Question about KitchenAid KSRA25CNBT / KSRA25CNBL / KSRA25CNWH Side by Side Refrigerator
Icmaker icemaker wont' fill or go through cycle. should I replace the unit?
  • 725 Answers
You can check it by jumping it and run it through a cycle . I can help you step by step in a chat
Posted on May 27, 2008
Icemaker leaking water into ice bin during fill cycle
Need more information like model number as all units are not same and the answer could be different for each unit. Refer, ice machine, Freezer, all different unit and run differently. Please allow me to help you with the correct information. Thanks
Apr 15, 2016 | Refrigerators
My icemaker will get cold but wont make ice.
Hi and welcome to FixYa, I am Kelly
Here is what the manual says:
3. Icer-ette freezes but water does not come into mold; no ice production.
3A. Nonfunctioning water valve assembly. 3A. Clean or replace solenoid valve assembly.
3B. Mold heater assembly. 3B. Contact Raritan Technical Support.
3C. Water supply turned off. 3C. Provide pressurized water.
3D. Icemaker module. 3D. Replace icemaker module.
3E. Cold control. 3E. Replace cold control.
3F. Bad wiring harness plug contacts. 3F. Contact Raritan Technical Support.*
Although this is for troubleshooting non optical sensor refrigerators:
The troubleshooting procedures for cycling the unit are exactly the same,
The ice maker module part number for the 120V unit is PN 628366 (do a net search for this part number and save yourslef a bumch of money if you fetermine your moduleis bad) You start the harvest cycle by removing the front cover and then jumpering test points T to H. The white dial will begin to move if there is power to the module. Remove the jumper when the sweep arm reaches 5" o'clock and let the ice maker automatically cycle. It should harvest, and fill in on complete turn of the white dial. If it does not fill you probably have a water supply or water valve problem. There is an inline input power fuse for the ice maker. Power should come in via the red wire.
Mind you the ice maker has an internal thermostat behind the module assy that has to reach 15 deg F to start the harvest cycle. When you jumper T to H you are bypassing the thermostat. If the thermostat fails or the unit does not reach 15 deg F then the harvest cycle will never begin.
Thanks for choosing FixYa,
Nov 25, 2010 | Raritan Icer-ette Ice Cube Maker
Replace icmaker on kenmore
Unplug refrigerator. Take a moment to examine how the icemaker is positioned in the freezer compartment prior to proceeding (e.g.: water inlet tubing coming into the icemaker, etc.). Remove or loosen (where applicalble) screws holding icemaker. Unplug icemaker's wire harness connection. install new icemaker by reversing the screws harness, etc. Make certain that the new icemaker is in the "on" position. Plug the refrigerator in. Allow approximately 6 to 8 hours (some models take fewer or longer timeframe) for ice production.
Feb 10, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
Icemaker fills with water..the ice freezes but does not dump.
I dont believe its too much water. You may have a problem with the heater not coming on. If your icemaker advances then the termostat is calling for it. The ejector blade would bounce from the 1 oclock to the 2 oclock position until the heater warms the mold enough to allow the ejector blade to push the ice out. If the heater is out I would replace the complete icemaker
Jun 27, 2009 | U-Line Icemaker
Icemaker does not fill with water
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to check the wiring to icemaker solenoid.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 11, 2009 | Whirlpool ED5GHGXMQ Side by Side...
No ice from icemaker
check see if the lever arm in the icmaker is up
Apr 05, 2009 | Refrigerators
Is the Ice Full metal bail (connected to switch) hanging down (Icemaker ON), straight out (off) or missing? If straight out, push down, if Missing, find and reattach or manually flip the switch that the bail connected to (near light), close door and see if it kicks on.
Another possibility is the entire feed, valve and fill piping froze and is packed with ice. Use caution here...
Fill a large bowl that will fit in the cubetray with boiling water and carefully insert it into its location, Flip the switch up (straight out) close the door, set kitchen timer for 30 min and check it then by removing bowl , flipping bail down and closing door. It will take 30 sec or so to start filling.
If all that gets you no joy, replace the fill valve solenoid
Jan 15, 2009 | Frigidaire FRS3R5EMB Side by Side...
you might have a bad water valve that it wont close since your just repl ice maker then try to repl water valve at back if is leaking then the fill cup will be full of ice and also it will be over filling the ice maker mold
Oct 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag ice maker wont fill upwith water
is the icemaker cycling at all? pull the front cover offf of the icemaker and verify that the gear isnt broken. if so replace the motor module. if thats ok the next 2 things could be either a frozen fill tube or bad fill valve..
Dec 08, 2007 | Refrigerators
KitchenAid KSRA25CNBT / KSRA25CNBL / KSRA25CNWH Side by Side Refrigerator Logo
81 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
