Question about Goodman GDS80904BNA Open Flame Heater
I have a GPM125-4 gas furnace and I need a wiring schematic where can I get one
  • Goodman Master
  • 3,250 Answers
Www.goodmanmfg.ca some thing like that might org or ca but they have manules there you might have to play with the wed address
Posted on Oct 03, 2010
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Dec 16, 2013 | Ruud Rheem Furnace Blower Motor...
Have a 1998 wild travel trailer and need to
Hello. I can help you. Your gas furnace only needed a small amount of electrical power to operate. The electric heater on the other hand will need a lot more power and most likely will need 220 volts as opposed to 110 volts for the gas furnace. Therefore, a new line to feed your electric heater, sized appropriately will have to be run from the electrical panel to the electric heater. I recommend that you have a pro do this wiring job for you as there is no room for error. Good luck with it.
Nov 01, 2009 | Electrical Supplies
Dayton Heater M/N 3E227E
Hard to believe they sell a retrofit kit for a Gas furnace to a Customer....This is ahrd to advise you on with out seeing the schematic and if it is indeed intended for that furnace....the Spark mounting location is CRITICAL for safety so make sure that is correct above all.....OK The wire coming off the transformer and tied to the red wire going to the heat excghanger would most likely be a High Limit switch...cuts the gas off if the blower doesnt work etc or you would have a fire...so this switch must be in series with the transformer to cut power when the switch opens....the wire MV/PV coming from the "Electronic control box" needs to go to the New Gas Valve you should have which will have a termional marked MV/PV (Main valve/Pilot/valve) as your old one was for a standing pilot application and when you have electronic ignition you req a Gas valve for Intermittent pilot .....you should also have 2 more terminals on the valve MV and PV which will have seperate lines from the ignition control as well....basicvally there will be another wire coming from MV/PV going back to the transformer...make sure all wiring is correct and I would strongly advise you have a technician check your work before you attempt to use it....if wired incorrectly you could have a serious delayed ignition as its possible to power the main burner instead of the pilot if you wire it up wrong below is a typical spark wiring diagram....may not apply totally to your system but it will give you the general idea79f9627.gif
Oct 31, 2009 | Heating & Cooling
Need schematic for carrier furnace/ac. A butcher
There should be a schematic inside where the blower is or in the main elec. panel on unit
Oct 02, 2009 | Heating & Cooling
I have a 20 year old furnace the transformer went took it off a year ago forgot the wiring , need a wiring diagram
The transformer is for the low voltage side of your furnace, you should be able to take the door off of the furnace and follow the wiring schematic on the inside of the door to wire it back correctly.
Sep 30, 2009 | Heating & Cooling
Schematic diagram Rudd silouette II a/c gas furnace needed
There should be a small set of screw lugs on the electronic board in the furnace. Look for a red wire that comes out of the transformer and follow it to find where the 24V connections are.
Sep 21, 2009 | Ruud UBHC Air Conditioner
Need wiring schematics for goodman manufacture model # A60-20REV/C gas furnace
Here is a diagram containing the Wiring Schematics for Goodman Gas Furnace
Jun 27, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
46 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
