Bosch Axxis WTA 3500 Dryer
The drum doesn't turn but it heats fine - Bosch Axxis WTA 3500 Dryer
  • Bosch Master
  • 12,061 Answers
With this model, it is usually the belt, has either broken or come off, the drive pulley.
It is a difficult job to do, but it could be done DIY. You will need to obtain a service manual, and the belt to do so. (You would need to obtain a service manual first, to be able to obtain the part number for the parts required, as this is the only place this info exists)
If you do not wish to DIY, then please contact a Bosch service center, and ask for a "Quote" for the repair. When the serviceman calls.
Below is a DIY website to assist you in troubleshooting the exact cause, as although it is usually just a belt, it also maybe, the Motor, the main board,,sensors, the list goes on...
http://www.acmehowto.com/howto/appliance/dryergoe.php
Posted on Oct 03, 2010
Barrel isn't turning.
I believe you will find the belt is broken.
There is a motor which is supposed to turn a belt, which in turn drives the drum.
If you wish to repair ir yourself, a letter to "Fixya" could cause someone to walk you through the steps.
Be blessed.
Mar 04, 2013 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
The drum turns. It heats up. But only small loads of cotton get dry! We have changed the vent tube. Vacuumed the vent the lint catcher area and around the drum to remove lint and hair. Still not...
A very typical problem with GAS dryers is the soloniod coils that open the gas valve . When the coils are cool they operate just fine,but once the dryer gets warm from running the coils dont open the gas valve wwhen they are warm. If that is what your experiencing,the dryer heats when its cool but doesn't heat when it's been running for a while,the coils on the gas valve will need to be replaced.
GENE
Aug 16, 2011 | Roper RGX4634KQ Gas Dryer
Drum doesn't turn..Motor sounds fine and dryer sends heat. Drum turns freely when moved by hand.
replace the belt and idler pulley as a set sold at any Sears store
Aug 14, 2011 | Dryers
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryers Logo
155 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
